    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 950.9k Views 155 Watching
      dtrarch
      Hi Fredo
      Thank you for the JPP update. πŸ‘ πŸ‘ πŸ‘
      Just super and a well deserved cookie on its way. πŸ˜„
      Sure wish your contribute was in English but thanks for fixing the entry.
      You are not only generous but honest too. πŸ‘ πŸ‘ πŸ‘ πŸ‘
      dtr
      • kenK
        ken
        Fredo6
        Well sir, I installed your plugin for V 2013. Noticed that the icons, looked a little large. I discovered that all the png files listed as 16 x 16 were actually 24 x24. Not sure if you intended this or the sizes were not changed.
        I changed all my 16 x16 listed, to actual 16 x16 from the 24 x 24, and now they look like the rest of the icon on the toolbar.
        Ken
        • fredo6F
          Fredo6
          Ken
          Ken,
          You are right: icons are 24x24 and 32x32 for the big ones.
          However, due to ancient code in LibFredo6, I had kept the old naming conventions _16 and _24 for compatibility with earlier versions of SU. I may change it to _small and _large at a later stage, but this is some work to keep compatibility.
          In SU8 and earlier, the icons are: small = 16x16, large = 24x24. However, SU will anyway rescale the image whatever size it is.
          In SU13, the icons are: small = 24x24, large = 32x32. SU13 does not resize the icons images.
          Personally I find that bigger icons offer a better readibility while still fitting in the square allocated in the toolbar.
          Currently, there's nothing I can do immediately for two reasons:
          • I need to ask Daniel S. a version of the icons in 16x16
          • I need to offer the option for the user to choose between small (16x16) and less small (24x24), as we'll probably find users liking one or the other option.
          • kenK
            ken
            Fredo6
            It wasn't a problem, I just notice the icons were larger. I have a 1920x1080 display and the icons just didn't look good. Me, I just went in and changed the size. I wasn't sure if you intended this, or you make a mistake in coping the files.
            I just giving you a heads up.
            Thanks for you reply and your work. Not sure where you live, but Boulder is beautiful and a great place to live, hint, hint.
            Ken
            • H
              hebeijianke
              There are two strings cannt be translated
              Processing time = %1s
              Time calculation =
              • fredo6F
                Time calculation =
                There may be a problem with the = sign.
                So just use : instead for the time being
                  Effectively Tapering negative gives some funny results! πŸ˜„
                  • bagateloB
                    bagatelo
                    Very good job! Thanks!
                    And about to make the object like before the operation by this plug in? Will be great...
                    • fredo6F
                      NEW RELEASE: JointPush Pull Interactive v3.0h - 29 Oct 13
                      JointPushPull Interactive 3.0h is a minor release fixing a few problems and adjustments
                      • OxerO
                        Oxer
                        Thanks you very much!! 😍
                        I needed some of new features. I have created the new spanish (Spain) language file
                        Spanish (Spain) Language File
                        • mitcorbM
                          mitcorb
                          Salutations Fredo:
                          I like your new version. However, I will not download until I can make a donation.
                          • LAGRARI2012L
                            LAGRARI2012
                            Thanks you very much πŸ‘
                            • B
                              BruceG
                              Doesn't seem to work in my Windows 8.1 machine. Previous push/pull still works fine. It will highlight sections but not select more than one or if one is selected it will not extrude. Anyone else with this problem?
                              • chonC
                                chon
                                Hello,
                                i've got similar problems. No extrusion on selected faces, but the plugin works on groups/components when they are closed and so, all the faces of the group/component will be extruded and not only those who i would like to. That's a good new fonction but not in any case... πŸ˜‰
                                Fredo ? Any help ? πŸ’š
                                • fredo6F
                                  NEW RELEASE: JointPush Pull Interactive v3.1a - 27 Nov 13
                                  JointPushPull Interactive 3.1a is a release for future Sketchup compatibility.
                                  • blackquodB
                                    blackquod
                                    Try running sketchup.exe in compatibility mode for Windows 7/8. It worked for me.
                                    • K
                                      kaas
                                      any chance you know whats causing this error?
                                      Date: 11-Dec-13 15:01:48
                                      An error occured in Joint Push Pull
                                      Error in Analysis of model
                                      undefined method `entityID' for nil:NilClass
                                      JointPushPullAlgo.rb: 377 -- algo_analyze_groupings
                                      JointPushPullAlgo.rb: 489 -- algo_prepare_calculation_exec
                                      JointPushPullAlgo.rb: 476 -- algo_prepare_calculation
                                      JointPushPullTool.rb: 892 -- modify_preparation
                                      JointPushPullTool.rb: 910 -- modify_execute
                                      JointPushPullTool.rb: 931 -- modify_offset
                                      JointPushPullTool.rb: 1128 -- execute_validate
                                      JointPushPullTool.rb: 1327 -- onReturn
                                      • fredo6F
                                        It's a small bug when
                                        • you do a first Push pull
                                        • then you press Return, whereas there is no face selected
                                        I'll fix it in a next release
                                          does this is possible or I miss something ?
                                          (i have not tested with the new version)
                                          JPPv6.skp
                                            It worked for me, Pilou. You should try it.
                                            • 30
                                            • 31
                                            • 2 / 31
