    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • fredo6F
      @hebeijianke said:
      There are two strings cannt be translated
      Processing time = %1s
      Time calculation =
      There may be a problem with the = sign.
      So just use : instead for the time being
        Effectively Tapering negative gives some funny results! 😄
        • bagateloB
          bagatelo
          Very good job! Thanks!
          And about to make the object like before the operation by this plug in? Will be great...
          • fredo6F
            NEW RELEASE: JointPush Pull Interactive v3.0h - 29 Oct 13
            JointPushPull Interactive 3.0h is a minor release fixing a few problems and adjustments
            • OxerO
              Oxer
              Thanks you very much!! 😍
              I needed some of new features. I have created the new spanish (Spain) language file
              Spanish (Spain) Language File
              • mitcorbM
                mitcorb
                Salutations Fredo:
                I like your new version. However, I will not download until I can make a donation.
                • LAGRARI2012L
                  LAGRARI2012
                  Thanks you very much 👍
                  • B
                    BruceG
                    Doesn't seem to work in my Windows 8.1 machine. Previous push/pull still works fine. It will highlight sections but not select more than one or if one is selected it will not extrude. Anyone else with this problem?
                    • chonC
                      chon
                      Hello,
                      i've got similar problems. No extrusion on selected faces, but the plugin works on groups/components when they are closed and so, all the faces of the group/component will be extruded and not only those who i would like to. That's a good new fonction but not in any case... 😉
                      Fredo ? Any help ? 💚
                      SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
                      • fredo6F
                        NEW RELEASE: JointPush Pull Interactive v3.1a - 27 Nov 13
                        JointPushPull Interactive 3.1a is a release for future Sketchup compatibility.
                        • blackquodB
                          blackquod
                          Try running sketchup.exe in compatibility mode for Windows 7/8. It worked for me.
                          • K
                            kaas
                            any chance you know whats causing this error?
                            Date: 11-Dec-13 15:01:48
                            An error occured in Joint Push Pull
                            Error in Analysis of model
                            undefined method `entityID' for nil:NilClass
                            JointPushPullAlgo.rb: 377 -- algo_analyze_groupings
                            JointPushPullAlgo.rb: 489 -- algo_prepare_calculation_exec
                            JointPushPullAlgo.rb: 476 -- algo_prepare_calculation
                            JointPushPullTool.rb: 892 -- modify_preparation
                            JointPushPullTool.rb: 910 -- modify_execute
                            JointPushPullTool.rb: 931 -- modify_offset
                            JointPushPullTool.rb: 1128 -- execute_validate
                            JointPushPullTool.rb: 1327 -- onReturn
                            • fredo6F
                              It's a small bug when
                              • you do a first Push pull
                              • then you press Return, whereas there is no face selected
                              I'll fix it in a next release
                                does this is possible or I miss something ?
                                (i have not tested with the new version)
                                JPPv6.skp
                                  It worked for me, Pilou. You should try it.
                                    With the old version the best was that! 😲
                                    Cool now with this new version that is working as wished! 👍
                                      rekin0
                                      Thanks a lot!
                                      • E
                                        Elmer BeFuddled
                                        Greetings!
                                        I'm having a problem with trying to use this tool. When I open SU I get an error msg regarding LibFredo as below:
                                        Error Loading File C;/Program Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_!LibFredo6/__loader.rb
                                        (eval);1;in `effective_load_part2'; compile error
                                        (eval);1; syntax error, unexpected tINTEGER, expecting ')'
                                        ...Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_!LibFredo6', '...
                                        (eval);1; syntax error, unexpected tCONSTANT, expecting kDO or '{' or '('
                                        ... '13/Plugins/Fredo6_!LibFredo6', 'LibFredo6') ; MYDEFPARAM =...
                                        (eval);1; syntax error, unexpected tCONSTANT, expecting kEND
                                        ...Fredo6_!LibFredo6', 'LibFredo6') ; MYDEFPARAM = MYPLUGIN.cre...
                                        ..._PLATFORM =~ /darwin/i) ? 'MAC' ; 'PC' ;RUN_ON_MAC = false ;...
                                        ...RM =~ /darwin/i) ? 'MAC' ; 'PC' ;RUN_ON_MAC = false ;end
                                        (eval);1; unterminated string meets end of file
                                        (eval);1; syntax error, unexpected $end, expecting kEND
                                        ... 'PC' ;RUN_ON_MAC = false ;end
                                        Error Loading File C;/Program Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_ToolsOnSurface/__loader.rb
                                        ...Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_ToolsOnSurface...
                                        (eval);1; syntax error, unexpected tSTRING_BEG, expecting kDO or '{' or '('
                                        ...Plugins/Fredo6_ToolsOnSurface', 'ToolsOnSurface') ; MYDEFPAR...
                                        ...olsOnSurface', 'ToolsOnSurface') ; MYDEFPARAM = MYPLUGIN.cre...
                                        I've just installed Ruby, as well, although not where it wants to go (in the root of C:. Nothing goes there unless Security logs!) Its been installed to the same sub-folder in Program Files as SketchUp.
                                        Any hints or tips to help me?
                                        On a good note (always leave 'em happy Elmer!!) I've just installed the bezier curve tool. What a little beauty!!
                                        • cottyC
                                          cotty
                                          You should never use special characters in path names!
                                          in your case: '13...
                                          my SketchUp gallery
                                            Certainly special characters like é or ö will break the current version of Ruby that ships with SketchUp.
                                            The ' is a special case, because it breaks some Ruby and js when passed in a string that is 'raw'.
                                            The author can use " " to encapsulate Ruby string parts so the included ' is preserved.
                                            Or if the encapsulation is ' ' it must then be escaped - tr("'","'") for js use it's best perhaps as say tr("'","\\'") ...
                                            But for now please leave ' out of your path-names - there are many alternatives... 😒
                                            • 30
                                            • 31
                                            • 2 / 31
