    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
      OSX wraps all extracted ZIPs into a folder with the same name as the ZIP. It is the content of that folder that should be in the Plugins folder. So you want to extract to a temp location, then move the correct files.
      You can use this utility to make it easier to install correctly:
      http://forums.sketchucation.com/viewtopic.php?t=42315
      Also, here's an article on installing plugins:
      http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
      (Dave beat me to it.)
        But you were more thorough.
          jcarter
          Thanks, hopefully responding allows me to download this tool!
          • LanaL Offline
            Lana
            Thanks Fredo. I love yours plugins.
              mwm5053
              In using the Classic Bezier Curve, I tried to change segments from 20s to 6s but doesn't seem to want do that and pressing tab doesn't seem to bring up anything obviously I'm missing something here I'm sure maybe someone can help. Thanks
              2011 iMac
              SU 2015 Pro, 2017 Make
              V2 Twilight
              macOS Sierra 10.12.5
              • jeff hammondJ Offline
                i'm not 100% sure of the # with classic bezier but i do know that if you're using a uniform B-spline, the lowest acceptable amount of segments is 15s (and if you enter something lower, it will still be 15 segments)
                [EDIT]-- with classic bezier curves, the lowest acceptable # is 7
                  mwm5053
                  Thanks Jeff will try that
                  2011 iMac
                  V2 Twilight
                  • W Offline
                    Woody Longspike
                    Thank you Fredo, a most excellent plugin and easy to use!
                      shemalpandya
                      THANK YOU SOOOOO MUCH 😍
                        gigi500
                        Is anybody using this plug in on Mac Sketch Up Pro2013? My plugin crashes after a few seconds....
                          Have you got the latest files and the latest LibFredo...
                          Which was recast for v2013 compatibility.
                          Also do you have any other know problem tools loading like Vray-beta ??
                            I've been using BZ_Spline tools on Mac in SU2013 with no problems. I do have the latest version of LibFredo6.
                            I wonder if you have a permissions issue.
                            Revised: It seems to work fine unless I try to use a number of tools from the toolbar in succession. Even just switching tools seems to cause a crash. I hadn't ever had an occasion to do that in my normal workflow so hadn't seen it. It doesn't seem to throw any Bug Splats, either.
                              gigi500
                              library and all that - downloaded from the store, so all new...Tried to delete and reinstall - the same thing.Without changing tools, just a few curves on a blank file, sometimes less than a complete curve - bugsplat. I am attaching a screen shot of plug ins - maybe you see something that I do not. Permissions are all the same for other plugins,including Fredos, so should not be an issue. His other plugins work just fine, no crashes.
                              • fredo6F Offline
                                You have a wrong installation
                                jointpushpull_main.rb should be in JPP_Dir_20, NOT in the main SU Plugins directory.
                                  gigi500
                                  You are right. I moved it. Bezier lasted this time for maybe 8 curves, then bugsplat:(((
                                    Fredo, I'm seeing the same thing on my Mac. I successfully drew 5 Bezier curves but while drawing the 6th, SketchUp crashed without a Bug Splat.
                                      gigi500
                                      I am attaching a new screen shot - got rid of all plugins but native sketch up and bezier. Still Crashes!
                                        What is the FULL path to that Plugins folder ?
                                        You leak out the story drip by drip... 😉
                                          gigi500
                                          the normal for mac:library/application support/sketchup2013/plugins/
                                          Everything else works. And Dave R apparently encountered the same thing...I got rid temporarily of other plugins to make sure they do not affect that one. No change.
                                          • fredo6F Offline
                                            @gigi500, @Dave,
                                            Not sure what it can be and why it appears now (I did not change anything to the plugin for a while).
                                            Since you have a deterministic crash situation (after a few curve), would you mind to remove the file LibTraductor.rb (or rename it .rb!). Since you have LibFredo6 installed, it should be harmless.
                                            • 11
                                            • 12
                                            • 22
                                            • 23
                                            • 10 / 23
