    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 231.7k Views 45 Watching
      You should run Split Donut on the n-gons. It will give smoother results with less geometry.
      • cottyC Offline
        cotty
        πŸ‘
        I changed the model accordingly (V2)...
        my SketchUp gallery
          You should measure the poly count between the v1 & v2.
          I don't use Artisan to sub-d but have noticed that quad based meshes have lower face counts than those with Ngons present.
          Obviously the catmull Clark algo doesn't know how to efficiently divide an Ngon. Which creates lots of unnecessary polys and noticeable pinching.
          You should also run Quad Face detect poles to see where the pinching will happen and then tackle those.
          But I love to follow this thread. One of the gems in a sea 'it won't load' topics.
            d12dozr
            How cool would it if if Split Donut (or something similar) was integrated into Artisan, and helped figure out the n-gon topology??
            +1, yes!
            http://goo.gl/f7ooYh
            • cottyC Offline
              cotty
              @rich o brien said:
              You should also run Quad Face detect poles ...
              I don't know this, can you explain it a little bit, please?
              Thank you!
              Or directly in SU. I hope that Thomthom changed to Trimble to change all internals to quads and to implement his subdivision from this promising topic...
              @d12dozr said:
              +1, yes!
              Thank you too!
              my SketchUp gallery
              • cottyC Offline
                cotty
                I often wonder why Artisan shows a nice (more quad-like) mesh in the preview and it is not possible to choose this mesh instead of the triangulated...
                my SketchUp gallery
                  http://www.screenr.com/iUOH
                  [screenr:a7uj0sdu]iUOH[/screenr:a7uj0sdu]
                  • cottyC Offline
                    cotty
                    Newer looked at that context menu 😲
                    Very helpful, thank you!
                    edit: there seems to be some poles in the above example ...
                    my SketchUp gallery
                    • cottyC Offline
                      cotty
                      A quick baby rattle...
                      Screencast (making of) which covers the main part: http://screenr.com/ITOH
                      cotty_babyrattle_V2.skp
                      my SketchUp gallery
                      • W Offline
                        Whaat
                        Well, the preview mesh uses openGL to render (which supports non-planar quads) and we all know that SketchUp itself does not allow them.
                        Nice work as usual, cotty! πŸ‘
                          There are because the faces are not Quad Faces...
                          Having them as Quad Faces reduces pole count to 4.
                          • cottyC Offline
                            cotty
                            Is it possible to change the geometry so that there is no pole?
                            my SketchUp gallery
                              Of course but at times poles are inevitable. Just beware poles cause mesh pinching.
                              In that example you have 6 edges converging to one point at 4 locations.
                              If you tweak the proxy to lower the pole from 6 edges to 5 you then end up with 8 poles.
                              • cottyC Offline
                                cotty
                                3 simple components to assemble a mattress...
                                cotty_mattress.skp
                                my SketchUp gallery
                                • ElibjrE Offline
                                  Elibjr
                                  Thanks guys. These will show me how to put together my next chair model.
                                    from Pete's old Model This: Minion thread
                                    Must finish it off first... πŸ˜•
                                      SIVA SUNDAR
                                      hii i want to download full version of artisan plugins pls send me the link or put the file pls i need it... and one thing i already have the plugin but i can't use that plugin.
                                      this is how showing in my sketchup screen pls help me out.
                                        Here you can (legally) obtain artisan: http://artisan4sketchup.com/
                                        Else, if your post refers to some other (illegal) source of the plugin, be warned that SketchUcation does not tolerate piracy. For the time being, I hope it's only a language misapprehension
                                        • cottyC Offline
                                          cotty
                                          Looks like your trial period is over, you can buy a license here: http://artisan4sketchup.com/
                                          edit: oh, Gaieus was faster πŸ˜‰
                                          my SketchUp gallery
                                          • charly2008C Offline
                                            charly2008
                                            I Need your Help. How do I get this quad faces with artisan. I only get this result (see photo below).
                                            Thanks in advance for your help.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
