    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 294.7k Views 45 Watching
    • cottyC Offline
      cotty
      @rich o brien said:
      You should also run Quad Face detect poles ...
      I don't know this, can you explain it a little bit, please?
      @rich o brien said:
      But I love to follow this thread. One of the gems in a sea 'it won't load' topics.
      Thank you!
      @d12dozr said:
      How cool would it if if Split Donut (or something similar) was integrated into Artisan, and helped figure out the n-gon topology??
      Or directly in SU. I hope that Thomthom changed to Trimble to change all internals to quads and to implement his subdivision from this promising topic...
      @d12dozr said:
      +1, yes!
      Thank you too!
      my SketchUp gallery
      • cottyC Offline
        cotty
        I often wonder why Artisan shows a nice (more quad-like) mesh in the preview and it is not possible to choose this mesh instead of the triangulated...
        my SketchUp gallery
          http://www.screenr.com/iUOH
          [screenr:a7uj0sdu]iUOH[/screenr:a7uj0sdu]
          • cottyC Offline
            cotty
            Newer looked at that context menu 😲
            Very helpful, thank you!
            edit: there seems to be some poles in the above example ...
            my SketchUp gallery
            • cottyC Offline
              cotty
              A quick baby rattle...
              Screencast (making of) which covers the main part: http://screenr.com/ITOH
              cotty_babyrattle_V2.skp
              my SketchUp gallery
              • W Offline
                Whaat
                Well, the preview mesh uses openGL to render (which supports non-planar quads) and we all know that SketchUp itself does not allow them.
                Nice work as usual, cotty! 👍
                  There are because the faces are not Quad Faces...
                  Having them as Quad Faces reduces pole count to 4.
                  • cottyC Offline
                    cotty
                    Is it possible to change the geometry so that there is no pole?
                    my SketchUp gallery
                      Of course but at times poles are inevitable. Just beware poles cause mesh pinching.
                      In that example you have 6 edges converging to one point at 4 locations.
                      If you tweak the proxy to lower the pole from 6 edges to 5 you then end up with 8 poles.
                      • cottyC Offline
                        cotty
                        3 simple components to assemble a mattress...
                        cotty_mattress.skp
                        my SketchUp gallery
                        • ElibjrE Offline
                          Elibjr
                          Thanks guys. These will show me how to put together my next chair model.
                            from Pete's old Model This: Minion thread
                            Must finish it off first... 😕
                              SIVA SUNDAR
                              hii i want to download full version of artisan plugins pls send me the link or put the file pls i need it... and one thing i already have the plugin but i can't use that plugin.
                              this is how showing in my sketchup screen pls help me out.
                                Here you can (legally) obtain artisan: http://artisan4sketchup.com/
                                Else, if your post refers to some other (illegal) source of the plugin, be warned that SketchUcation does not tolerate piracy. For the time being, I hope it's only a language misapprehension
                                • cottyC Offline
                                  cotty
                                  Looks like your trial period is over, you can buy a license here: http://artisan4sketchup.com/
                                  edit: oh, Gaieus was faster 😉
                                  my SketchUp gallery
                                  • charly2008C Offline
                                    charly2008
                                    I Need your Help. How do I get this quad faces with artisan. I only get this result (see photo below).
                                    Thanks in advance for your help.
                                    • mitcorbM Offline
                                      mitcorb
                                      Hi charly:
                                      See dialogue on previous page at Friday, August 23 in this thread. Notice how cotty predefined the lines on the baby rattle, also.
                                      • mitcorbM Offline
                                        mitcorb
                                        Hi, charly.
                                        See if this helps. I did not use other plugins. Only Artisan. As stated, delete all internal partitions.
                                        • cottyC Offline
                                          cotty
                                          An excellent sofa example by ginchius with proxy image and rendered version.
                                          my SketchUp gallery
                                          • olisheaO Offline
                                            olishea
                                            Wow ginchius' models are so convincing! I can imagine just how comfy the sofa is just by looking at the render! Most furniture models looks very static and formal.
                                            oli
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
