    [Plugin] Click2flip v1.0 20110928
    23 Posts 11 Posters 21.6k Views 11 Watching
      mirale999
      A wonderful plugin! thank you TIG!I think TIG-flipBacks.rb is much more easier than other face reversers until now~
      paranoia is a higher form of awareness...
      • 3 Offline
        3dsmax9
        it's great to have a lot of choice thanks TIG, personally i prefer this one FrontFace1-2 : http://forums.sketchucation.com/viewtopic.php?t=13380
          mirale999
          haha! I'm using frontface and Click2flip, they have different feature~ I appreciate the amazing performance of the former, while the latter is faster when I have so many small faces to reverse at once!
          • artmusicstudioA Offline
            artmusicstudio
            hi tig,
            i am not a programmer, but as flipped faces always happen in skp and in complicated structures it is sometimes difficult to select them one after another, i had a following idea for this script
            1. could it flip ALL SELECTED faces at once (of course with your "automatic" identificaton?
            2. could it become an option :
            make all front / make all back / make all faces the side, which is "higher" represented (sorry for this english....means with 100 faces, when 3 are back and the rest is front, it would make all front and vice versa)
            by that i could double-click & select all connected faces and define all at once
            thanx stan
              Isn't a pair of shortcut-keys, to 'Reverse' and 'Orient' to match the just reversed face, going to do most of this ?
                artmusicstudio
                yes, you're right. maybe for selection (if there is any) or all elements.
                so this 'make positive/negative' feature would be great and a real time-saver.
                regards stan
                  clubber2k
                  Wow, magical! πŸ‘ πŸ‘ πŸ‘
                  looked for something like this way back and didn't find.
                  only issue is that the automatic decision making stress me out. on complex models it might flip the right one facing to me, but also another that should be facing in another direction and I didn't even notice...
                  can you add an option using the same concept to just label all the wrong facing faces - allowing more precise decision making?
                  thanks 😎
                    You might find it useful to set the back face color to something more easily discernible. I use a green I'd never use in the model as a color/texture.
                      clubber2k
                      Yes - that's a generally good idea but since sometimes you have materials on the back side you need to go monochrome and back too see whats going on.. anyway since this plugin already exist - adding a label option will add great usability if possible..
                      • CadFatherC Offline
                        CadFather
                        great and simple tool, would be super-fab if able to flip curved faces as well!
                        ...i thought combining the 2 bits of code above might do the trick:
                        1, click2flip
                        2, flip selection
                        the idea being that if i click on a curved face, i'm also selecting it and therefore running the 2nd script might reverse the whole curved face, say a cylinder. (ideally i thought it could be toggled by pressing an accelerator key) a fair bit beyond my christmas powers... surely possible though..?
                        class TIG;;Click2flip
                          @@BEEP=false
                          def initialize()
                            @ip  = nil
                            @ip1 = nil
                          def activate()
                            @ip  = Sketchup;;InputPoint.new
                            @ip1 = Sketchup;;InputPoint.new
                            @msg="Click back of face to flip it..."
                            self.reset()
                          def deactivate(view)
                            view.invalidate
                          def onCancel(flag, view)
                            view.invalidate
                            Sketchup.send_action("selectSelectionTool;")
                            return nil
                          def resume(view)
                            Sketchup;;set_status_text(@msg, SB_PROMPT)
                          def reset()
                          def onMouseMove(flags, x, y, view)
                            @ip.pick(view, x, y)
                            if @ip != @ip1
                                view.invalidate if @ip.display? or @ip1.display?
                                @ip1.copy!(@ip)
                                view.tooltip = @ip1.tooltip
                          def onLButtonDown(flags, x, y, view)
                            if @ip1.valid?
                                @pt=@ip1.position
                                ph = view.pick_helper
                                ph.do_pick(x,y)
                                @face = ph.picked_face
                                self.flipper() if @face
                          def flipper()
                            normal=@face.normal
                            vector=@pt.vector_to(Sketchup.active_model.active_view.camera.eye)
                            angle=normal.angle_between(vector)
                            if angle > 90.degrees
                              @face.reverse!
                              UI.beep if @@BEEP
                            end#if
                        end#class
                        def self.flipBacks()
                          model=Sketchup.active_model
                          eye=model.active_view.camera.eye
                          faces=[]
                          Sketchup.active_model.selection.each{|e|faces << e if e.class==Sketchup;;Face}
                          return nil unless faces[0]
                          model.start_operation("Flip Selected Back Faces...")
                          faces.each{|face|
                            normal=face.normal
                            vector=face.bounds.center.vector_to(eye)
                            face.reverse! if angle > 90.degrees
                          model.commit_operation
                        EDIT: actually just noticed the second script only flips half a cylinder (the side to the screen), the back remains undone.
                        • 2 / 2
