    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 253.1k Views 51 Watching
      samyell77
      Yes - tried to draw 3 boxes in a new model and run the plugin and it crashed?
      Stumped....
      SU Pro 2016
      Dell Precision M4800
      PC Windows 10
      Intel Core i7-4900MQ @ 2.80ghz
      Nvidia Quadro K2100M
      16gb RAM
      • BoxB
        Just tested and it's working fine here on 7,8 and 13.
        Have you changed anything recently, graphic card/driver, windows version/update , any new hardware..etc etc... you might need to track back to what you did before it started to crash.
          samyell77
          Installed a new graphics card recently but a colleague of mine has the same machine and had the same card installed at the same time and no problems.
          Have removed all plugins from my plugins folder and installed only eclate deplace and still getting crashes every time... Arrrrrgh!
          Going to have to make exploded diagrams manually for now.....
          SU Pro 2016
          PC Windows 10
          16gb RAM
          • BoxB
            Have you tried changing the opengl settings, sometimes just turning hardware acceleration off or on fixes things and it can often be switched back after.
              samyell77
              Thanks Box - tried and no joy Im afraid. Think its an issue with a graphics card. Going to sort it next week some time (hopefully)...
              Cheers
              Sam
              SU Pro 2016
              PC Windows 10
              16gb RAM
                samyell77
                Have found a work around for this but still not got to the bottom of it. SU crashes pretty consistently if I run Eclate Deplace and have the outliner window open? So have been making sure I save, collapse the outliner window, open radial move first and then run eclate deplace. This seems to avoid the crashes but have no idea why...
                SU Pro 2016
                PC Windows 10
                16gb RAM
                  Maybe you can also try to run it with it alone inside the Plugins folder for see if there is no compatibility with an another plugin!
                    It has been a know problem with SketchUp that having the Outliner open and 'rolled-down' when running ANY processes that require intensive/multiple creation/changes to groups/components... it can at least significantly slow down the processing, and at worst cause a full crash/splat.
                    So the simple rule is when doing this kind of intensive processing, do not have the Outliner open, or if it is open, then do not have it 'rolled-down'.
                    And of course always save your work before starting any really complex operations that might lead to a failure/crash...
                      samyell77
                      Hi TIG, Pilou,
                      Thanks - had come around to that conclusion but thanks for confirming. Pilou, with outlier closed I have had no crashes and don't seem to have to run radial move first to get Eclate Deplace to work. As TIG says from now on I'll make sure I have the outliner window shut when doing anything with Eclate Deplace.
                      Thanks again for your help and Pilou thanks for a great plugin - I use it all the time and its a massive time saver for me...! ๐Ÿ‘
                      SU Pro 2016
                      PC Windows 10
                      16gb RAM
                      • maxmarjamaaM
                        maxmarjamaa
                        Thank you, I've long been looking for.
                        • T
                          toddbg
                          Hi -
                          I'm having trouble with using this plugin.
                          I have a fence model that I am trying to explode so I can get a good diagram of.
                          This is a rather simple model but I thought I would use the plugin so that when I move up to doing cabinets and other major pieces then I would know how to use this plugin. ๐Ÿ˜„
                          I have been able to get the rails to move along the X and Z but there are some smaller rails that capture a lattice that I would like to move apart on the Y, but they do not seem to be working.
                          test lattice cedar fence.
                            You have something wrong drawn inside the middle group of vertical and horizontal Planks ! ๐Ÿ˜ฎ
                            I have redrawn them and no problem! ๐Ÿ˜„ Coef % x = 1; Y= 5 ; Z = 1
                            the one on the origine is yours the one with "White pinky planks" is mine! ๐Ÿ˜„
                            lattice_v4_expandedV6.skp
                            • T
                              toddbg
                              Thanks Pilou!
                              I['ll go back and see what I have wrong in the original. Your version works quite well. ๐Ÿ˜„
                                samyell77
                                Hi Pilou,
                                Just wondered if you have any plans to update this plugin for 2014? Its an amazingly useful plugin and I use it almost daily.
                                Thanks in advance
                                Sam
                                SU Pro 2016
                                PC Windows 10
                                16gb RAM
                                  @samyell77 said:
                                  Hi Pilou,
                                  Thanks in advance
                                  Sam
                                  What makes you think it's not compatible with v2014 ?
                                  As far as I know it works in ALL versions ??
                                    samyell77
                                    Apologies - just realised I was updating the 2013 plugins folder not the 2014 one. It works perfectly as always!
                                    SU Pro 2016
                                    PC Windows 10
                                    16gb RAM
                                      samyell77
                                      ๐Ÿ˜ As I said and exquisite plugin - many thanks Pilou!!!! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                      SU Pro 2016
                                      PC Windows 10
                                      16gb RAM
                                        ๐Ÿ˜„
                                        So CPlassais has made a very good job! ๐Ÿ˜Ž
                                        • T
                                          tashnag
                                          Hello,
                                          Great plug in! I am having an issue though, please see the attached and help me figure out whats wrong...
                                          If you open the attached sketchup file you will see 2 things, an 11/16" thick panel with 1/32" veneer on both sides, and 3 random sized panels pressed together.
                                          The 11/16 with the 1/32 veneer wont separate when I use the plug, and I don't know why
                                          The other 3 separate no problem, even though i create them the same way.
                                          On another note, I cant tell which is the newest english version, I am currently on 3.0.2
                                          Eclate deplace .skp
                                            Post your file save as V6 or V7 ! I can't read the 2014 that I have not! ๐Ÿ˜‰
                                            • 7 / 9
