    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 164.1k Views 79 Watching
      archigrafix
      Thanx to help TIG
      I have saved all leaves components in version 7 and now I get it to start...
      Anyway it creates the trunk but no leaves and I get this error message from ruby console:
      Error: #<NoMethodError: undefined method hue2rgb' for #<SketchupExtension::M3darcstudiotree::Cf3das_Colorset:0xf8a1cf0>> (eval):1774:in hsltorgb'
      (eval):1648:in initialize' (eval):1628:in each'
      (eval):1628:in initialize' (eval):2559:in new'
      (eval):2559:in drawstems' (eval):2394:in draw'
      (eval):667:in f3das_loadconfiguration' (eval):4443:in require'
      (eval):4443:in `call'
      Agir comme un homme de pensée, et penser comme un homme d'action...
      • ppoublanP Offline
        ppoublan
        @archigrafix said:
        Thanx to help TIG
        I need to debug with SU7. Seems SU7 interprets differently the ruby code. hue2rgb is a local definition within another one (hsltorgb). Should not be a method of the class. (is not with SU8).
        Here is the code that is working for SU8 and not SU7 if someone has an idea
        def hsltorgb(h, s, l)
        		if h<0.0
        			h=h+1.0
        		if h>1.0
        			h=h-1.0
        		if s<0.01
        			s=0.01
        		if s>0.99
        			s=0.99
        		if l<0.01
        			l=0.01
        		if l>0.99
        			l=0.99
        		if(s == 0)
        			r = g = b = l
        		else
        			def hue2rgb(p, q, t)
        				if(t < 0)
        					t = t + 1.0
        				if(t > 1)
        					t = t - 1.0
        				if(t < 1.0/6.0)
        					return p + (q - p) * 6.0 * t
        				if(t < 1.0/2.0)
        					return q
        				if(t < 2.0/3.0)
        					return p + (q - p) * (2.0/3.0 - t) * 6.0
        				return p
        			q = l < 0.5 ? l * (1.0 + s) ; l + s - l * s
        			p = 2.0 * l - q
        			r = hue2rgb(p, q, h + 1.0/3.0)
        			g = hue2rgb(p, q, h)
        			b = hue2rgb(p, q, h - 1.0/3.0)
        		return [r * 255, g * 255, b * 255]
        • ppoublanP Offline
          ppoublan
          ok I got it.
          Need to publish new version.
          Really strange that ruby code (without SU calls) not interpreted the same way.
          Will fix this today.
          Yours
          Pascal
            archigrafix
            @ppoublan said:
            ok I got it.
            Yours
            Pascal
            Thanx to help Pascal
            I will wait for it 😉
              kaas
              @alan fraser said:
              Brilliant plugin, Pascal...and very configurable.... 👍 👍 👍
              Brilliant indeed!
              The plugin is also very good at making 'low' polygon count trees. The picture is a tree made of nearly 3k faces and 6k edges (mostly the trunk and 3d branches), the leaf size is maximum with a branch texture applied to it.
              • KrisidiousK Offline
                Krisidious
                You guys are killin me... I want mine to work.
                By: Kristoff Rand
                • davids90gtD Offline
                  davids90gt
                  @krisidious said:
                  On SU 2013 Win, I'm getting this error on startup.
                  no such file to load -- 3darcstudio/3darcstudiotree.rbs
                  Error Loading File 3darcstudiotreeloader.rb
                  The file is in the location specified.
                  I'm getting this exact same thing. I have full permissions.
                    Krisidious
                    I'm not crazy... WooHoo...
                    By: Kristoff Rand
                    • ppoublanP Offline
                      ppoublan
                      @archigrafix said:
                      @ppoublan said:
                      ok I got it.
                      Yours
                      Pascal
                      Beta v0.93 published : (should work with SU7, but still to be tested)
                      • Fixed call to hue2rgb code incorrectly interpreted by SU7 (inline def usage)
                      • Converted skp leaves components to SU7 file format (hope it will work also with SU8)
                      • Fix of “up” flowers parameter bug
                      • Removed the dot at the end of comments between =begin and =end commands that generates errors loading script in some cases
                      Can be found here : http://3darcstudio.com/en/downloads-files/sketchup-plugins/206-3d-tree-maker-sketchup-plugin
                      Yours
                      Pascal
                      • ppoublanP Offline
                        ppoublan
                        I made tests with SU 2013 (free version). Seems to work, so I Will need more info to find the error cause.
                        • any other info within message box other than error loading file ?
                        • the loader is not scrambled and only few lines (less than 10), if someone else got similar issue when migrating to SU2013 ? Here is the code (I only removed the dots at the end of lines between =begin and =end.
                        =begin
                        Copyright 2012-2013 3DArcStudio
                        All Rights Reserved
                        THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
                        WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF
                        MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
                        =end
                        require 'sketchup.rb'
                        require 'extensions.rb'
                        extension = SketchupExtension.new '3DArcStudio Tree Maker', '3darcstudio/3darcstudiotree.rbs'
                        extension.creator = 'Pascal Poublan'
                        extension.version = '093'
                        extension.copyright = '2013, 3D Arc Studio. All rights reserved.'
                        extension.description = 'Sketchup Generic Trees Maker'
                        Sketchup.register_extension extension, true
                        • ppoublanP Offline
                          ppoublan
                          Dear all,
                          Here is a new tree template I like.
                          Extract the zip file to the plugins/3darcstudio directory and choose Vine Tree template when creating a tree.
                          Yours
                          tree maker template to copy to plugin 3darcstudio directory
                            Krisidious
                            I get the same error in both SU8 and SU2013.
                            Could this be a Pro Problem?
                            By: Kristoff Rand
                            • Alan FraserA Offline
                              Alan Fraser
                              Kris, are you running SU in Administrator mode? You can set the program exe file to do this every time in Properties. I had to do this some time ago when a few of Fredo's scripts were acting up (before he updated the library file)
                              I'm not saying it'll solve the problem, but it's worth a try. I've had that error in the past with other Rubies...infuriating when the 'missing' file is staring you in the face.
                              3D Figures
                                Check that everyone has FULL permissions to your Plugins folder [and that it trickles down to all subfolders/files etc...]
                                If you have a 'CREATOR OWNER' listed under Security try to remove it...
                                Use the 'Advanced...' options to Edit that...
                                Add yourself [or your 'group'] as the Owner.
                                The only three entries you need are SYSTEM, users-group and admins-group - and perhaps yourself - BUT you should be in the other two groups anyway!
                                You don't really need CREATOR OWNER or Trusted Installer...
                                Have the inherit properties check-box unchecked!
                                That combined with running it as administrator might alleviate these issues... 😕
                                  Krisidious
                                  Ok, I deleted Creator Owner and hit all of the permissions again.
                                  ran as administrator... same thing.
                                  By: Kristoff Rand
                                  • massimoM Offline
                                    massimo Moderator
                                    Do you have the same settings also for "Users"? If not, do the same for that.
                                      Krisidious
                                      path='C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs'
                                      File.exist?(path)
                                      true
                                      Load Path
                                      Error: #<NameError: (eval):155: uninitialized constant Path>
                                      (eval):155
                                      load path
                                      Error: #<SyntaxError: (eval):155:in load': C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: no .<digit> floating literal anymore; put 0 before dot RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: syntax error, unexpected tINTEGER RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: Invalid char \010' in expression>
                                      (eval):155
                                      (eval):155
                                      By: Kristoff Rand
                                        Krisidious
                                        yes... have it at the same.
                                        By: Kristoff Rand
                                          Alan Fraser
                                          That looks similar to my Plugins properties...except I have "CREATOR OWNER" on top of SYSTEM; and "Administrators(Alan-PC/Administrators)" underneath it.
                                          3D Figures
                                            Remove 'Trusted Installer'.
                                            The 'CREATOR OWNER' is optional - but if it inherits permissions from its container, then it might screw up things...
                                            Use the minimum number of 'users/groups' that you can get away with...
                                            Ensure that they ALL have FULL permissions.
                                            Do no 'inherit' any permissions...
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
