    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 248.9k Views 51 Watching
      samyell77
      Have found a work around for this but still not got to the bottom of it. SU crashes pretty consistently if I run Eclate Deplace and have the outliner window open? So have been making sure I save, collapse the outliner window, open radial move first and then run eclate deplace. This seems to avoid the crashes but have no idea why...
      SU Pro 2016
      Dell Precision M4800
      PC Windows 10
      Intel Core i7-4900MQ @ 2.80ghz
      Nvidia Quadro K2100M
      16gb RAM
        Maybe you can also try to run it with it alone inside the Plugins folder for see if there is no compatibility with an another plugin!
          It has been a know problem with SketchUp that having the Outliner open and 'rolled-down' when running ANY processes that require intensive/multiple creation/changes to groups/components... it can at least significantly slow down the processing, and at worst cause a full crash/splat.
          So the simple rule is when doing this kind of intensive processing, do not have the Outliner open, or if it is open, then do not have it 'rolled-down'.
          And of course always save your work before starting any really complex operations that might lead to a failure/crash...
            samyell77
            Hi TIG, Pilou,
            Thanks - had come around to that conclusion but thanks for confirming. Pilou, with outlier closed I have had no crashes and don't seem to have to run radial move first to get Eclate Deplace to work. As TIG says from now on I'll make sure I have the outliner window shut when doing anything with Eclate Deplace.
            Thanks again for your help and Pilou thanks for a great plugin - I use it all the time and its a massive time saver for me...! ๐Ÿ‘
            SU Pro 2016
            PC Windows 10
            16gb RAM
            • maxmarjamaaM Offline
              maxmarjamaa
              Thank you, I've long been looking for.
                toddbg
                Hi -
                I'm having trouble with using this plugin.
                I have a fence model that I am trying to explode so I can get a good diagram of.
                This is a rather simple model but I thought I would use the plugin so that when I move up to doing cabinets and other major pieces then I would know how to use this plugin. ๐Ÿ˜„
                I have been able to get the rails to move along the X and Z but there are some smaller rails that capture a lattice that I would like to move apart on the Y, but they do not seem to be working.
                test lattice cedar fence.
                  You have something wrong drawn inside the middle group of vertical and horizontal Planks ! ๐Ÿ˜ฎ
                  I have redrawn them and no problem! ๐Ÿ˜„ Coef % x = 1; Y= 5 ; Z = 1
                  the one on the origine is yours the one with "White pinky planks" is mine! ๐Ÿ˜„
                  lattice_v4_expandedV6.skp
                    toddbg
                    Thanks Pilou!
                    I['ll go back and see what I have wrong in the original. Your version works quite well. ๐Ÿ˜„
                      samyell77
                      Hi Pilou,
                      Just wondered if you have any plans to update this plugin for 2014? Its an amazingly useful plugin and I use it almost daily.
                      Thanks in advance
                      Sam
                      SU Pro 2016
                      PC Windows 10
                      16gb RAM
                        @samyell77 said:
                        Hi Pilou,
                        Thanks in advance
                        Sam
                        What makes you think it's not compatible with v2014 ?
                        As far as I know it works in ALL versions ??
                          samyell77
                          Apologies - just realised I was updating the 2013 plugins folder not the 2014 one. It works perfectly as always!
                          SU Pro 2016
                          PC Windows 10
                          16gb RAM
                            samyell77
                            ๐Ÿ˜ As I said and exquisite plugin - many thanks Pilou!!!! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                            SU Pro 2016
                            PC Windows 10
                            16gb RAM
                              ๐Ÿ˜„
                              So CPlassais has made a very good job! ๐Ÿ˜Ž
                                tashnag
                                Hello,
                                Great plug in! I am having an issue though, please see the attached and help me figure out whats wrong...
                                If you open the attached sketchup file you will see 2 things, an 11/16" thick panel with 1/32" veneer on both sides, and 3 random sized panels pressed together.
                                The 11/16 with the 1/32 veneer wont separate when I use the plug, and I don't know why
                                The other 3 separate no problem, even though i create them the same way.
                                On another note, I cant tell which is the newest english version, I am currently on 3.0.2
                                Eclate deplace .skp
                                  Post your file save as V6 or V7 ! I can't read the 2014 that I have not! ๐Ÿ˜‰
                                  • massimoM Offline
                                    massimo Moderator
                                    Here you go Pilou. Saved as SU5, just in case... ๐Ÿ˜‰
                                    Eclate deplace .skp
                                      Thanks Massimo! Now i can investigate for find the glitch! ๐Ÿ˜Ž
                                        tashnag
                                        @Pilou, Thank you for your time.
                                        I don't know what you mean by groups and components on the same level. I exploded the parts and then turned them all into groups, and put them back together and it still wont work... I don't know what I'm doing wrong here.
                                        I thought they are all separated because I can grab individual parts and move them, and I just noticed a funny thing, when I change the angle of the 3 panels 45 degrees in either direction one of the veneer parts will do what I expect with eclate deplace, but not the other side.
                                          @tashnag
                                          It's normal!
                                          Plug works only with Components and/or Groups on the same level!
                                          Your "Thin object" is not composed of separated components/groups!!!
                                          So explode it and make with them some components/groups separated! ๐Ÿ˜‰
                                          PS another thing : your thin pieces are too small! Su don't works very well with these sort of little piรจces!
                                          So the plug too!
                                          So make a scale * 10; Apply the plug; make a scale 0.1
                                            Posts crossing! ๐Ÿ˜ณ
                                            So the plug too!
                                            • 7 / 9
