    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 368.9k Views 110 Watching
      rafaelparedes
      the option add a layer only visible in the current scene just add a hidden layer to all scenes,its not visible in the current scene.
      anyone else having this issue?
      • jiminy-billy-bobJ
        jiminy-billy-bob
        @wind-borne said:
        No, here is a shot of your icon surrounded by others in the customize toolbar window.
        This is weird. It displays fine on windows. Anyone else having this issue on mac ?
        @wind-borne said:
        As far as I am aware manipulating the code is the only way. There have been many threads about toolbar management on OSX concerning automatically displaying toolbars every time SU is opened.
        Ho ok, I thought it worked the same as windows.
        @hornoxx said:
        One thing I still do not understand: The use or the possibilities of the locksmbol here - does the lock prevent of deleting a layers or should it lock the layers content as well?
        I would appreciate a note about this question...
        You're right, I need to write some doc to explain everything.
        The locking feature only prevent layers to be deleted or purged, but only from within Layers Panel. If you try to delete or purge them from the default layers window, they'll still be removed.
        And thanks, I really appreciate your kind words πŸ˜„
        • jiminy-billy-bobJ
          jiminy-billy-bob
          You're right, I can reproduce this.
          • Bob JamesB
            Bob James
            @huckrorick said:
            Re:
            "It auto-updates the layer state of the current scene.
            If you turn on or off a layer, it's saved in the scene.
            Isn't that what I would want to happen??"
            From my use I would not want that to happen. When I open a scene I frequently want to turn on and off other layers while I'm examining the model. I do not want those changes automatically made to the scene. If I want the changes, then I click "update". It would be VERY inconvenient for my use to have every layer I turn on or off added to the scene.
            Your logic has changed my mind: I agree with you 100%. πŸ˜„
              Stephen Roberts
              Can't use it on my system - bugsplats every single time I try a drawing. I'm going to try disabling other plugins till I find out which one is causing the problem. If I find an answer I will feed it back. Looks very promising and I hope it can be kept....
              • tt_suT
                tt_su
                Is your forum profile up to date? You are using Windows (what version) with SketchUp 8?
                  davecoopstl
                  This is a fantastic plugin! Thanks for all the hard work.
                  Any chance you could make it so that when I use the Hide Dialogs function in SketchUp, your Layers Panel is included in the Dialog Boxes that hide/unhide??
                  That would be super-handy. Especially since I have Hide Dialogs assigned to a Shortcut Key and, right now, they all hide except for your Layers Panel.
                  Just a suggestion.
                  Dave.
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    As far as I know, the API doesn't allow this.
                    • jiminy-billy-bobJ
                      jiminy-billy-bob
                      @wind-borne said:
                      @jiminy-billy-bob said:
                      @wind-borne said:
                      Suggestion:
                      You might want to enlarge icon for use in main toolbar, barely discernible as shown on top shot.
                      Do you have a retina screen ?
                      Could you test the attached plugin and tell me if it has the same problem ? (The icon should be the same as Layers Panel)
                      jbb_toolbar_test.rbz
                      • wind-borneW
                        wind-borne
                        same result, small in main
                        floating ok sized yet do not want auto loading
                        "To read between the lines was easier than to follow the text."OSX 10.11.6
                        %(#BF80BF)[SU 8 pro
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          Great, thanks. I needed to know this snippet has the issue before filling a bug report.
                            I never knew this tread had added a poll?
                            Nice to see Thea getting some attention
                            • jiminy-billy-bobJ
                              jiminy-billy-bob
                              Yeah it's been some time now πŸ˜„
                              • jiminy-billy-bobJ
                                jiminy-billy-bob
                                New version 0.9.1 beta !
                                Changelog :
                                • Fixed options dialog on OSX
                                • Disabled automatic display of floating toolbar on OSX
                                • Fixed "Add layer hidden on new pages"
                                • Fixed clash with RichSections plugin
                                • Several bug fixes
                                Download in the plugin store !
                                • P
                                  paolo01
                                  Just installed and the plugin is very useful, to keep layers in order. It is really excellent! Thank you!
                                  If I can suggest a new function, it might be useful to have the possibility to duplicate the position of a single layer in different groups. For instance, in a building with many stores, I could have the layer "external walls store2" within the group "store2", but also within the group "external walls", containing all the external walls of any store .
                                  I think it could be possible to reach a similar result using layers and outliner together, but using a single panel would make the function of visibility much simpler.
                                  Thank you again and good job!
                                  Paolo
                                  • jiminy-billy-bobJ
                                    jiminy-billy-bob
                                    I think it would be rather confusing to have duplicates of the same layer. I've never seen such thing in any software, and I think there is a reason for that.
                                    Although, I was considering adding a function similar to layer compositions in Photoshop.
                                    • wind-borneW
                                      wind-borne
                                      Changelog :
                                      Thanks for saving me the trouble to deal with toolbar with each update. πŸ˜„
                                      Options dialog still dysfunctional on my OSX,
                                      reverts to this setup regardless of my choices
                                      %(#BF80BF)[SU 8 pro
                                      • jiminy-billy-bobJ
                                        jiminy-billy-bob
                                        So you confirm you're running SU8 pro on OSX 10.9.1 ?
                                        Do you see the effects of changing these options ? (Like if you uncheck "Display render toolbar")
                                          rafaelparedes
                                          no add a layer only visible in the current scene 😞?
                                          • wind-borneW
                                            wind-borne
                                            Yes, using 10.9.1 and SU pro and tested on SU 2013, no combination of check/uncheck of boxes has any effect and reopening options displays as shown above every time.
                                            Duh moment when I read warning sign when merging layers and saw I could disable elsewhere. My style of modeling doesn't bring forth that warning on its own and didn't understand why the plugin was until I watched SU's Layers window while merging layers. The warning sign was what I wanted to eliminate and now I know how.
                                            %(#BF80BF)[SU 8 pro
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 33
                                            • 34
                                            • 17 / 34
