    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 86.1k Views 46 Watching
    • V Offline
      Vaile
      @thomthom said:
      I'm getting crashes when I try to import an .obj file I got. (120MB)
      I've tried different options - triangulate on/off, material on/off - but it bugsplats every time. Memory usage of Sketchup.exe doesn't exceed 300MB.
      Any ideas?
      I am having this very same issue.
        macmac12
        guys have you tried installing this in su 2013? ❓ I tried but I can't see it in file menu, wondering if anyone here installed it successfully inside 2013
          You haven't completed your User-Profile... OS, version etc ??
          Help us to help you...
          It is Win 32bit, by default it tries to install into the SketchUp 8 Importers folder, you can redirect it to SketchUp 2013, but when it installs the dll it doesn't load as the OBJ importer in the Import list...
          I suspect that the author will need to make a v2013 compatible version... 😒
          Perhaps if you PM him he'll respond...
            macmac12
            thanks Tig for the reply. yah, sorry about my profile, I will complete them now.
            Hope the author of this plugin release some update for 2013. I think this is the best importer for obj in sketchup
            thanks Tig
              I've been in touch with the author...
              He will look at a v2013 compliant version...
              But don't hold your breath...
                archigrafix
                I now always get bugsplat when using the obj importer...
                I am on Win7Pro64 SU7
                Anyone with the same problem?
                Agir comme un homme de pensée, et penser comme un homme d'action...
                  guaucorreo
                  hi, there is a problem on the official page of http://www.fluidray.com/ (Internal Server Error)
                  an its imposible to download the fluidimporter win 32
                  please can someone share
                  thanks in advance
                    guaucorreo
                    thanks, i have now the fluidimporter from direct download (11,7MB)
                    I try how it works
                    • F Offline
                      fluid
                      We just released FluidImporter 2.0 for SketchUp 2013. We decided to make it available for a small fee to help support the development. You can download the 30-Day trial (full-featured) in the download page: http://www.fluidray.com/downloads
                        RTM
                        This is what I was looking for !!! thanks TIG and fluid you are my hero ! 😄
                          Mikaelo
                          HELP WANTED - OBJ IMPORT OPTION DOES NOT APPEAR
                          I am a happy SketchUp user (version 8.0.16846), mostly for hobby purposes. I used the FluidImporter (v 1.0.5 32 bit) to import OBJ files into SketchUp with no problems at all for more than one year. I am running Win XP pro SP3 32 bit.
                          Last week I format my HD and start installing again all programs - no problem so far. After installing the SketchUp (version 8.0.16846) & FluidImporter (v 1.0.5 32 bit) which I used to work for long time without problems, I found that I cannot import OBJ files. Actually, under the "Import" table, the "OBJ files" options is now missing (screenshots follwoing). The FluidImporter seems to be installed normaly, the files "FluidImporter.dll" and "Uninstall.exe" seems to be OK under C:\Program Files\Google\Google SketchUp 8\Importers folder (exactly as before HD format and Win XP new instalation)... but the OBJ importing option is missing!
                          As said before, I am running a SketchUp 8.0.16846 with FluidImporter 1.0.5 (Win XP 32 bit version downloaded from http://www.fluidray.com/downloads link) on a Win XP SP3. The most weird is that I installed the exact same setup files as before HD format and new Win XP, so it should work but unfortunatelly it does not!
                          Any ideas or advices please?
                          http://s28.postimg.org/psxdlvpvx/Screen_01.jpg
                          http://s28.postimg.org/lu063218t/Screen_02.jpg
                          http://s28.postimg.org/tb9di9qrx/Screen_03.jpg
                          http://s28.postimg.org/cq1r2lznx/Screen_04.jpg
                            Mikaelo
                            Anybody? Come ooon people. Am I the only one person facing this problem? There MUST be a way! OBJ files importing option is still not available and I have no idea what should be done to make it work...
                            ...ANY idea, ANY advice could be usefull
                              Have you been in touch with the author ?
                              It might be an XP issue ??
                              If all else fails my slower Ruby based OBJimporter will work ?
                                Mikaelo
                                Already did that, few days ago. No answer yet.
                                Could be, could be not. I have an old laptop, operating with same XP pro SP3 version, same SketchUp version 8.0.15158 and same FluidImporter version 1.0.5 and the OBJ files can be imported. You might ask me why I do not use this old laptop, to do all the import hard work to translate OBJ into SKP files. Well, its an old laptop as said before, not capable for hard work and able to handle only small (not more than 1-2 Mb) OBJ files without crashing Sketchup.
                                I guess you mean THIS one. Right? Already download it and seems to be the "obj_importer_v2.2.rbz" file (5.2 kb). Placed it into "Plugins" folder, but nothing happened. Should I place it into another folder? On the other hand, I ve alrady tried Jim Foltz's "obj_import.rb" file, which seems to give me an option to inport an OBJ file but it does not work (Sketchup does not respond (even if I tried small files 0.5-1 Mb)...
                                The last few days I have this problem, I formated the hd 5 times, install everything again another 5 times, do everything by the book as I did dozens of times all these years before when need to re-fresh my Windows, tried different versions of Sketchup (v 7.0.08657 / 7.0.10247 / 7.1.04871 / 7.1.06087 / 7.1.06860 / 8.0.03117 / 8.0.04811 / 8.0.11752 / 8.0.14346 / 8.0.15158) tried to install again and again the FluidImporter 1.0.5, but nothing happens...!!! No OBJ file import option appeared into menu.
                                • BoxB Offline
                                  I don't know about the rest of it but the .rbz file is an installation file used to install extension from within sketchup. If you go to Window/Preferences/Extensions tab and click install extension you can navigate to the file and install it that way.
                                  If you don't have a new enough version of SU the install extension button won't be there, either update SU or install the .rb manually. To get the .rb from the .rbz rename it to .zip and you'll find the .rb inside and you can extract it to your plugins folder.
                                    Mikaelo
                                    As said before, even if the plugin seems to be installed correct and then select an OBJ file to import, NOTHING happens, even for small files, even if I wait 5, 10, or more than 20 minutes for 500Kb sized OBJ files! Feel free to have a look on the following screenshots (for example by installing and using TIG's "obj_importer_v2.2.rbz" plugin).
                                    http://s27.postimg.org/t3i5lv0fn/001.jpg
                                    http://s27.postimg.org/mn4li12ib/002.jpg
                                    http://s27.postimg.org/jhjzrtjw3/003.jpg
                                    As already said, I have installed the v 8.0.15158, which I believe is the most recent "8" version before the "2013" version. The point is that the laptop, works with same SketchUp version, same Win XP version, can import OBJ files with any kind of method (plugin or FluidImporter) but is old & extremely slow to use for such purposes.
                                    Already tried that. No result!...
                                      OK...
                                      Back track.
                                      If it installed OK on another XP PC, then it should install on this similar one...
                                      Have you got the XP SP3 installed on both ?
                                      Also do you have the same Security permissions set for the subfolders within the SketchUp folder ?
                                      That is == ALL subfolders, like Plugins, AND Importers etc...
                                      Perhaps having limited permissions is affecting the importer's successful installation...
                                        Mikaelo
                                        @ TIG thanks for helping. You are an experienced user and I count on your oppinion.
                                        Yes, on the old & slow laptop is intsalled and works fine. Actually (and that the most weird thing that drives me crazy) it WAS installed and used to work OK on THIS PC, few days ago, before disc format and installing again Win XP. Same XP, same everything. I cannot understand, HOW it is possible for OJJ importer to work fine on PC and after format and re-install everything (by using the exact same exe files, my SketchUp denies to import OBJ files? How can be?
                                        Yes! From same CD. I "refresh" my PC / laptop once or twice a year, using always same Win XP features and always following same procedures. Never had problems before
                                        @tig said:
                                        Also do you have the same Security permissions set for the subfolders within the SketchUp folder ? That is == ALL subfolders, like Plugins, AND Importers etc...
                                        Everything is set on same options. I had the laptop side-byside with PC, and check every possible option within SketchUp. All same. Also, checked files & folders. All same too.
                                        Hmmm, what exactly you mean with "limited permissions"? How can be one working and other not, when both using the exact same software?
                                          Folders can have limited security permissions.
                                          These can affect the permissions of the enclosed files.
                                          Check the security permissions of the two folders and see if they differ ?
                                          This relates to Windows itself, not SketchUp or any application...
                                            Have you tried 'Repairing' SketchUp ?
                                            • 6 / 9
