    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 237.5k Views 51 Watching
      I just downloaded and installed it and it works for me on SU2013. Perhaps you have some other plugin that is causing the conflict. Do you have the Vray or Podium plugins? You might try disabling other plugins and see if this one will run for you.
        samyell77
        Thanks DaveR, will try disabling some plugins and see. Hadn't thought of that - DOH!
        SU Pro 2016
        Dell Precision M4800
        PC Windows 10
        Intel Core i7-4900MQ @ 2.80ghz
        Nvidia Quadro K2100M
        16gb RAM
          SketchyPhysics is also a big pertubator! ๐Ÿ˜‰
            samyell77
            Hi All,
            Have tried to disable everything except Eclate Deplace and it STILL crashes? Anyone got any thoughts. Im stumped and seeing as I use this plugin almost daily am pulling my hair out.
            Any help greatly appreciated as always....
            Not sure what other plugins need to run with Eclate Deplace so not sure if there is anythign that has to be on to allow it to work.
            Sam
            SU Pro 2016
            PC Windows 10
            16gb RAM
            • BoxB Offline
              Perhaps there is something wrong with the model, or does it happen with all?
                samyell77
                Yes - tried to draw 3 boxes in a new model and run the plugin and it crashed?
                Stumped....
                SU Pro 2016
                PC Windows 10
                16gb RAM
                • BoxB Offline
                  Just tested and it's working fine here on 7,8 and 13.
                  Have you changed anything recently, graphic card/driver, windows version/update , any new hardware..etc etc... you might need to track back to what you did before it started to crash.
                    samyell77
                    Installed a new graphics card recently but a colleague of mine has the same machine and had the same card installed at the same time and no problems.
                    Have removed all plugins from my plugins folder and installed only eclate deplace and still getting crashes every time... Arrrrrgh!
                    Going to have to make exploded diagrams manually for now.....
                    SU Pro 2016
                    PC Windows 10
                    16gb RAM
                    • BoxB Offline
                      Have you tried changing the opengl settings, sometimes just turning hardware acceleration off or on fixes things and it can often be switched back after.
                        samyell77
                        Thanks Box - tried and no joy Im afraid. Think its an issue with a graphics card. Going to sort it next week some time (hopefully)...
                        Cheers
                        Sam
                        SU Pro 2016
                        PC Windows 10
                        16gb RAM
                          samyell77
                          Have found a work around for this but still not got to the bottom of it. SU crashes pretty consistently if I run Eclate Deplace and have the outliner window open? So have been making sure I save, collapse the outliner window, open radial move first and then run eclate deplace. This seems to avoid the crashes but have no idea why...
                          SU Pro 2016
                          PC Windows 10
                          16gb RAM
                            Maybe you can also try to run it with it alone inside the Plugins folder for see if there is no compatibility with an another plugin!
                              It has been a know problem with SketchUp that having the Outliner open and 'rolled-down' when running ANY processes that require intensive/multiple creation/changes to groups/components... it can at least significantly slow down the processing, and at worst cause a full crash/splat.
                              So the simple rule is when doing this kind of intensive processing, do not have the Outliner open, or if it is open, then do not have it 'rolled-down'.
                              And of course always save your work before starting any really complex operations that might lead to a failure/crash...
                                samyell77
                                Hi TIG, Pilou,
                                Thanks - had come around to that conclusion but thanks for confirming. Pilou, with outlier closed I have had no crashes and don't seem to have to run radial move first to get Eclate Deplace to work. As TIG says from now on I'll make sure I have the outliner window shut when doing anything with Eclate Deplace.
                                Thanks again for your help and Pilou thanks for a great plugin - I use it all the time and its a massive time saver for me...! ๐Ÿ‘
                                SU Pro 2016
                                PC Windows 10
                                16gb RAM
                                • maxmarjamaaM Offline
                                  maxmarjamaa
                                  Thank you, I've long been looking for.
                                    toddbg
                                    Hi -
                                    I'm having trouble with using this plugin.
                                    I have a fence model that I am trying to explode so I can get a good diagram of.
                                    This is a rather simple model but I thought I would use the plugin so that when I move up to doing cabinets and other major pieces then I would know how to use this plugin. ๐Ÿ˜„
                                    I have been able to get the rails to move along the X and Z but there are some smaller rails that capture a lattice that I would like to move apart on the Y, but they do not seem to be working.
                                    test lattice cedar fence.
                                      You have something wrong drawn inside the middle group of vertical and horizontal Planks ! ๐Ÿ˜ฎ
                                      I have redrawn them and no problem! ๐Ÿ˜„ Coef % x = 1; Y= 5 ; Z = 1
                                      the one on the origine is yours the one with "White pinky planks" is mine! ๐Ÿ˜„
                                      lattice_v4_expandedV6.skp
                                        toddbg
                                        Thanks Pilou!
                                        I['ll go back and see what I have wrong in the original. Your version works quite well. ๐Ÿ˜„
                                          samyell77
                                          Hi Pilou,
                                          Just wondered if you have any plans to update this plugin for 2014? Its an amazingly useful plugin and I use it almost daily.
                                          Thanks in advance
                                          Sam
                                          SU Pro 2016
                                          PC Windows 10
                                          16gb RAM
                                            @samyell77 said:
                                            Hi Pilou,
                                            Thanks in advance
                                            Sam
                                            What makes you think it's not compatible with v2014 ?
                                            As far as I know it works in ALL versions ??
                                            • 6 / 9
