    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 217.7k Views 79 Watching
    • ppoublanP Offline
      ppoublan
      @krisidious said:
      @davids90gt said:
      @krisidious said:
      On SU 2013 Win, I'm getting this error on startup.
      no such file to load -- 3darcstudio/3darcstudiotree.rbs
      Error Loading File 3darcstudiotreeloader.rb
      The file is in the location specified.
      I'm getting this exact same thing. I have full permissions.
      I'm not crazy... WooHoo...
      I made tests with SU 2013 (free version). Seems to work, so I Will need more info to find the error cause.
      • any other info within message box other than error loading file ?
      • the loader is not scrambled and only few lines (less than 10), if someone else got similar issue when migrating to SU2013 ? Here is the code (I only removed the dots at the end of lines between =begin and =end.
      =begin
      Copyright 2012-2013 3DArcStudio
      All Rights Reserved
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
      WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF
      MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
      =end
      require 'sketchup.rb'
      require 'extensions.rb'
      extension = SketchupExtension.new '3DArcStudio Tree Maker', '3darcstudio/3darcstudiotree.rbs'
      extension.creator = 'Pascal Poublan'
      extension.version = '093'
      extension.copyright = '2013, 3D Arc Studio. All rights reserved.'
      extension.description = 'Sketchup Generic Trees Maker'
      Sketchup.register_extension extension, true
      • ppoublanP Offline
        ppoublan
        Dear all,
        Here is a new tree template I like.
        Extract the zip file to the plugins/3darcstudio directory and choose Vine Tree template when creating a tree.
        Yours
        tree maker template to copy to plugin 3darcstudio directory
        • KrisidiousK Offline
          Krisidious
          I get the same error in both SU8 and SU2013.
          Could this be a Pro Problem?
          By: Kristoff Rand
          • Alan FraserA Offline
            Alan Fraser
            Kris, are you running SU in Administrator mode? You can set the program exe file to do this every time in Properties. I had to do this some time ago when a few of Fredo's scripts were acting up (before he updated the library file)
            I'm not saying it'll solve the problem, but it's worth a try. I've had that error in the past with other Rubies...infuriating when the 'missing' file is staring you in the face.
            3D Figures
              Check that everyone has FULL permissions to your Plugins folder [and that it trickles down to all subfolders/files etc...]
              If you have a 'CREATOR OWNER' listed under Security try to remove it...
              Use the 'Advanced...' options to Edit that...
              Add yourself [or your 'group'] as the Owner.
              The only three entries you need are SYSTEM, users-group and admins-group - and perhaps yourself - BUT you should be in the other two groups anyway!
              You don't really need CREATOR OWNER or Trusted Installer...
              Have the inherit properties check-box unchecked!
              That combined with running it as administrator might alleviate these issues... πŸ˜•
                Krisidious
                Ok, I deleted Creator Owner and hit all of the permissions again.
                ran as administrator... same thing.
                By: Kristoff Rand
                • massimoM Offline
                  massimo Moderator
                  Do you have the same settings also for "Users"? If not, do the same for that.
                    Krisidious
                    path='C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs'
                    File.exist?(path)
                    true
                    Load Path
                    Error: #<NameError: (eval):155: uninitialized constant Path>
                    (eval):155
                    load path
                    Error: #<SyntaxError: (eval):155:in load': C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: no .<digit> floating literal anymore; put 0 before dot RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: syntax error, unexpected tINTEGER RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: Invalid char \010' in expression>
                    (eval):155
                    (eval):155
                    By: Kristoff Rand
                      Krisidious
                      yes... have it at the same.
                      By: Kristoff Rand
                        Alan Fraser
                        That looks similar to my Plugins properties...except I have "CREATOR OWNER" on top of SYSTEM; and "Administrators(Alan-PC/Administrators)" underneath it.
                        3D Figures
                          Remove 'Trusted Installer'.
                          The 'CREATOR OWNER' is optional - but if it inherits permissions from its container, then it might screw up things...
                          Use the minimum number of 'users/groups' that you can get away with...
                          Ensure that they ALL have FULL permissions.
                          Do no 'inherit' any permissions...
                            Krisidious
                            Done... Still problem persists...
                            By: Kristoff Rand
                              What's under the 'Owner' tab ?
                                Krisidious
                                By: Kristoff Rand
                                  Then you are screwed 😲
                                  I'm out of ideas... πŸ˜’
                                    Krisidious
                                    By: Kristoff Rand
                                      Krisidious
                                      By: Kristoff Rand
                                        Krisidious
                                        πŸ’­
                                        By: Kristoff Rand
                                          Krisidious
                                          Yes!
                                          It's a conflict.
                                          Removing all plugins from the plugins folder and it works.
                                          Now how can I figure out which one it is...
                                          By: Kristoff Rand
                                          • BoxB Offline
                                            Do the old half half trick, add half of them back, if they work try the other half, when you get a half that doesn't work halve it and repeat until you have the one precious.
                                            • 16
                                            • 17
                                            • 5 / 17
