    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 950.9k Views 155 Watching
    • massimoM
      massimo Moderator
      Thanks Fredo I'll try it for sure. πŸ‘
      Pilou,
      This was a special gift for you...
      πŸ˜†
        Many Thanks! πŸ’š
        As soon as some free times I will explore these new infinite possibilities! (Smart) 😎
        Ce tableau inestimable est pour vous! πŸ˜„
        Renderiza Γ  la subdivision, Chris Fullmer Γ  la peinture et Fredo6 Γ  la randomisation! πŸ˜‰ β˜€
        Ps I have made some publicity of it over the 3D world forums! πŸ˜›
          alpro
          Amazing!, thank you!!
          • cottyC
            cotty
            If you think you know those tools, you should look in the 39 pages PDF documentation and I bet you will find something new to learn 😎
            examples:
            • random push pull
            • tapering
            my SketchUp gallery
              dtrarch
              Hi Fredo
              Thank you for the JPP update. πŸ‘ πŸ‘ πŸ‘
              Just super and a well deserved cookie on its way. πŸ˜„
              Sure wish your contribute was in English but thanks for fixing the entry.
              You are not only generous but honest too. πŸ‘ πŸ‘ πŸ‘ πŸ‘
              dtr
              • kenK
                ken
                Fredo6
                Well sir, I installed your plugin for V 2013. Noticed that the icons, looked a little large. I discovered that all the png files listed as 16 x 16 were actually 24 x24. Not sure if you intended this or the sizes were not changed.
                I changed all my 16 x16 listed, to actual 16 x16 from the 24 x 24, and now they look like the rest of the icon on the toolbar.
                Ken
                • fredo6F
                  Fredo6
                  Ken
                  Ken,
                  You are right: icons are 24x24 and 32x32 for the big ones.
                  However, due to ancient code in LibFredo6, I had kept the old naming conventions _16 and _24 for compatibility with earlier versions of SU. I may change it to _small and _large at a later stage, but this is some work to keep compatibility.
                  In SU8 and earlier, the icons are: small = 16x16, large = 24x24. However, SU will anyway rescale the image whatever size it is.
                  In SU13, the icons are: small = 24x24, large = 32x32. SU13 does not resize the icons images.
                  Personally I find that bigger icons offer a better readibility while still fitting in the square allocated in the toolbar.
                  Currently, there's nothing I can do immediately for two reasons:
                  • I need to ask Daniel S. a version of the icons in 16x16
                  • I need to offer the option for the user to choose between small (16x16) and less small (24x24), as we'll probably find users liking one or the other option.
                  • kenK
                    ken
                    Fredo6
                    It wasn't a problem, I just notice the icons were larger. I have a 1920x1080 display and the icons just didn't look good. Me, I just went in and changed the size. I wasn't sure if you intended this, or you make a mistake in coping the files.
                    I just giving you a heads up.
                    Thanks for you reply and your work. Not sure where you live, but Boulder is beautiful and a great place to live, hint, hint.
                    Ken
                    • H
                      hebeijianke
                      There are two strings cannt be translated
                      Processing time = %1s
                      Time calculation =
                      • fredo6F
                        Time calculation =
                        There may be a problem with the = sign.
                        So just use : instead for the time being
                          Effectively Tapering negative gives some funny results! πŸ˜„
                          • bagateloB
                            bagatelo
                            Very good job! Thanks!
                            And about to make the object like before the operation by this plug in? Will be great...
                            • fredo6F
                              NEW RELEASE: JointPush Pull Interactive v3.0h - 29 Oct 13
                              JointPushPull Interactive 3.0h is a minor release fixing a few problems and adjustments
                              • OxerO
                                Oxer
                                Thanks you very much!! 😍
                                I needed some of new features. I have created the new spanish (Spain) language file
                                Spanish (Spain) Language File
                                • mitcorbM
                                  mitcorb
                                  Salutations Fredo:
                                  I like your new version. However, I will not download until I can make a donation.
                                  • LAGRARI2012L
                                    LAGRARI2012
                                    Thanks you very much πŸ‘
                                    • B
                                      BruceG
                                      Doesn't seem to work in my Windows 8.1 machine. Previous push/pull still works fine. It will highlight sections but not select more than one or if one is selected it will not extrude. Anyone else with this problem?
                                      • chonC
                                        chon
                                        Hello,
                                        i've got similar problems. No extrusion on selected faces, but the plugin works on groups/components when they are closed and so, all the faces of the group/component will be extruded and not only those who i would like to. That's a good new fonction but not in any case... πŸ˜‰
                                        Fredo ? Any help ? πŸ’š
                                        • fredo6F
                                          NEW RELEASE: JointPush Pull Interactive v3.1a - 27 Nov 13
                                          JointPushPull Interactive 3.1a is a release for future Sketchup compatibility.
                                          • blackquodB
                                            blackquod
                                            Try running sketchup.exe in compatibility mode for Windows 7/8. It worked for me.
                                            • 30
                                            • 31
                                            • 2 / 31
