    [Plugin] Click2flip v1.0 20110928
    23 Posts 11 Posters 21.6k Views 11 Watching
      You might find it useful to set the back face color to something more easily discernible. I use a green I'd never use in the model as a color/texture.
        clubber2k
        Yes - that's a generally good idea but since sometimes you have materials on the back side you need to go monochrome and back too see whats going on.. anyway since this plugin already exist - adding a label option will add great usability if possible..
        • CadFatherC Offline
          CadFather
          great and simple tool, would be super-fab if able to flip curved faces as well!
          ...i thought combining the 2 bits of code above might do the trick:
          1, click2flip
          2, flip selection
          the idea being that if i click on a curved face, i'm also selecting it and therefore running the 2nd script might reverse the whole curved face, say a cylinder. (ideally i thought it could be toggled by pressing an accelerator key) a fair bit beyond my christmas powers... surely possible though..?
          class TIG;;Click2flip
            @@BEEP=false
            def initialize()
              @ip  = nil
              @ip1 = nil
            def activate()
              @ip  = Sketchup;;InputPoint.new
              @ip1 = Sketchup;;InputPoint.new
              @msg="Click back of face to flip it..."
              self.reset()
            def deactivate(view)
              view.invalidate
            def onCancel(flag, view)
              view.invalidate
              Sketchup.send_action("selectSelectionTool;")
              return nil
            def resume(view)
              Sketchup;;set_status_text(@msg, SB_PROMPT)
            def reset()
            def onMouseMove(flags, x, y, view)
              @ip.pick(view, x, y)
              if @ip != @ip1
                  view.invalidate if @ip.display? or @ip1.display?
                  @ip1.copy!(@ip)
                  view.tooltip = @ip1.tooltip
            def onLButtonDown(flags, x, y, view)
              if @ip1.valid?
                  @pt=@ip1.position
                  ph = view.pick_helper
                  ph.do_pick(x,y)
                  @face = ph.picked_face
                  self.flipper() if @face
            def flipper()
              normal=@face.normal
              vector=@pt.vector_to(Sketchup.active_model.active_view.camera.eye)
              angle=normal.angle_between(vector)
              if angle > 90.degrees
                @face.reverse!
                UI.beep if @@BEEP
              end#if
          end#class
          def self.flipBacks()
            model=Sketchup.active_model
            eye=model.active_view.camera.eye
            faces=[]
            Sketchup.active_model.selection.each{|e|faces << e if e.class==Sketchup;;Face}
            return nil unless faces[0]
            model.start_operation("Flip Selected Back Faces...")
            faces.each{|face|
              normal=face.normal
              vector=face.bounds.center.vector_to(eye)
              face.reverse! if angle > 90.degrees
            model.commit_operation
          EDIT: actually just noticed the second script only flips half a cylinder (the side to the screen), the back remains undone.
          • 2 / 2
