    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 916.8k Views 155 Watching
    • fredo6F Offline
      Fredo6
      Well sir, I installed your plugin for V 2013. Noticed that the icons, looked a little large. I discovered that all the png files listed as 16 x 16 were actually 24 x24. Not sure if you intended this or the sizes were not changed.
      I changed all my 16 x16 listed, to actual 16 x16 from the 24 x 24, and now they look like the rest of the icon on the toolbar.
      Ken
      Ken,
      You are right: icons are 24x24 and 32x32 for the big ones.
      However, due to ancient code in LibFredo6, I had kept the old naming conventions _16 and _24 for compatibility with earlier versions of SU. I may change it to _small and _large at a later stage, but this is some work to keep compatibility.
      In SU8 and earlier, the icons are: small = 16x16, large = 24x24. However, SU will anyway rescale the image whatever size it is.
      In SU13, the icons are: small = 24x24, large = 32x32. SU13 does not resize the icons images.
      Personally I find that bigger icons offer a better readibility while still fitting in the square allocated in the toolbar.
      Currently, there's nothing I can do immediately for two reasons:
      • I need to ask Daniel S. a version of the icons in 16x16
      • I need to offer the option for the user to choose between small (16x16) and less small (24x24), as we'll probably find users liking one or the other option.
      • kenK Offline
        ken
        Fredo6
        It wasn't a problem, I just notice the icons were larger. I have a 1920x1080 display and the icons just didn't look good. Me, I just went in and changed the size. I wasn't sure if you intended this, or you make a mistake in coping the files.
        I just giving you a heads up.
        Thanks for you reply and your work. Not sure where you live, but Boulder is beautiful and a great place to live, hint, hint.
        Ken
        • H Offline
          hebeijianke
          There are two strings cannt be translated
          Processing time = %1s
          Time calculation =
          • fredo6F Offline
            Time calculation =
            There may be a problem with the = sign.
            So just use : instead for the time being
              Effectively Tapering negative gives some funny results! 😄
              • bagateloB Offline
                bagatelo
                Very good job! Thanks!
                And about to make the object like before the operation by this plug in? Will be great...
                • fredo6F Offline
                  NEW RELEASE: JointPush Pull Interactive v3.0h - 29 Oct 13
                  JointPushPull Interactive 3.0h is a minor release fixing a few problems and adjustments
                  • OxerO Offline
                    Oxer
                    Thanks you very much!! 😍
                    I needed some of new features. I have created the new spanish (Spain) language file
                    Spanish (Spain) Language File
                    • mitcorbM Offline
                      mitcorb
                      Salutations Fredo:
                      I like your new version. However, I will not download until I can make a donation.
                      • LAGRARI2012L Offline
                        LAGRARI2012
                        Thanks you very much 👍
                          BruceG
                          Doesn't seem to work in my Windows 8.1 machine. Previous push/pull still works fine. It will highlight sections but not select more than one or if one is selected it will not extrude. Anyone else with this problem?
                          • chonC Offline
                            chon
                            Hello,
                            i've got similar problems. No extrusion on selected faces, but the plugin works on groups/components when they are closed and so, all the faces of the group/component will be extruded and not only those who i would like to. That's a good new fonction but not in any case... 😉
                            Fredo ? Any help ? 💚
                            • fredo6F Offline
                              NEW RELEASE: JointPush Pull Interactive v3.1a - 27 Nov 13
                              JointPushPull Interactive 3.1a is a release for future Sketchup compatibility.
                              • blackquodB Offline
                                blackquod
                                Try running sketchup.exe in compatibility mode for Windows 7/8. It worked for me.
                                  kaas
                                  any chance you know whats causing this error?
                                  Date: 11-Dec-13 15:01:48
                                  An error occured in Joint Push Pull
                                  Error in Analysis of model
                                  undefined method `entityID' for nil:NilClass
                                  JointPushPullAlgo.rb: 377 -- algo_analyze_groupings
                                  JointPushPullAlgo.rb: 489 -- algo_prepare_calculation_exec
                                  JointPushPullAlgo.rb: 476 -- algo_prepare_calculation
                                  JointPushPullTool.rb: 892 -- modify_preparation
                                  JointPushPullTool.rb: 910 -- modify_execute
                                  JointPushPullTool.rb: 931 -- modify_offset
                                  JointPushPullTool.rb: 1128 -- execute_validate
                                  JointPushPullTool.rb: 1327 -- onReturn
                                  • fredo6F Offline
                                    It's a small bug when
                                    • you do a first Push pull
                                    • then you press Return, whereas there is no face selected
                                    I'll fix it in a next release
                                      does this is possible or I miss something ?
                                      (i have not tested with the new version)
                                      JPPv6.skp
                                        It worked for me, Pilou. You should try it.
                                          With the old version the best was that! 😲
                                          Cool now with this new version that is working as wished! 👍
                                            rekin0
                                            Thanks a lot!
                                            • 30
                                            • 31
                                            • 2 / 31
