    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • cottyC
      cotty
      Some hours online and over 4000 downloads, wow! πŸ˜‰
      Great(er) as always! Love the new tools "round" and "Follow"!
      Don't forget the donation button, it is in the plugin store πŸ‘
      my SketchUp gallery
      • guanjinG
        guanjin
        Potenca kombino de iloj。
        Dankon Fredo!
        πŸ‘ πŸ‘ πŸ‘
        • H
          hebeijianke
          Chinese language
          JointPushPull_ZH.lang
          • sicksickisckS
            sicksickisck
            this is worth money, more than most of scripts on .smustard dot com
            • rami_lpmR
              rami_lpm
              Thanks a lot!
                The new hit for sure ! πŸ‘ 😎
                Random functions are crazzy! 😲
                • fredo6F
                  Pilou,
                  This was a special gift for you. I am sure you'll complement it with the Tapering feature to produce some inspiring modern art masterpiece.
                  And I am also sure that you'll ask right away for random colorization! πŸ˜†
                  • B
                    Ben Ritter
                    A big thank you. You are very talented, and generous.
                    • massimoM
                      massimo Moderator
                      Thanks Fredo I'll try it for sure. πŸ‘
                      Pilou,
                      This was a special gift for you...
                      πŸ˜†
                        Many Thanks! πŸ’š
                        As soon as some free times I will explore these new infinite possibilities! (Smart) 😎
                        Ce tableau inestimable est pour vous! πŸ˜„
                        Renderiza Γ  la subdivision, Chris Fullmer Γ  la peinture et Fredo6 Γ  la randomisation! πŸ˜‰ β˜€
                        Ps I have made some publicity of it over the 3D world forums! πŸ˜›
                          alpro
                          Amazing!, thank you!!
                          • cottyC
                            cotty
                            If you think you know those tools, you should look in the 39 pages PDF documentation and I bet you will find something new to learn 😎
                            examples:
                            • random push pull
                            • tapering
                            my SketchUp gallery
                              dtrarch
                              Hi Fredo
                              Thank you for the JPP update. πŸ‘ πŸ‘ πŸ‘
                              Just super and a well deserved cookie on its way. πŸ˜„
                              Sure wish your contribute was in English but thanks for fixing the entry.
                              You are not only generous but honest too. πŸ‘ πŸ‘ πŸ‘ πŸ‘
                              dtr
                              • kenK
                                ken
                                Fredo6
                                Well sir, I installed your plugin for V 2013. Noticed that the icons, looked a little large. I discovered that all the png files listed as 16 x 16 were actually 24 x24. Not sure if you intended this or the sizes were not changed.
                                I changed all my 16 x16 listed, to actual 16 x16 from the 24 x 24, and now they look like the rest of the icon on the toolbar.
                                Ken
                                • fredo6F
                                  Fredo6
                                  Ken
                                  Ken,
                                  You are right: icons are 24x24 and 32x32 for the big ones.
                                  However, due to ancient code in LibFredo6, I had kept the old naming conventions _16 and _24 for compatibility with earlier versions of SU. I may change it to _small and _large at a later stage, but this is some work to keep compatibility.
                                  In SU8 and earlier, the icons are: small = 16x16, large = 24x24. However, SU will anyway rescale the image whatever size it is.
                                  In SU13, the icons are: small = 24x24, large = 32x32. SU13 does not resize the icons images.
                                  Personally I find that bigger icons offer a better readibility while still fitting in the square allocated in the toolbar.
                                  Currently, there's nothing I can do immediately for two reasons:
                                  • I need to ask Daniel S. a version of the icons in 16x16
                                  • I need to offer the option for the user to choose between small (16x16) and less small (24x24), as we'll probably find users liking one or the other option.
                                  • kenK
                                    ken
                                    Fredo6
                                    It wasn't a problem, I just notice the icons were larger. I have a 1920x1080 display and the icons just didn't look good. Me, I just went in and changed the size. I wasn't sure if you intended this, or you make a mistake in coping the files.
                                    I just giving you a heads up.
                                    Thanks for you reply and your work. Not sure where you live, but Boulder is beautiful and a great place to live, hint, hint.
                                    Ken
                                    • H
                                      hebeijianke
                                      There are two strings cannt be translated
                                      Processing time = %1s
                                      Time calculation =
                                      • fredo6F
                                        Time calculation =
                                        There may be a problem with the = sign.
                                        So just use : instead for the time being
                                          Effectively Tapering negative gives some funny results! πŸ˜„
                                          • bagateloB
                                            bagatelo
                                            Very good job! Thanks!
                                            And about to make the object like before the operation by this plug in? Will be great...
                                            • 30
                                            • 31
                                            • 1 / 31
