    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 236.2k Views 51 Watching
      @guanjin said:
      V 0.3.1 version, did not see
      Really? Where were you looking?
      πŸ˜’
      • designerbursaD Offline
        designerbursa
        thank you
          samyell77
          Anyone getting bugsplats with this plugin? Love it and find it very useful but for some reason it is buggin out constantly on me - doesn't work at all! Can anyone help.....?
          Version numbers below... even tried downloading the current french version but no joy. Tried copying some parts out of my model into a fresh model and still got the bugsplat!
          Eclate Deplace - Version 0.3.2 rewritted by Fredo
          Radial Move - Version 0.3.2 rewritted by Fredo
          SU Pro 2016
          Dell Precision M4800
          PC Windows 10
          Intel Core i7-4900MQ @ 2.80ghz
          Nvidia Quadro K2100M
          16gb RAM
            samyell77
            Anyone??? Or is it just me...
            Can't get this to work at all for some reason, just crashes every time I try to use it.
            Any help or suggestions very gladly received πŸ˜„
            SU Pro 2016
            PC Windows 10
            16gb RAM
              I just downloaded and installed it and it works for me on SU2013. Perhaps you have some other plugin that is causing the conflict. Do you have the Vray or Podium plugins? You might try disabling other plugins and see if this one will run for you.
                samyell77
                Thanks DaveR, will try disabling some plugins and see. Hadn't thought of that - DOH!
                SU Pro 2016
                PC Windows 10
                16gb RAM
                  SketchyPhysics is also a big pertubator! πŸ˜‰
                    samyell77
                    Hi All,
                    Have tried to disable everything except Eclate Deplace and it STILL crashes? Anyone got any thoughts. Im stumped and seeing as I use this plugin almost daily am pulling my hair out.
                    Any help greatly appreciated as always....
                    Not sure what other plugins need to run with Eclate Deplace so not sure if there is anythign that has to be on to allow it to work.
                    Sam
                    SU Pro 2016
                    PC Windows 10
                    16gb RAM
                    • BoxB Offline
                      Perhaps there is something wrong with the model, or does it happen with all?
                        samyell77
                        Yes - tried to draw 3 boxes in a new model and run the plugin and it crashed?
                        Stumped....
                        SU Pro 2016
                        PC Windows 10
                        16gb RAM
                        • BoxB Offline
                          Just tested and it's working fine here on 7,8 and 13.
                          Have you changed anything recently, graphic card/driver, windows version/update , any new hardware..etc etc... you might need to track back to what you did before it started to crash.
                            samyell77
                            Installed a new graphics card recently but a colleague of mine has the same machine and had the same card installed at the same time and no problems.
                            Have removed all plugins from my plugins folder and installed only eclate deplace and still getting crashes every time... Arrrrrgh!
                            Going to have to make exploded diagrams manually for now.....
                            SU Pro 2016
                            PC Windows 10
                            16gb RAM
                            • BoxB Offline
                              Have you tried changing the opengl settings, sometimes just turning hardware acceleration off or on fixes things and it can often be switched back after.
                                samyell77
                                Thanks Box - tried and no joy Im afraid. Think its an issue with a graphics card. Going to sort it next week some time (hopefully)...
                                Cheers
                                Sam
                                SU Pro 2016
                                PC Windows 10
                                16gb RAM
                                  samyell77
                                  Have found a work around for this but still not got to the bottom of it. SU crashes pretty consistently if I run Eclate Deplace and have the outliner window open? So have been making sure I save, collapse the outliner window, open radial move first and then run eclate deplace. This seems to avoid the crashes but have no idea why...
                                  SU Pro 2016
                                  PC Windows 10
                                  16gb RAM
                                    Maybe you can also try to run it with it alone inside the Plugins folder for see if there is no compatibility with an another plugin!
                                      It has been a know problem with SketchUp that having the Outliner open and 'rolled-down' when running ANY processes that require intensive/multiple creation/changes to groups/components... it can at least significantly slow down the processing, and at worst cause a full crash/splat.
                                      So the simple rule is when doing this kind of intensive processing, do not have the Outliner open, or if it is open, then do not have it 'rolled-down'.
                                      And of course always save your work before starting any really complex operations that might lead to a failure/crash...
                                        samyell77
                                        Hi TIG, Pilou,
                                        Thanks - had come around to that conclusion but thanks for confirming. Pilou, with outlier closed I have had no crashes and don't seem to have to run radial move first to get Eclate Deplace to work. As TIG says from now on I'll make sure I have the outliner window shut when doing anything with Eclate Deplace.
                                        Thanks again for your help and Pilou thanks for a great plugin - I use it all the time and its a massive time saver for me...! πŸ‘
                                        SU Pro 2016
                                        PC Windows 10
                                        16gb RAM
                                        • maxmarjamaaM Offline
                                          maxmarjamaa
                                          Thank you, I've long been looking for.
                                            toddbg
                                            Hi -
                                            I'm having trouble with using this plugin.
                                            I have a fence model that I am trying to explode so I can get a good diagram of.
                                            This is a rather simple model but I thought I would use the plugin so that when I move up to doing cabinets and other major pieces then I would know how to use this plugin. πŸ˜„
                                            I have been able to get the rails to move along the X and Z but there are some smaller rails that capture a lattice that I would like to move apart on the Y, but they do not seem to be working.
                                            test lattice cedar fence.
                                            • 6 / 9
