    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • mitcorbM
      mitcorb
      Salutations Fredo:
      I like your new version. However, I will not download until I can make a donation.
      • LAGRARI2012L
        LAGRARI2012
        Thanks you very much ๐Ÿ‘
        • B
          BruceG
          Doesn't seem to work in my Windows 8.1 machine. Previous push/pull still works fine. It will highlight sections but not select more than one or if one is selected it will not extrude. Anyone else with this problem?
          • chonC
            chon
            Hello,
            i've got similar problems. No extrusion on selected faces, but the plugin works on groups/components when they are closed and so, all the faces of the group/component will be extruded and not only those who i would like to. That's a good new fonction but not in any case... ๐Ÿ˜‰
            Fredo ? Any help ? ๐Ÿ’š
            SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
            • fredo6F
              NEW RELEASE: JointPush Pull Interactive v3.1a - 27 Nov 13
              JointPushPull Interactive 3.1a is a release for future Sketchup compatibility.
              • blackquodB
                blackquod
                Try running sketchup.exe in compatibility mode for Windows 7/8. It worked for me.
                • K
                  kaas
                  any chance you know whats causing this error?
                  Date: 11-Dec-13 15:01:48
                  An error occured in Joint Push Pull
                  Error in Analysis of model
                  undefined method `entityID' for nil:NilClass
                  JointPushPullAlgo.rb: 377 -- algo_analyze_groupings
                  JointPushPullAlgo.rb: 489 -- algo_prepare_calculation_exec
                  JointPushPullAlgo.rb: 476 -- algo_prepare_calculation
                  JointPushPullTool.rb: 892 -- modify_preparation
                  JointPushPullTool.rb: 910 -- modify_execute
                  JointPushPullTool.rb: 931 -- modify_offset
                  JointPushPullTool.rb: 1128 -- execute_validate
                  JointPushPullTool.rb: 1327 -- onReturn
                  • fredo6F
                    It's a small bug when
                    • you do a first Push pull
                    • then you press Return, whereas there is no face selected
                    I'll fix it in a next release
                      does this is possible or I miss something ?
                      (i have not tested with the new version)
                      JPPv6.skp
                        It worked for me, Pilou. You should try it.
                          With the old version the best was that! ๐Ÿ˜ฒ
                          Cool now with this new version that is working as wished! ๐Ÿ‘
                            rekin0
                            Thanks a lot!
                            • E
                              Elmer BeFuddled
                              Greetings!
                              I'm having a problem with trying to use this tool. When I open SU I get an error msg regarding LibFredo as below:
                              Error Loading File C;/Program Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_!LibFredo6/__loader.rb
                              (eval);1;in `effective_load_part2'; compile error
                              (eval);1; syntax error, unexpected tINTEGER, expecting ')'
                              ...Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_!LibFredo6', '...
                              (eval);1; syntax error, unexpected tCONSTANT, expecting kDO or '{' or '('
                              ... '13/Plugins/Fredo6_!LibFredo6', 'LibFredo6') ; MYDEFPARAM =...
                              (eval);1; syntax error, unexpected tCONSTANT, expecting kEND
                              ...Fredo6_!LibFredo6', 'LibFredo6') ; MYDEFPARAM = MYPLUGIN.cre...
                              ..._PLATFORM =~ /darwin/i) ? 'MAC' ; 'PC' ;RUN_ON_MAC = false ;...
                              ...RM =~ /darwin/i) ? 'MAC' ; 'PC' ;RUN_ON_MAC = false ;end
                              (eval);1; unterminated string meets end of file
                              (eval);1; syntax error, unexpected $end, expecting kEND
                              ... 'PC' ;RUN_ON_MAC = false ;end
                              Error Loading File C;/Program Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_ToolsOnSurface/__loader.rb
                              ...Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_ToolsOnSurface...
                              (eval);1; syntax error, unexpected tSTRING_BEG, expecting kDO or '{' or '('
                              ...Plugins/Fredo6_ToolsOnSurface', 'ToolsOnSurface') ; MYDEFPAR...
                              ...olsOnSurface', 'ToolsOnSurface') ; MYDEFPARAM = MYPLUGIN.cre...
                              I've just installed Ruby, as well, although not where it wants to go (in the root of C:. Nothing goes there unless Security logs!) Its been installed to the same sub-folder in Program Files as SketchUp.
                              Any hints or tips to help me?
                              On a good note (always leave 'em happy Elmer!!) I've just installed the bezier curve tool. What a little beauty!!
                              • cottyC
                                cotty
                                You should never use special characters in path names!
                                in your case: '13...
                                my SketchUp gallery
                                  Certainly special characters like รฉ or รถ will break the current version of Ruby that ships with SketchUp.
                                  The ' is a special case, because it breaks some Ruby and js when passed in a string that is 'raw'.
                                  The author can use " " to encapsulate Ruby string parts so the included ' is preserved.
                                  Or if the encapsulation is ' ' it must then be escaped - tr("'","'") for js use it's best perhaps as say tr("'","\\'") ...
                                  But for now please leave ' out of your path-names - there are many alternatives... ๐Ÿ˜’
                                  • N
                                    numerobis
                                    Almost two months online already... How could i miss this one?!? ๐Ÿ˜ฎ
                                    Unbelievable! You've done it again... Great improvement! ๐Ÿ˜Ž
                                    I'm not sure if the sketchup "developers" are still following what's going on with their software on plugin level... If i would be in their position i would really be ashamed...
                                    • E
                                      Elmer BeFuddled
                                      Right, I shall remove the offending "happy oz trophy" (which is a straight one, nothing oblique or fancy) from the SU file path.
                                      Its never affected any thing else when I abb. (tee hee!! ๐Ÿ˜‰ ) the date in the path name but I'll be honest, up until ten days ago I'd never heard of Ruby, heathen that I am!!
                                      A thought. A.N.Other plug-in, the SVG importer that required rexml (from Ruby) to be added into the plug-ins folder didn't work either, though I can't remember the error msg. I received.
                                      It may also be why I can't import *.dxf files from Inkscape that were made from a *.pdf files that were made in Photoshop from *.psd files that were made from thoughts in my single malt, whisky hazed mind!
                                      Back to the point, I'll update you with as to how things went.
                                      !!! HOT OFF THE PRESSES !!!
                                      An Update.
                                      Well, I re-installed SU to C:\Program Files (x86)\DEVELOP\SketchUp 13 and Ruby to C:\Program Files (x86)\DEVELOP\Ruby193 and voila!! Joint Push Pull and Tools on Surface both popped up their toolbars when I opened up SU.
                                      Who'd have thunked a little apostrophe could cause so much hassle!
                                      That would never of crossed my mind as I've been 'apostrophising' install paths and file names since Jesus left Kilmarnock (a.k.a a very long time) with no issues. Strange how the parenthesis as in (x86) get ignored!
                                      Still having problems with the svg importer (the error message shows one oblique and one straight comma) but I'll post about that in the correct place.
                                      Many many thanks to you cotty and TIG for your help. I'd have got nowhere without it.
                                      ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜
                                      Elmer
                                      • fredo6F
                                        NEW RELEASE: JointPush Pull Interactive v3.2a - 25 Jan 14
                                        JointPushPull Interactive 3.2a includes a Projected mode for Vector Push-Pull (see video).
                                        [flash=425,344:3hd996ii]http://www.youtube.com/v/qsKZpmrJkxs&hl[/flash:3hd996ii]
                                        • cottyC
                                          cotty
                                          One WOW! per day, a good average ๐Ÿ˜‰
                                          ๐Ÿ‘
                                          my SketchUp gallery
                                          • CadFatherC
                                            CadFather
                                            wow indeed, here's a scary thought... ..imagine life without Fredo6..... ๐Ÿ˜ฒ ๐Ÿ˜†
                                            • 30
                                            • 31
                                            • 2 / 31
