    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 253.1k Views 51 Watching
    • T
      trimguy66
      I am hoping someone can help me.
      I have downloaded the Eclate_Deplace RB file, and dropped it in to my plugin folder,Which I have attached a screen shot of, but the tool is not showing up within SU.
      Any help would be greatly appreciated
      Thank You,
      Wayne
        So are you saying that if you select a collection of components/groups and right click on them, you aren't finding Eclate_Deplace in the Context menu?
          Time to launch SU...
          Dave was more speed than me πŸ˜‰
          • T
            trimguy66
            Thank you gentlemen, found it, I was looking in Plugins.
            This is a great tool, and a great forum.
            Thanks again!!
            Wayne
            • guanjinG
              guanjin
              V 0.3.1 version, did not see
                Really? Where were you looking?
                πŸ˜’
                • designerbursaD
                  designerbursa
                  thank you
                    samyell77
                    Anyone getting bugsplats with this plugin? Love it and find it very useful but for some reason it is buggin out constantly on me - doesn't work at all! Can anyone help.....?
                    Version numbers below... even tried downloading the current french version but no joy. Tried copying some parts out of my model into a fresh model and still got the bugsplat!
                    Eclate Deplace - Version 0.3.2 rewritted by Fredo
                    Radial Move - Version 0.3.2 rewritted by Fredo
                    SU Pro 2016
                    Dell Precision M4800
                    PC Windows 10
                    Intel Core i7-4900MQ @ 2.80ghz
                    Nvidia Quadro K2100M
                    16gb RAM
                      samyell77
                      Anyone??? Or is it just me...
                      Can't get this to work at all for some reason, just crashes every time I try to use it.
                      Any help or suggestions very gladly received πŸ˜„
                      SU Pro 2016
                      PC Windows 10
                      16gb RAM
                        I just downloaded and installed it and it works for me on SU2013. Perhaps you have some other plugin that is causing the conflict. Do you have the Vray or Podium plugins? You might try disabling other plugins and see if this one will run for you.
                          samyell77
                          Thanks DaveR, will try disabling some plugins and see. Hadn't thought of that - DOH!
                          SU Pro 2016
                          PC Windows 10
                          16gb RAM
                            SketchyPhysics is also a big pertubator! πŸ˜‰
                              samyell77
                              Hi All,
                              Have tried to disable everything except Eclate Deplace and it STILL crashes? Anyone got any thoughts. Im stumped and seeing as I use this plugin almost daily am pulling my hair out.
                              Any help greatly appreciated as always....
                              Not sure what other plugins need to run with Eclate Deplace so not sure if there is anythign that has to be on to allow it to work.
                              Sam
                              SU Pro 2016
                              PC Windows 10
                              16gb RAM
                              • BoxB
                                Perhaps there is something wrong with the model, or does it happen with all?
                                  samyell77
                                  Yes - tried to draw 3 boxes in a new model and run the plugin and it crashed?
                                  Stumped....
                                  SU Pro 2016
                                  PC Windows 10
                                  16gb RAM
                                  • BoxB
                                    Just tested and it's working fine here on 7,8 and 13.
                                    Have you changed anything recently, graphic card/driver, windows version/update , any new hardware..etc etc... you might need to track back to what you did before it started to crash.
                                      samyell77
                                      Installed a new graphics card recently but a colleague of mine has the same machine and had the same card installed at the same time and no problems.
                                      Have removed all plugins from my plugins folder and installed only eclate deplace and still getting crashes every time... Arrrrrgh!
                                      Going to have to make exploded diagrams manually for now.....
                                      SU Pro 2016
                                      PC Windows 10
                                      16gb RAM
                                      • BoxB
                                        Have you tried changing the opengl settings, sometimes just turning hardware acceleration off or on fixes things and it can often be switched back after.
                                          samyell77
                                          Thanks Box - tried and no joy Im afraid. Think its an issue with a graphics card. Going to sort it next week some time (hopefully)...
                                          Cheers
                                          Sam
                                          SU Pro 2016
                                          PC Windows 10
                                          16gb RAM
                                            samyell77
                                            Have found a work around for this but still not got to the bottom of it. SU crashes pretty consistently if I run Eclate Deplace and have the outliner window open? So have been making sure I save, collapse the outliner window, open radial move first and then run eclate deplace. This seems to avoid the crashes but have no idea why...
                                            SU Pro 2016
                                            PC Windows 10
                                            16gb RAM
                                            • 6 / 9
