    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 373.7k Views 45 Watching
    • cottyC
      cotty
      A quick champagne glass...
      cotty_champagneglass.skp
      my SketchUp gallery
      • cottyC
        cotty
        A sculpture ...
        (Rendered fur: displacement map, wood texture)
        cotty_sculpture.zip
        my SketchUp gallery
        • cottyC
          cotty
          And because of the nice displacement fur, another test, this time an ugly fur-man...
          cotty_furman.skp
          my SketchUp gallery
          • pbacotP
            Thanks Cotty. Fur makes it all wonderful, haha.
            • HieruH
              Hieru
              Great tutorial showing real-time subdivision modelling of a car:
              www.davidhier.co.uk
                You should run Split Donut on the n-gons. It will give smoother results with less geometry.
                • cottyC
                  cotty
                  πŸ‘
                  I changed the model accordingly (V2)...
                  my SketchUp gallery
                    You should measure the poly count between the v1 & v2.
                    I don't use Artisan to sub-d but have noticed that quad based meshes have lower face counts than those with Ngons present.
                    Obviously the catmull Clark algo doesn't know how to efficiently divide an Ngon. Which creates lots of unnecessary polys and noticeable pinching.
                    You should also run Quad Face detect poles to see where the pinching will happen and then tackle those.
                    But I love to follow this thread. One of the gems in a sea 'it won't load' topics.
                      d12dozr
                      How cool would it if if Split Donut (or something similar) was integrated into Artisan, and helped figure out the n-gon topology??
                      +1, yes!
                      http://goo.gl/f7ooYh
                      • cottyC
                        cotty
                        @rich o brien said:
                        You should also run Quad Face detect poles ...
                        I don't know this, can you explain it a little bit, please?
                        Thank you!
                        Or directly in SU. I hope that Thomthom changed to Trimble to change all internals to quads and to implement his subdivision from this promising topic...
                        @d12dozr said:
                        +1, yes!
                        Thank you too!
                        my SketchUp gallery
                        • cottyC
                          cotty
                          I often wonder why Artisan shows a nice (more quad-like) mesh in the preview and it is not possible to choose this mesh instead of the triangulated...
                          my SketchUp gallery
                            http://www.screenr.com/iUOH
                            [screenr:a7uj0sdu]iUOH[/screenr:a7uj0sdu]
                            • cottyC
                              cotty
                              Newer looked at that context menu 😲
                              Very helpful, thank you!
                              edit: there seems to be some poles in the above example ...
                              my SketchUp gallery
                              • cottyC
                                cotty
                                A quick baby rattle...
                                Screencast (making of) which covers the main part: http://screenr.com/ITOH
                                cotty_babyrattle_V2.skp
                                my SketchUp gallery
                                • W
                                  Whaat
                                  Well, the preview mesh uses openGL to render (which supports non-planar quads) and we all know that SketchUp itself does not allow them.
                                  Nice work as usual, cotty! πŸ‘
                                    There are because the faces are not Quad Faces...
                                    Having them as Quad Faces reduces pole count to 4.
                                    • cottyC
                                      cotty
                                      Is it possible to change the geometry so that there is no pole?
                                      my SketchUp gallery
                                        Of course but at times poles are inevitable. Just beware poles cause mesh pinching.
                                        In that example you have 6 edges converging to one point at 4 locations.
                                        If you tweak the proxy to lower the pole from 6 edges to 5 you then end up with 8 poles.
                                        • cottyC
                                          cotty
                                          3 simple components to assemble a mattress...
                                          cotty_mattress.skp
                                          my SketchUp gallery
                                          • ElibjrE
                                            Elibjr
                                            Thanks guys. These will show me how to put together my next chair model.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
