    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 286.8k Views 110 Watching
    • H Offline
      huckrorick
      Re:
      "It auto-updates the layer state of the current scene.
      If you turn on or off a layer, it's saved in the scene.
      Isn't that what I would want to happen??"
      From my use I would not want that to happen. When I open a scene I frequently want to turn on and off other layers while I'm examining the model. I do not want those changes automatically made to the scene. If I want the changes, then I click "update". It would be VERY inconvenient for my use to have every layer I turn on or off added to the scene.
        rafaelparedes
        the option add a layer only visible in the current scene just add a hidden layer to all scenes,its not visible in the current scene.
        anyone else having this issue?
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          @wind-borne said:
          No, here is a shot of your icon surrounded by others in the customize toolbar window.
          This is weird. It displays fine on windows. Anyone else having this issue on mac ?
          @wind-borne said:
          As far as I am aware manipulating the code is the only way. There have been many threads about toolbar management on OSX concerning automatically displaying toolbars every time SU is opened.
          Ho ok, I thought it worked the same as windows.
          @hornoxx said:
          One thing I still do not understand: The use or the possibilities of the locksmbol here - does the lock prevent of deleting a layers or should it lock the layers content as well?
          I would appreciate a note about this question...
          You're right, I need to write some doc to explain everything.
          The locking feature only prevent layers to be deleted or purged, but only from within Layers Panel. If you try to delete or purge them from the default layers window, they'll still be removed.
          And thanks, I really appreciate your kind words πŸ˜„
            jiminy-billy-bob
            You're right, I can reproduce this.
            • Bob JamesB Offline
              Bob James
              @huckrorick said:
              Re:
              Your logic has changed my mind: I agree with you 100%. πŸ˜„
                Stephen Roberts
                Can't use it on my system - bugsplats every single time I try a drawing. I'm going to try disabling other plugins till I find out which one is causing the problem. If I find an answer I will feed it back. Looks very promising and I hope it can be kept....
                • tt_suT Offline
                  tt_su
                  Is your forum profile up to date? You are using Windows (what version) with SketchUp 8?
                    davecoopstl
                    This is a fantastic plugin! Thanks for all the hard work.
                    Any chance you could make it so that when I use the Hide Dialogs function in SketchUp, your Layers Panel is included in the Dialog Boxes that hide/unhide??
                    That would be super-handy. Especially since I have Hide Dialogs assigned to a Shortcut Key and, right now, they all hide except for your Layers Panel.
                    Just a suggestion.
                    Dave.
                      jiminy-billy-bob
                      As far as I know, the API doesn't allow this.
                        jiminy-billy-bob
                        @wind-borne said:
                        @jiminy-billy-bob said:
                        @wind-borne said:
                        Suggestion:
                        You might want to enlarge icon for use in main toolbar, barely discernible as shown on top shot.
                        Do you have a retina screen ?
                        Could you test the attached plugin and tell me if it has the same problem ? (The icon should be the same as Layers Panel)
                        jbb_toolbar_test.rbz
                        • wind-borneW Offline
                          wind-borne
                          same result, small in main
                          floating ok sized yet do not want auto loading
                          "To read between the lines was easier than to follow the text."OSX 10.11.6
                          %(#BF80BF)[SU 8 pro
                            jiminy-billy-bob
                            Great, thanks. I needed to know this snippet has the issue before filling a bug report.
                              I never knew this tread had added a poll?
                              Nice to see Thea getting some attention
                                jiminy-billy-bob
                                Yeah it's been some time now πŸ˜„
                                  jiminy-billy-bob
                                  New version 0.9.1 beta !
                                  Changelog :
                                  • Fixed options dialog on OSX
                                  • Disabled automatic display of floating toolbar on OSX
                                  • Fixed "Add layer hidden on new pages"
                                  • Fixed clash with RichSections plugin
                                  • Several bug fixes
                                  Download in the plugin store !
                                    paolo01
                                    Just installed and the plugin is very useful, to keep layers in order. It is really excellent! Thank you!
                                    If I can suggest a new function, it might be useful to have the possibility to duplicate the position of a single layer in different groups. For instance, in a building with many stores, I could have the layer "external walls store2" within the group "store2", but also within the group "external walls", containing all the external walls of any store .
                                    I think it could be possible to reach a similar result using layers and outliner together, but using a single panel would make the function of visibility much simpler.
                                    Thank you again and good job!
                                    Paolo
                                      jiminy-billy-bob
                                      I think it would be rather confusing to have duplicates of the same layer. I've never seen such thing in any software, and I think there is a reason for that.
                                      Although, I was considering adding a function similar to layer compositions in Photoshop.
                                        wind-borne
                                        Changelog :
                                        Thanks for saving me the trouble to deal with toolbar with each update. πŸ˜„
                                        Options dialog still dysfunctional on my OSX,
                                        reverts to this setup regardless of my choices
                                        %(#BF80BF)[SU 8 pro
                                          jiminy-billy-bob
                                          So you confirm you're running SU8 pro on OSX 10.9.1 ?
                                          Do you see the effects of changing these options ? (Like if you uncheck "Display render toolbar")
                                            rafaelparedes
                                            no add a layer only visible in the current scene 😞?
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 33
                                            • 34
                                            • 17 / 34
