    [Plugin] Click2flip v1.0 20110928
    23 Posts 11 Posters 22.1k Views 11 Watching
      byrnebm
      Ok thanks. Just a quick question is relation to the script "relazionefacce" which I use with click2flip. For the parameters it returns i.e FACCIA, ORIENAMENTO,AREA and MATERIALE. Where does the Faccia parameter come from and is this something that can be set for each face?
        FACCIA [FACE] is name=face.to_s.split(":")[-1].split(">")[0]
        i.e. when the array of faces is made they are by their 'id' e.g.
        [#<Sketchup::Face:0x1182fad0>, #<Sketchup::Face:0x1182f9e0>, ...]
        The splitting takes the 'id' code so the above list becomes
        [0x1182fad0 0x1182f9e0 ...
        You could of course just omit that column in the file as it does little of use...
          byrnebm
          I was just wondering if there was some way of naming the faces. I was hoping to be able to assign the room name to the horizontal face ie the floor of the room. So when i copy the parameters returned by relazionefacce to a spreadsheet I would know what room the results refer to.
            You could of course add an attribute to each face and later match the tabulated values to those, but it means manually adding them all - that's why I used the 'id' - but that only exists per session so isn't that useful later either...
            When I code with attributes I usually add a time-stamp id as it's unique enough - if you have two attributes with the value 'office' only one might get found.
            Tools like 'flattery' add a unique attribute code to every selected face and then use this in matching parts together later. You could do something similar - add an attribute to every selected face and use the attribute in your tabulated forms. You'd then need a second simple tool to 'find face by id' - it opens a dialog, you'd paste the attribute value from the tabulated data, and it finds the face by its attribute and then highlights that face for you...
            Change 'FACCIA' to say 'ID'.
            Modify the code thus...
            faces.each{|face|
              tid=(Time.now.to_f*1000).to_i
              face.set_attribute('BB','id',tid)if not face.get_attribute('BB','id',nil)
              ### if it already has an id it's kept...
              tid=face.get_attribute('BB','id',0)
              name=tid.to_s
            Now write a new tool to find a face by id...
            module TIG
             def self.findfacebyid()
              model=Sketchup.active_model
              ss=model.selection
              ss.clear
              results=inputbox(['ID; '],[0],'FindFaceByID')
              return nil unless results
              id=results[0].to_i
              model.active_entities.each{|e|ss.add(e)if e.get_attribute('BB','id',nil)==id}
            Usage: type TIG.findfacebyid
            or make a second menu item using it - follow the other menu item as a guide...
            Copy+paste an id from the table into the dialog
            The faces' IDs will persist across sessions provided the model is saved...
            I used 'BB' as the attribute-library based on your initials, but you can use anything you want...
            ๐Ÿค“
              Gillman
              Just wanted to thank you for this great plug-in. It has already saved me a ton of time.
                mirale999
                A wonderful plugin! thank you TIG๏ผI think TIG-flipBacks.rb is much more easier than other face reversers until now~
                paranoia is a higher form of awareness...
                • 3 Offline
                  3dsmax9
                  it's great to have a lot of choice thanks TIG, personally i prefer this one FrontFace1-2 : http://forums.sketchucation.com/viewtopic.php?t=13380
                    mirale999
                    haha! I'm using frontface and Click2flip, they have different feature~ I appreciate the amazing performance of the former, while the latter is faster when I have so many small faces to reverse at once!
                    • artmusicstudioA Offline
                      artmusicstudio
                      hi tig,
                      i am not a programmer, but as flipped faces always happen in skp and in complicated structures it is sometimes difficult to select them one after another, i had a following idea for this script
                      1. could it flip ALL SELECTED faces at once (of course with your "automatic" identificaton?
                      2. could it become an option :
                      make all front / make all back / make all faces the side, which is "higher" represented (sorry for this english....means with 100 faces, when 3 are back and the rest is front, it would make all front and vice versa)
                      by that i could double-click & select all connected faces and define all at once
                      thanx stan
                        Isn't a pair of shortcut-keys, to 'Reverse' and 'Orient' to match the just reversed face, going to do most of this ?
                          artmusicstudio
                          yes, you're right. maybe for selection (if there is any) or all elements.
                          so this 'make positive/negative' feature would be great and a real time-saver.
                          regards stan
                            clubber2k
                            Wow, magical! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                            looked for something like this way back and didn't find.
                            only issue is that the automatic decision making stress me out. on complex models it might flip the right one facing to me, but also another that should be facing in another direction and I didn't even notice...
                            can you add an option using the same concept to just label all the wrong facing faces - allowing more precise decision making?
                            thanks ๐Ÿ˜Ž
                              You might find it useful to set the back face color to something more easily discernible. I use a green I'd never use in the model as a color/texture.
                                clubber2k
                                Yes - that's a generally good idea but since sometimes you have materials on the back side you need to go monochrome and back too see whats going on.. anyway since this plugin already exist - adding a label option will add great usability if possible..
                                • CadFatherC Offline
                                  CadFather
                                  great and simple tool, would be super-fab if able to flip curved faces as well!
                                  ...i thought combining the 2 bits of code above might do the trick:
                                  1, click2flip
                                  2, flip selection
                                  the idea being that if i click on a curved face, i'm also selecting it and therefore running the 2nd script might reverse the whole curved face, say a cylinder. (ideally i thought it could be toggled by pressing an accelerator key) a fair bit beyond my christmas powers... surely possible though..?
                                  class TIG;;Click2flip
                                    @@BEEP=false
                                    def initialize()
                                      @ip  = nil
                                      @ip1 = nil
                                    def activate()
                                      @ip  = Sketchup;;InputPoint.new
                                      @ip1 = Sketchup;;InputPoint.new
                                      @msg="Click back of face to flip it..."
                                      self.reset()
                                    def deactivate(view)
                                      view.invalidate
                                    def onCancel(flag, view)
                                      view.invalidate
                                      Sketchup.send_action("selectSelectionTool;")
                                      return nil
                                    def resume(view)
                                      Sketchup;;set_status_text(@msg, SB_PROMPT)
                                    def reset()
                                    def onMouseMove(flags, x, y, view)
                                      @ip.pick(view, x, y)
                                      if @ip != @ip1
                                          view.invalidate if @ip.display? or @ip1.display?
                                          @ip1.copy!(@ip)
                                          view.tooltip = @ip1.tooltip
                                    def onLButtonDown(flags, x, y, view)
                                      if @ip1.valid?
                                          @pt=@ip1.position
                                          ph = view.pick_helper
                                          ph.do_pick(x,y)
                                          @face = ph.picked_face
                                          self.flipper() if @face
                                    def flipper()
                                      normal=@face.normal
                                      vector=@pt.vector_to(Sketchup.active_model.active_view.camera.eye)
                                      angle=normal.angle_between(vector)
                                      if angle > 90.degrees
                                        @face.reverse!
                                        UI.beep if @@BEEP
                                      end#if
                                  end#class
                                  def self.flipBacks()
                                    eye=model.active_view.camera.eye
                                    faces=[]
                                    Sketchup.active_model.selection.each{|e|faces << e if e.class==Sketchup;;Face}
                                    return nil unless faces[0]
                                    model.start_operation("Flip Selected Back Faces...")
                                    faces.each{|face|
                                      normal=face.normal
                                      vector=face.bounds.center.vector_to(eye)
                                      face.reverse! if angle > 90.degrees
                                    model.commit_operation
                                  EDIT: actually just noticed the second script only flips half a cylinder (the side to the screen), the back remains undone.
