    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 217.7k Views 79 Watching
    • davids90gtD Offline
      davids90gt
      @krisidious said:
      On SU 2013 Win, I'm getting this error on startup.
      no such file to load -- 3darcstudio/3darcstudiotree.rbs
      Error Loading File 3darcstudiotreeloader.rb
      The file is in the location specified.
      I'm getting this exact same thing. I have full permissions.
      • KrisidiousK Offline
        Krisidious
        I'm not crazy... WooHoo...
        By: Kristoff Rand
        • ppoublanP Offline
          ppoublan
          @archigrafix said:
          @ppoublan said:
          ok I got it.
          Need to publish new version.
          Really strange that ruby code (without SU calls) not interpreted the same way.
          Will fix this today.
          Yours
          Pascal
          Thanx to help Pascal
          I will wait for it πŸ˜‰
          Beta v0.93 published : (should work with SU7, but still to be tested)
          • Fixed call to hue2rgb code incorrectly interpreted by SU7 (inline def usage)
          • Converted skp leaves components to SU7 file format (hope it will work also with SU8)
          • Fix of β€œup” flowers parameter bug
          • Removed the dot at the end of comments between =begin and =end commands that generates errors loading script in some cases
          Can be found here : http://3darcstudio.com/en/downloads-files/sketchup-plugins/206-3d-tree-maker-sketchup-plugin
          Yours
          Pascal
          • ppoublanP Offline
            ppoublan
            I made tests with SU 2013 (free version). Seems to work, so I Will need more info to find the error cause.
            • any other info within message box other than error loading file ?
            • the loader is not scrambled and only few lines (less than 10), if someone else got similar issue when migrating to SU2013 ? Here is the code (I only removed the dots at the end of lines between =begin and =end.
            =begin
            Copyright 2012-2013 3DArcStudio
            All Rights Reserved
            THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
            WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF
            MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
            =end
            require 'sketchup.rb'
            require 'extensions.rb'
            extension = SketchupExtension.new '3DArcStudio Tree Maker', '3darcstudio/3darcstudiotree.rbs'
            extension.creator = 'Pascal Poublan'
            extension.version = '093'
            extension.copyright = '2013, 3D Arc Studio. All rights reserved.'
            extension.description = 'Sketchup Generic Trees Maker'
            Sketchup.register_extension extension, true
            • ppoublanP Offline
              ppoublan
              Dear all,
              Here is a new tree template I like.
              Extract the zip file to the plugins/3darcstudio directory and choose Vine Tree template when creating a tree.
              Yours
              tree maker template to copy to plugin 3darcstudio directory
                Krisidious
                I get the same error in both SU8 and SU2013.
                Could this be a Pro Problem?
                By: Kristoff Rand
                • Alan FraserA Offline
                  Alan Fraser
                  Kris, are you running SU in Administrator mode? You can set the program exe file to do this every time in Properties. I had to do this some time ago when a few of Fredo's scripts were acting up (before he updated the library file)
                  I'm not saying it'll solve the problem, but it's worth a try. I've had that error in the past with other Rubies...infuriating when the 'missing' file is staring you in the face.
                  3D Figures
                    Check that everyone has FULL permissions to your Plugins folder [and that it trickles down to all subfolders/files etc...]
                    If you have a 'CREATOR OWNER' listed under Security try to remove it...
                    Use the 'Advanced...' options to Edit that...
                    Add yourself [or your 'group'] as the Owner.
                    The only three entries you need are SYSTEM, users-group and admins-group - and perhaps yourself - BUT you should be in the other two groups anyway!
                    You don't really need CREATOR OWNER or Trusted Installer...
                    Have the inherit properties check-box unchecked!
                    That combined with running it as administrator might alleviate these issues... πŸ˜•
                      Krisidious
                      Ok, I deleted Creator Owner and hit all of the permissions again.
                      ran as administrator... same thing.
                      By: Kristoff Rand
                      • massimoM Offline
                        massimo Moderator
                        Do you have the same settings also for "Users"? If not, do the same for that.
                          Krisidious
                          path='C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs'
                          File.exist?(path)
                          true
                          Load Path
                          Error: #<NameError: (eval):155: uninitialized constant Path>
                          (eval):155
                          load path
                          Error: #<SyntaxError: (eval):155:in load': C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: no .<digit> floating literal anymore; put 0 before dot RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: syntax error, unexpected tINTEGER RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: Invalid char \010' in expression>
                          (eval):155
                          (eval):155
                          By: Kristoff Rand
                            Krisidious
                            yes... have it at the same.
                            By: Kristoff Rand
                              Alan Fraser
                              That looks similar to my Plugins properties...except I have "CREATOR OWNER" on top of SYSTEM; and "Administrators(Alan-PC/Administrators)" underneath it.
                              3D Figures
                                Remove 'Trusted Installer'.
                                The 'CREATOR OWNER' is optional - but if it inherits permissions from its container, then it might screw up things...
                                Use the minimum number of 'users/groups' that you can get away with...
                                Ensure that they ALL have FULL permissions.
                                Do no 'inherit' any permissions...
                                  Krisidious
                                  Done... Still problem persists...
                                  By: Kristoff Rand
                                    What's under the 'Owner' tab ?
                                      Krisidious
                                      By: Kristoff Rand
                                        Then you are screwed 😲
                                        I'm out of ideas... πŸ˜’
                                          Krisidious
                                          By: Kristoff Rand
                                            Krisidious
                                            By: Kristoff Rand
                                            • 16
                                            • 17
                                            • 5 / 17
