    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 97.1k Views 46 Watching
      Perhaps it's the TGA image format that's unsuitable ?
      Try moving the origin of the TGA to top-left and re-saving... and/or having no TGA RLE-compression in the image [Gimp it].
      If a TGA file's format is not suitable for use in a SKM texture it will fail.
      I have just maually replicated this error by trying to use a bottom-left/RLE-compressed TGA as a texture - it fails... because there is no suitable image file specified...
      Alternatively try making PNG versions of the files [with Gimp] and editing the MTL file to look for .PNG not .TGA file names...
      See if these ideas works...
        Mainline411
        Tried converting to the .TGA to a .PNG it converted fine but still the textures do not import. I do not know what GIMP is so I can't try the first one I have uploaded the files now (you can get them here: http://testsite21.weebly.com/uploads/5/5/0/6/5506080/sketchucation_trimble_sktechup_.obj_error.zip) if you could try and import them and send me the .SKP it would be extremely appreciated 😄 I did change it to PNG but I changed it back to .TGA I have included the .PNG in the zip still though.
          The MTL path is 'absolute' NOT relative
          map_Kd **C:\**london_map.tga etc
          For the code to find the image it must either be in the root of the drive [bad idea] or in the same folder as the MTL, so edit it to read
          map_Kd london_map.tga etc
          Can't guarantee the TGA file is 'good' but we won't know until you set the paths right...
            Mainline411
            I put the files in the root of the drive.
              But... why ???
              Keep them with the MTL file where they belong, and change the path to a relative path inside the MTL file's code.
              Not even sure that a \ works in MTL absolute paths - it should be a / ???
              The originator needs shooting for making the MTL file that way in the first place... 😒
              Does it work ?
              Either way ??
              Have you tried fixing the TGA file otherwise ??? 😕
                Mainline411
                @tig said:
                But... why ???
                Does it work ?
                Either way ??
                Fixed the problem by changing
                map_Kd C:\london_map.tga
                to
                  mingjae
                  Hi, I want to uninstall the FluidImporter,
                  but I use revoUninstaller to do the job,
                  but revo is make a mistake, it even bold the vray registry to be deleted so i skip the registry deletion and i found this to verify if i can delete these 3 files:
                  http://img14.imageshack.us/img14/9527/85977293.jpg
                  are those fluidimporter files? is it save if I delete them?
                  coz fluidimporter is crashes with my vray so vray wont render any image from imported object..
                    Do not remove any of the other Importer's .dll files.
                    If you have you need to reinstall the affected products...
                    To stop the Fluid-OBJimporter loading simply run its Uninstaller and it will be removed...
                    • L
                      Lost_Arkitekt
                      I have three .OBJ files I'm trying to import. The largest one imports without crashing, but half of all the facets are not filled in, so I can't really change the material.
                      The other two files (one without an MTL) crash as soon about 2 seconds after starting to parse file.
                      Here are the files that crash totally. (One isn't zipped...no MTL).
                      Thanks.
                      arne-jacobsen-ant-obj.rar
                      • L
                        Lost_Arkitekt
                        The other file didn't attach. Here it is.
                        chair-obj.rar
                          Try checking that the units size is correct - very small facets cannot be formed in SketchUp.
                          Some app's make OBJ files in odd ways...
                          So if that doesn't work try importing it into another app - like Blender: if it is OK it that app, then re-export from that - the new OBJ format might be made more compatible with this SketchUp's importer ?
                          • V
                            Vaile
                            @thomthom said:
                            I'm getting crashes when I try to import an .obj file I got. (120MB)
                            I've tried different options - triangulate on/off, material on/off - but it bugsplats every time. Memory usage of Sketchup.exe doesn't exceed 300MB.
                            Any ideas?
                            I am having this very same issue.
                              macmac12
                              guys have you tried installing this in su 2013? ❓ I tried but I can't see it in file menu, wondering if anyone here installed it successfully inside 2013
                                You haven't completed your User-Profile... OS, version etc ??
                                Help us to help you...
                                It is Win 32bit, by default it tries to install into the SketchUp 8 Importers folder, you can redirect it to SketchUp 2013, but when it installs the dll it doesn't load as the OBJ importer in the Import list...
                                I suspect that the author will need to make a v2013 compatible version... 😒
                                Perhaps if you PM him he'll respond...
                                  macmac12
                                  thanks Tig for the reply. yah, sorry about my profile, I will complete them now.
                                  Hope the author of this plugin release some update for 2013. I think this is the best importer for obj in sketchup
                                  thanks Tig
                                    I've been in touch with the author...
                                    He will look at a v2013 compliant version...
                                    But don't hold your breath...
                                      archigrafix
                                      I now always get bugsplat when using the obj importer...
                                      I am on Win7Pro64 SU7
                                      Anyone with the same problem?
                                      Agir comme un homme de pensée, et penser comme un homme d'action...
                                      • G
                                        guaucorreo
                                        hi, there is a problem on the official page of http://www.fluidray.com/ (Internal Server Error)
                                        an its imposible to download the fluidimporter win 32
                                        please can someone share
                                        thanks in advance
                                        • G
                                          guaucorreo
                                          thanks, i have now the fluidimporter from direct download (11,7MB)
                                          I try how it works
                                          • F
                                            fluid
                                            We just released FluidImporter 2.0 for SketchUp 2013. We decided to make it available for a small fee to help support the development. You can download the 30-Day trial (full-featured) in the download page: http://www.fluidray.com/downloads
                                            • 6 / 9
