    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 916.8k Views 155 Watching
      The new hit for sure ! πŸ‘ 😎
      Random functions are crazzy! 😲
      • fredo6F Offline
        Pilou,
        This was a special gift for you. I am sure you'll complement it with the Tapering feature to produce some inspiring modern art masterpiece.
        And I am also sure that you'll ask right away for random colorization! πŸ˜†
          Ben Ritter
          A big thank you. You are very talented, and generous.
          • massimoM Offline
            massimo Moderator
            Thanks Fredo I'll try it for sure. πŸ‘
            Pilou,
            This was a special gift for you...
            πŸ˜†
              Many Thanks! πŸ’š
              As soon as some free times I will explore these new infinite possibilities! (Smart) 😎
              Ce tableau inestimable est pour vous! πŸ˜„
              Renderiza Γ  la subdivision, Chris Fullmer Γ  la peinture et Fredo6 Γ  la randomisation! πŸ˜‰ β˜€
              Ps I have made some publicity of it over the 3D world forums! πŸ˜›
                alpro
                Amazing!, thank you!!
                • cottyC Offline
                  cotty
                  If you think you know those tools, you should look in the 39 pages PDF documentation and I bet you will find something new to learn 😎
                  examples:
                  • random push pull
                  • tapering
                  my SketchUp gallery
                    dtrarch
                    Hi Fredo
                    Thank you for the JPP update. πŸ‘ πŸ‘ πŸ‘
                    Just super and a well deserved cookie on its way. πŸ˜„
                    Sure wish your contribute was in English but thanks for fixing the entry.
                    You are not only generous but honest too. πŸ‘ πŸ‘ πŸ‘ πŸ‘
                    dtr
                    • kenK Offline
                      ken
                      Fredo6
                      Well sir, I installed your plugin for V 2013. Noticed that the icons, looked a little large. I discovered that all the png files listed as 16 x 16 were actually 24 x24. Not sure if you intended this or the sizes were not changed.
                      I changed all my 16 x16 listed, to actual 16 x16 from the 24 x 24, and now they look like the rest of the icon on the toolbar.
                      Ken
                      • fredo6F Offline
                        Fredo6
                        Ken
                        Ken,
                        You are right: icons are 24x24 and 32x32 for the big ones.
                        However, due to ancient code in LibFredo6, I had kept the old naming conventions _16 and _24 for compatibility with earlier versions of SU. I may change it to _small and _large at a later stage, but this is some work to keep compatibility.
                        In SU8 and earlier, the icons are: small = 16x16, large = 24x24. However, SU will anyway rescale the image whatever size it is.
                        In SU13, the icons are: small = 24x24, large = 32x32. SU13 does not resize the icons images.
                        Personally I find that bigger icons offer a better readibility while still fitting in the square allocated in the toolbar.
                        Currently, there's nothing I can do immediately for two reasons:
                        • I need to ask Daniel S. a version of the icons in 16x16
                        • I need to offer the option for the user to choose between small (16x16) and less small (24x24), as we'll probably find users liking one or the other option.
                        • kenK Offline
                          ken
                          Fredo6
                          It wasn't a problem, I just notice the icons were larger. I have a 1920x1080 display and the icons just didn't look good. Me, I just went in and changed the size. I wasn't sure if you intended this, or you make a mistake in coping the files.
                          I just giving you a heads up.
                          Thanks for you reply and your work. Not sure where you live, but Boulder is beautiful and a great place to live, hint, hint.
                          Ken
                          • H Offline
                            hebeijianke
                            There are two strings cannt be translated
                            Processing time = %1s
                            Time calculation =
                            • fredo6F Offline
                              Time calculation =
                              There may be a problem with the = sign.
                              So just use : instead for the time being
                                Effectively Tapering negative gives some funny results! πŸ˜„
                                • bagateloB Offline
                                  bagatelo
                                  Very good job! Thanks!
                                  And about to make the object like before the operation by this plug in? Will be great...
                                  • fredo6F Offline
                                    NEW RELEASE: JointPush Pull Interactive v3.0h - 29 Oct 13
                                    JointPushPull Interactive 3.0h is a minor release fixing a few problems and adjustments
                                    • OxerO Offline
                                      Oxer
                                      Thanks you very much!! 😍
                                      I needed some of new features. I have created the new spanish (Spain) language file
                                      Spanish (Spain) Language File
                                      • mitcorbM Offline
                                        mitcorb
                                        Salutations Fredo:
                                        I like your new version. However, I will not download until I can make a donation.
                                        • LAGRARI2012L Offline
                                          LAGRARI2012
                                          Thanks you very much πŸ‘
                                            BruceG
                                            Doesn't seem to work in my Windows 8.1 machine. Previous push/pull still works fine. It will highlight sections but not select more than one or if one is selected it will not extrude. Anyone else with this problem?
                                            • 30
                                            • 31
                                            • 1 / 31
