    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      Jack Camino
      Hello.
      Jack here, new to Sketchup8, plugins, etc. I am designing a guitar and I would really appreciate your help with this and future questions, which are going to be my contribution since at the moment I don't have any answers.
      I just downloaded the BezierSpline and installed it to the plugins folder on the macintosh HD so, my question is where is the location of the controls when I am in Sketchup8. Thanks.
        @jack camino said:
        Hello.
          Jack Camino
          Thanks Thomas.
          Let me show you what I have in my computer, see the attached pictures. Also, I don't understand what do you mean when you say remove the icon files in (BZ dir 14 ....images cad father). I guess that is the reason menu draw doesn't show bezier curves and I don't have a BesierSpline toolbar. Can you see the pictures and help me? Thanks.
            You haven't followed the footprint as laid out in the first post.
            You've got one too many folder levels. Move the contents of the one indicated into the Plugins folder and get rid of that folder.
            Also go to the SketchUp menu (to the left of File) and click on Preferences>Extensions and tick any and all boxes you find there.
              OSX wraps all extracted ZIPs into a folder with the same name as the ZIP. It is the content of that folder that should be in the Plugins folder. So you want to extract to a temp location, then move the correct files.
              You can use this utility to make it easier to install correctly:
              http://forums.sketchucation.com/viewtopic.php?t=42315
              Also, here's an article on installing plugins:
              http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
              (Dave beat me to it.)
                But you were more thorough.
                  jcarter
                  Thanks, hopefully responding allows me to download this tool!
                  • LanaL Offline
                    Lana
                    Thanks Fredo. I love yours plugins.
                      mwm5053
                      In using the Classic Bezier Curve, I tried to change segments from 20s to 6s but doesn't seem to want do that and pressing tab doesn't seem to bring up anything obviously I'm missing something here I'm sure maybe someone can help. Thanks
                      2011 iMac
                      SU 2015 Pro, 2017 Make
                      V2 Twilight
                      macOS Sierra 10.12.5
                      • jeff hammondJ Offline
                        i'm not 100% sure of the # with classic bezier but i do know that if you're using a uniform B-spline, the lowest acceptable amount of segments is 15s (and if you enter something lower, it will still be 15 segments)
                        [EDIT]-- with classic bezier curves, the lowest acceptable # is 7
                          mwm5053
                          Thanks Jeff will try that
                          2011 iMac
                          V2 Twilight
                          • W Offline
                            Woody Longspike
                            Thank you Fredo, a most excellent plugin and easy to use!
                              shemalpandya
                              THANK YOU SOOOOO MUCH 😍
                                gigi500
                                Is anybody using this plug in on Mac Sketch Up Pro2013? My plugin crashes after a few seconds....
                                  Have you got the latest files and the latest LibFredo...
                                  Which was recast for v2013 compatibility.
                                  Also do you have any other know problem tools loading like Vray-beta ??
                                    I've been using BZ_Spline tools on Mac in SU2013 with no problems. I do have the latest version of LibFredo6.
                                    I wonder if you have a permissions issue.
                                    Revised: It seems to work fine unless I try to use a number of tools from the toolbar in succession. Even just switching tools seems to cause a crash. I hadn't ever had an occasion to do that in my normal workflow so hadn't seen it. It doesn't seem to throw any Bug Splats, either.
                                      gigi500
                                      library and all that - downloaded from the store, so all new...Tried to delete and reinstall - the same thing.Without changing tools, just a few curves on a blank file, sometimes less than a complete curve - bugsplat. I am attaching a screen shot of plug ins - maybe you see something that I do not. Permissions are all the same for other plugins,including Fredos, so should not be an issue. His other plugins work just fine, no crashes.
                                      • fredo6F Offline
                                        You have a wrong installation
                                        jointpushpull_main.rb should be in JPP_Dir_20, NOT in the main SU Plugins directory.
                                          gigi500
                                          You are right. I moved it. Bezier lasted this time for maybe 8 curves, then bugsplat:(((
                                            Fredo, I'm seeing the same thing on my Mac. I successfully drew 5 Bezier curves but while drawing the 6th, SketchUp crashed without a Bug Splat.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 22
                                            • 23
                                            • 14 / 23
