    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 249.5k Views 45 Watching
    • cottyC Offline
      cotty
      A sculpture ...
      (Rendered fur: displacement map, wood texture)
      cotty_sculpture.zip
      my SketchUp gallery
      • cottyC Offline
        cotty
        And because of the nice displacement fur, another test, this time an ugly fur-man...
        cotty_furman.skp
        my SketchUp gallery
        • pbacotP Offline
          Thanks Cotty. Fur makes it all wonderful, haha.
          • HieruH Offline
            Hieru
            Great tutorial showing real-time subdivision modelling of a car:
            www.davidhier.co.uk
              You should run Split Donut on the n-gons. It will give smoother results with less geometry.
              • cottyC Offline
                cotty
                πŸ‘
                I changed the model accordingly (V2)...
                my SketchUp gallery
                  You should measure the poly count between the v1 & v2.
                  I don't use Artisan to sub-d but have noticed that quad based meshes have lower face counts than those with Ngons present.
                  Obviously the catmull Clark algo doesn't know how to efficiently divide an Ngon. Which creates lots of unnecessary polys and noticeable pinching.
                  You should also run Quad Face detect poles to see where the pinching will happen and then tackle those.
                  But I love to follow this thread. One of the gems in a sea 'it won't load' topics.
                    d12dozr
                    How cool would it if if Split Donut (or something similar) was integrated into Artisan, and helped figure out the n-gon topology??
                    +1, yes!
                    http://goo.gl/f7ooYh
                    • cottyC Offline
                      cotty
                      @rich o brien said:
                      You should also run Quad Face detect poles ...
                      I don't know this, can you explain it a little bit, please?
                      Thank you!
                      Or directly in SU. I hope that Thomthom changed to Trimble to change all internals to quads and to implement his subdivision from this promising topic...
                      @d12dozr said:
                      +1, yes!
                      Thank you too!
                      my SketchUp gallery
                      • cottyC Offline
                        cotty
                        I often wonder why Artisan shows a nice (more quad-like) mesh in the preview and it is not possible to choose this mesh instead of the triangulated...
                        my SketchUp gallery
                          http://www.screenr.com/iUOH
                          [screenr:a7uj0sdu]iUOH[/screenr:a7uj0sdu]
                          • cottyC Offline
                            cotty
                            Newer looked at that context menu 😲
                            Very helpful, thank you!
                            edit: there seems to be some poles in the above example ...
                            my SketchUp gallery
                            • cottyC Offline
                              cotty
                              A quick baby rattle...
                              Screencast (making of) which covers the main part: http://screenr.com/ITOH
                              cotty_babyrattle_V2.skp
                              my SketchUp gallery
                              • W Offline
                                Whaat
                                Well, the preview mesh uses openGL to render (which supports non-planar quads) and we all know that SketchUp itself does not allow them.
                                Nice work as usual, cotty! πŸ‘
                                  There are because the faces are not Quad Faces...
                                  Having them as Quad Faces reduces pole count to 4.
                                  • cottyC Offline
                                    cotty
                                    Is it possible to change the geometry so that there is no pole?
                                    my SketchUp gallery
                                      Of course but at times poles are inevitable. Just beware poles cause mesh pinching.
                                      In that example you have 6 edges converging to one point at 4 locations.
                                      If you tweak the proxy to lower the pole from 6 edges to 5 you then end up with 8 poles.
                                      • cottyC Offline
                                        cotty
                                        3 simple components to assemble a mattress...
                                        cotty_mattress.skp
                                        my SketchUp gallery
                                        • ElibjrE Offline
                                          Elibjr
                                          Thanks guys. These will show me how to put together my next chair model.
                                            from Pete's old Model This: Minion thread
                                            Must finish it off first... πŸ˜•
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
