    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 259.9k Views 79 Watching
      archigrafix
      Yes Kris nothing happens at all...just frustration 😲
      Agir comme un homme de pensée, et penser comme un homme d'action...
      • ppoublanP
        ppoublan
        Hi Kris,
        Sorry for that but I only tested it on SU8 as dev started after SU8 was available. Do not know what functions are not correctly supported by previous versions.
        Do you get at least the menu in plugins ?
        I you activate the Ruby console, do you get some messages in the console ?
        Yours
        Pascal
        • V
          versus
          I found the problem, perhaps due to a misspelling between lines = begin and = end, this is due only to a point out of place, just before = end, in my case, I have many plugins installed and thought it was due to one that caused the conflict, I tried an installation of SU 8 without additional plugins and charge well, it might be the WXP vs windows vista, in windows vista remove the point of the last sentence of the load file header specifically as follows:
          original
          AND FITNESS FOR A PARTICULAR PURPOSE.
          = end
          new
          = end
          in windows vista files are not loaded when I was at the end point of the line before = end, but in windows xp there was no problem loading the plugin
          another thing I did was copy the contents of the folder directly in the plugins folder of SU 8
            archigrafix
            @ppoublan said:
            Hi Kris,
            Yours
            Pascal
            Yes the menu is there...When I choice "Make tree" it returns:
            Error: #<RuntimeError: Can't insert empty component.>
            (eval):1050:in load' (eval):1050:in initialize'
            (eval):1042:in each' (eval):1042:in initialize'
            (eval):1217:in new' (eval):1217:in initialize'
            (eval):653:in new' (eval):653:in f3das_loadconfiguration'
            (eval):651:in each' (eval):651:in f3das_loadconfiguration'
            (eval):4443:in require' (eval):4443:in call'
            Hope you can help
              @archgrafix
              Are you sure that the specified component SKP exists in the tool's subfolder?
              If so can you open it in SketchUp?
              If it is getting found, then the 'empty component' error suggest that is either 'empty' [i.e. it contains no entities] or most likely it's been saved as a SketchUp version newer that the version that your current Model is opened in ??
              So for example, if the SKPs are v2013 and you try to use them in v8 it'll fail, or
              if the SKPs are v8 and you try to use them in v7 it'll fail and so on... Older version SKPs can be used with newer versions of SketchUp, but not vice versa...
              The tool's SKPs seem to ship as v8.
              Have you edited them in v2013, or trying to use them in SketchUp v7 ?
              So, if you open/edit any component SKP - like those in the tool's subfolder - then be sure to use 'Save_as' on it to put it back as being for an earlier version of SketchUp: so that it is then compatible when inserted as a component in earlier versions that it has just been edited in...
              PS: Please update your User-Profile to show your OS, Version etc...
              It helps us to help you...
              • Alan FraserA
                Alan Fraser
                Brilliant plugin, Pascal...and very configurable...both during and post production. 👍 👍 👍
                The tree on the left is a default Olive...but with simplified leaf geometry (down to 3 faces per leaf). It is now down to only 21,000 faces.
                The tree on the right is another default Olive, but with even simpler leaves (1 face) but double the number of leaves; and minus all the small twigs. This is down to only 12,000 faces. It was only 7000 before I doubled the leaf count (by simply selecting the foliage group, duplicating and rotating it.)
                3D Figures
                • KrisidiousK
                  Krisidious
                  You might want to just add that to you signature and save some time.
                  By: Kristoff Rand
                  • ppoublanP
                    ppoublan
                    @archigrafix said:
                    @ppoublan said:
                    Hi Kris,
                    Yours
                    Pascal
                    Hope you can help
                    This part of code is loading skp files as components. It seems that these files are not read by SU7. The solution may be to load them wiht SU8 and save them as SU7 skp format.
                      archigrafix
                      Thanx to help TIG
                      I have saved all leaves components in version 7 and now I get it to start...
                      Anyway it creates the trunk but no leaves and I get this error message from ruby console:
                      Error: #<NoMethodError: undefined method hue2rgb' for #<SketchupExtension::M3darcstudiotree::Cf3das_Colorset:0xf8a1cf0>> (eval):1774:in hsltorgb'
                      (eval):1648:in initialize' (eval):1628:in each'
                      (eval):1628:in initialize' (eval):2559:in new'
                      (eval):2559:in drawstems' (eval):2394:in draw'
                      (eval):667:in f3das_loadconfiguration' (eval):4443:in require'
                      (eval):4443:in `call'
                      • ppoublanP
                        ppoublan
                        @archigrafix said:
                        Thanx to help TIG
                        I need to debug with SU7. Seems SU7 interprets differently the ruby code. hue2rgb is a local definition within another one (hsltorgb). Should not be a method of the class. (is not with SU8).
                        Here is the code that is working for SU8 and not SU7 if someone has an idea
                        def hsltorgb(h, s, l)
                        		if h<0.0
                        			h=h+1.0
                        		if h>1.0
                        			h=h-1.0
                        		if s<0.01
                        			s=0.01
                        		if s>0.99
                        			s=0.99
                        		if l<0.01
                        			l=0.01
                        		if l>0.99
                        			l=0.99
                        		if(s == 0)
                        			r = g = b = l
                        		else
                        			def hue2rgb(p, q, t)
                        				if(t < 0)
                        					t = t + 1.0
                        				if(t > 1)
                        					t = t - 1.0
                        				if(t < 1.0/6.0)
                        					return p + (q - p) * 6.0 * t
                        				if(t < 1.0/2.0)
                        					return q
                        				if(t < 2.0/3.0)
                        					return p + (q - p) * (2.0/3.0 - t) * 6.0
                        				return p
                        			q = l < 0.5 ? l * (1.0 + s) ; l + s - l * s
                        			p = 2.0 * l - q
                        			r = hue2rgb(p, q, h + 1.0/3.0)
                        			g = hue2rgb(p, q, h)
                        			b = hue2rgb(p, q, h - 1.0/3.0)
                        		return [r * 255, g * 255, b * 255]
                        • ppoublanP
                          ppoublan
                          ok I got it.
                          Need to publish new version.
                          Really strange that ruby code (without SU calls) not interpreted the same way.
                          Will fix this today.
                          Yours
                          Pascal
                            archigrafix
                            @ppoublan said:
                            ok I got it.
                            Yours
                            Pascal
                            Thanx to help Pascal
                            I will wait for it 😉
                            • K
                              kaas
                              @alan fraser said:
                              Brilliant plugin, Pascal...and very configurable.... 👍 👍 👍
                              Brilliant indeed!
                              The plugin is also very good at making 'low' polygon count trees. The picture is a tree made of nearly 3k faces and 6k edges (mostly the trunk and 3d branches), the leaf size is maximum with a branch texture applied to it.
                              • KrisidiousK
                                Krisidious
                                You guys are killin me... I want mine to work.
                                By: Kristoff Rand
                                • davids90gtD
                                  davids90gt
                                  @krisidious said:
                                  On SU 2013 Win, I'm getting this error on startup.
                                  no such file to load -- 3darcstudio/3darcstudiotree.rbs
                                  Error Loading File 3darcstudiotreeloader.rb
                                  The file is in the location specified.
                                  I'm getting this exact same thing. I have full permissions.
                                  • KrisidiousK
                                    Krisidious
                                    I'm not crazy... WooHoo...
                                    By: Kristoff Rand
                                    • ppoublanP
                                      ppoublan
                                      @archigrafix said:
                                      @ppoublan said:
                                      ok I got it.
                                      Yours
                                      Pascal
                                      Beta v0.93 published : (should work with SU7, but still to be tested)
                                      • Fixed call to hue2rgb code incorrectly interpreted by SU7 (inline def usage)
                                      • Converted skp leaves components to SU7 file format (hope it will work also with SU8)
                                      • Fix of “up” flowers parameter bug
                                      • Removed the dot at the end of comments between =begin and =end commands that generates errors loading script in some cases
                                      Can be found here : http://3darcstudio.com/en/downloads-files/sketchup-plugins/206-3d-tree-maker-sketchup-plugin
                                      Yours
                                      Pascal
                                      • ppoublanP
                                        ppoublan
                                        I made tests with SU 2013 (free version). Seems to work, so I Will need more info to find the error cause.
                                        • any other info within message box other than error loading file ?
                                        • the loader is not scrambled and only few lines (less than 10), if someone else got similar issue when migrating to SU2013 ? Here is the code (I only removed the dots at the end of lines between =begin and =end.
                                        =begin
                                        Copyright 2012-2013 3DArcStudio
                                        All Rights Reserved
                                        THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
                                        WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF
                                        MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
                                        =end
                                        require 'sketchup.rb'
                                        require 'extensions.rb'
                                        extension = SketchupExtension.new '3DArcStudio Tree Maker', '3darcstudio/3darcstudiotree.rbs'
                                        extension.creator = 'Pascal Poublan'
                                        extension.version = '093'
                                        extension.copyright = '2013, 3D Arc Studio. All rights reserved.'
                                        extension.description = 'Sketchup Generic Trees Maker'
                                        Sketchup.register_extension extension, true
                                        • ppoublanP
                                          ppoublan
                                          Dear all,
                                          Here is a new tree template I like.
                                          Extract the zip file to the plugins/3darcstudio directory and choose Vine Tree template when creating a tree.
                                          Yours
                                          tree maker template to copy to plugin 3darcstudio directory
                                          • KrisidiousK
                                            Krisidious
                                            I get the same error in both SU8 and SU2013.
                                            Could this be a Pro Problem?
                                            By: Kristoff Rand
                                            • 16
                                            • 17
                                            • 4 / 17
