    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 286.8k Views 110 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      Can you try with all the other plugins disabled ?
      • wind-borneW Offline
        wind-borne
        @jiminy-billy-bob said:
        It's here guys ! πŸ˜„
        New version 0.9 beta !
        Changelog :
        • OSX support
        • Fixed clicking on layer's name not selecting it
        Download in the plugin store !
        A huge thanks to TT for the OSX support ! πŸ‘ πŸ‘
        It's the first OSX version, so it still has bugs. We need you to find them πŸ˜‰
        Glad to join in.
        Enjoying the ability to group, merge and rearrange β˜€
        Problem:
        The options panel doesn't work for me.
        None of the changes take effect.
        Shown, reopening options(right) after setting(left).
        Tried reinstalling and tested on 2013 also, same no go.
        Annoyance:
        Upon closing, Save dialog appears even if no changes made on file with this extension enabled.
        For those of us using shortcuts or main toolbar, having floating toolbar automatically load. Deleted that line for now.
        Suggestion:
        You might want to enlarge icon for use in main toolbar, barely discernible as shown on top shot.
        OSX 10.9, Safari 7.0, SU 8
        Good luck and thanks again...
        "To read between the lines was easier than to follow the text."OSX 10.11.6
        %(#BF80BF)[SU 8 pro
          jiminy-billy-bob
          Thanks for your feedback ! πŸ˜‰
          @wind-borne said:
          Annoyance:
          I have to initialize some stuff, so there is no real workaround for the save dialog.
          As for the toolbar, can't you just hide it in the toolbars options ?
          • Bob JamesB Offline
            Bob James
            I have 188 rb files. I used SketchUcation Extensions Manager and was able to disable all the other extensions (that had no effect on the problem[s]). But SketchUcation Plugins Manager can only disable one plugin at a time. 😞 So disabling all of the rb files one at a time is not very desirable.
            What I will try is: disable my Plugins folder and make a dummy with just Layers Panel and whatever basic plugins are required.
              @Bob
              The SketchUcation Plugins Manager [and its other siblings - Extensions Manager and Plugins Uninstaller] will allow you to select multiple items in either column - Loaded/Enabled or Disabled - clicking and holding the Ctrl for individual items added to the selection or Shift key to add all up/down from the last one you selected [like any Windows app]...
              Then click the red > button to disable as desired.
              IF you made a named 'Set' [blue button] of the current Plugins set up... BEFORE doing major change... then you can easily revert to that named 'Set' on a later occasion...
              The Managers are there to ease the pain... you just need to restart SketchUp to see the changes... πŸ˜„
                jiminy-billy-bob
                Well that's what I was thinking.
                  jiminy-billy-bob
                  @wind-borne said:
                  Suggestion:
                  Do you have a retina screen ?
                    Bob James
                    @tig said:
                    @Bob
                    Thanks, TIG, that's what I did: I selected all of the plugins except Layers Panel using Shift Select and hit the disable button. They all went to the disabled side. I restarted SU and only the first plugin was shown in the disable column. I tried more than once because that's how I disabled all of the extensions in the Extension Manager.
                    Neat idea πŸ‘
                    If I make a named set containing all of my plugins and another containing only Layers Panel, if I turn off the "everything" set and turn on the LP set will SU think Plugins contains only LP?
                      Bob James
                      It auto-updates the layer state of the current scene.
                      If you turn on or off a layer, it's saved in the scene.
                      Isn't that what I would want to happen??
                        Bob James
                        Did fresh install of everything and the problem went away except for one model. I turned off all the layers and had no problem so I added one of the 40-or-so layers at a time and found one of the layers was causing the LP open/close error. Weird πŸ˜•
                        All seems to be well here at home. When I get to work I'll see how it goes there.
                          jiminy-billy-bob
                          It depends ^^
                          Option disabled : Default Sketchup behaviour => Manual update
                          Option enabled : Automatic update
                          Could you send me the problematic file ?
                            wind-borne
                            @wind-borne said:
                            Suggestion:
                            No, here is a shot of your icon surrounded by others in the customize toolbar window.
                            %(#BF80BF)[SU 8 pro
                              wind-borne
                              As far as I am aware manipulating the code is the only way. There have been many threads about toolbar management on OSX concerning automatically displaying toolbars every time SU is opened.
                              %(#BF80BF)[SU 8 pro
                              • HornOxxH Offline
                                HornOxx
                                wow - what a great plugin - thank you so much!
                                I work a lot with the Adobe bundle and I'm really not a fan of it - but one thing I love as well, namely the layer management. So I am very happy with your plugin. Just the possibility with the typical Adobe ALT shortcut is great or even the possibility to work with layer groups. So far, your plugin works without error (SKUP 8 with Win7/64Bit).
                                One thing I still do not understand: The use or the possibilities of the locksmbol here - does the lock prevent of deleting a layers or should it lock the layers content as well?
                                I would appreciate a note about this question...
                                Once again many thanks for this great plugin
                                • you deserve a place in the SKUP Olymp ! πŸ˜„)
                                never trust a skinny cook
                                • H Offline
                                  huckrorick
                                  Re:
                                  "It auto-updates the layer state of the current scene.
                                  Isn't that what I would want to happen??"
                                  From my use I would not want that to happen. When I open a scene I frequently want to turn on and off other layers while I'm examining the model. I do not want those changes automatically made to the scene. If I want the changes, then I click "update". It would be VERY inconvenient for my use to have every layer I turn on or off added to the scene.
                                    rafaelparedes
                                    the option add a layer only visible in the current scene just add a hidden layer to all scenes,its not visible in the current scene.
                                    anyone else having this issue?
                                      jiminy-billy-bob
                                      This is weird. It displays fine on windows. Anyone else having this issue on mac ?
                                      Ho ok, I thought it worked the same as windows.
                                      You're right, I need to write some doc to explain everything.
                                      The locking feature only prevent layers to be deleted or purged, but only from within Layers Panel. If you try to delete or purge them from the default layers window, they'll still be removed.
                                      And thanks, I really appreciate your kind words πŸ˜„
                                        jiminy-billy-bob
                                        You're right, I can reproduce this.
                                          Bob James
                                          @huckrorick said:
                                          Re:
                                          Your logic has changed my mind: I agree with you 100%. πŸ˜„
                                            Stephen Roberts
                                            Can't use it on my system - bugsplats every single time I try a drawing. I'm going to try disabling other plugins till I find out which one is causing the problem. If I find an answer I will feed it back. Looks very promising and I hope it can be kept....
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 33
                                            • 34
                                            • 17 / 34
