FluidImporter free .obj importer Beta 1.0.5 Updated
@tig said:
The MTL path is 'absolute' NOT relative
map_Kd **C:\**london_map.tga
etc
For the code to find the image it must either be in the root of the drive [bad idea] or in the same folder as the MTL, so edit it to read
map_Kd london_map.tga
etc
Can't guarantee the TGA file is 'good' but we won't know until you set the paths right...I put the files in the root of the drive.
But... why ???
Keep them with the MTL file where they belong, and change the path to a relative path inside the MTL file's code.
Not even sure that a \ works in MTL absolute paths - it should be a / ???
The originator needs shooting for making the MTL file that way in the first place...Does it work ?
Either way ??Have you tried fixing the TGA file otherwise ???
@tig said:
But... why ???
Fixed the problem by changing
map_Kd C:\london_map.tga
to
Hi, I want to uninstall the FluidImporter,
but I use revoUninstaller to do the job,
but revo is make a mistake, it even bold the vray registry to be deleted so i skip the registry deletion and i found this to verify if i can delete these 3 files:are those fluidimporter files? is it save if I delete them?
coz fluidimporter is crashes with my vray so vray wont render any image from imported object..
Do not remove any of the other Importer's .dll files.
If you have you need to reinstall the affected products...To stop the Fluid-OBJimporter loading simply run its Uninstaller and it will be removed...
I have three .OBJ files I'm trying to import. The largest one imports without crashing, but half of all the facets are not filled in, so I can't really change the material.
The other two files (one without an MTL) crash as soon about 2 seconds after starting to parse file.
Here are the files that crash totally. (One isn't zipped...no MTL).
Thanks.
Try checking that the units size is correct - very small facets cannot be formed in SketchUp.
Some app's make OBJ files in odd ways...
So if that doesn't work try importing it into another app - like Blender: if it is OK it that app, then re-export from that - the new OBJ format might be made more compatible with this SketchUp's importer ? -
@thomthom said:
I'm getting crashes when I try to import an .obj file I got. (120MB)
I've tried different options - triangulate on/off, material on/off - but it bugsplats every time. Memory usage of Sketchup.exe doesn't exceed 300MB.Any ideas?
I am having this very same issue.
guys have you tried installing this in su 2013? I tried but I can't see it in file menu, wondering if anyone here installed it successfully inside 2013
You haven't completed your User-Profile... OS, version etc ??
Help us to help you...It is Win 32bit, by default it tries to install into the SketchUp 8 Importers folder, you can redirect it to SketchUp 2013, but when it installs the dll it doesn't load as the OBJ importer in the Import list...
I suspect that the author will need to make a v2013 compatible version...Perhaps if you PM him he'll respond...
thanks Tig for the reply. yah, sorry about my profile, I will complete them now.
Hope the author of this plugin release some update for 2013. I think this is the best importer for obj in sketchup
thanks Tig
I've been in touch with the author...
He will look at a v2013 compliant version...
But don't hold your breath... -
I now always get bugsplat when using the obj importer...
I am on Win7Pro64 SU7
Anyone with the same problem? -
hi, there is a problem on the official page of http://www.fluidray.com/ (Internal Server Error)
an its imposible to download the fluidimporter win 32
please can someone share
thanks in advance -
thanks, i have now the fluidimporter from direct download (11,7MB)
I try how it works -
We just released FluidImporter 2.0 for SketchUp 2013. We decided to make it available for a small fee to help support the development. You can download the 30-Day trial (full-featured) in the download page: http://www.fluidray.com/downloads -
This is what I was looking for !!! thanks TIG and fluid you are my hero !
HELP WANTED - OBJ IMPORT OPTION DOES NOT APPEAR
I am a happy SketchUp user (version 8.0.16846), mostly for hobby purposes. I used the FluidImporter (v 1.0.5 32 bit) to import OBJ files into SketchUp with no problems at all for more than one year. I am running Win XP pro SP3 32 bit.Last week I format my HD and start installing again all programs - no problem so far. After installing the SketchUp (version 8.0.16846) & FluidImporter (v 1.0.5 32 bit) which I used to work for long time without problems, I found that I cannot import OBJ files. Actually, under the "Import" table, the "OBJ files" options is now missing (screenshots follwoing). The FluidImporter seems to be installed normaly, the files "FluidImporter.dll" and "Uninstall.exe" seems to be OK under C:\Program Files\Google\Google SketchUp 8\Importers folder (exactly as before HD format and Win XP new instalation)... but the OBJ importing option is missing!
As said before, I am running a SketchUp 8.0.16846 with FluidImporter 1.0.5 (Win XP 32 bit version downloaded from http://www.fluidray.com/downloads link) on a Win XP SP3. The most weird is that I installed the exact same setup files as before HD format and new Win XP, so it should work but unfortunatelly it does not!
Any ideas or advices please?
Anybody? Come ooon people. Am I the only one person facing this problem? There MUST be a way! OBJ files importing option is still not available and I have no idea what should be done to make it work......ANY idea, ANY advice could be usefull
