    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 259.9k Views 79 Watching
    • ppoublanP
      ppoublan
      @archigrafix said:
      @ppoublan said:
      @archigrafix said:
      Yes Kris nothing happens at all...just frustration 😲
      Hi Kris,
      Sorry for that but I only tested it on SU8 as dev started after SU8 was available. Do not know what functions are not correctly supported by previous versions.
      Do you get at least the menu in plugins ?
      I you activate the Ruby console, do you get some messages in the console ?
      Yours
      Pascal
      Yes the menu is there...When I choice "Make tree" it returns:
      Error: #<RuntimeError: Can't insert empty component.>
      (eval):1050:in load' (eval):1050:in initialize'
      (eval):1042:in each' (eval):1042:in initialize'
      (eval):1217:in new' (eval):1217:in initialize'
      (eval):653:in new' (eval):653:in f3das_loadconfiguration'
      (eval):651:in each' (eval):651:in f3das_loadconfiguration'
      (eval):4443:in require' (eval):4443:in call'
      Hope you can help
      This part of code is loading skp files as components. It seems that these files are not read by SU7. The solution may be to load them wiht SU8 and save them as SU7 skp format.
        archigrafix
        Thanx to help TIG
        I have saved all leaves components in version 7 and now I get it to start...
        Anyway it creates the trunk but no leaves and I get this error message from ruby console:
        Error: #<NoMethodError: undefined method hue2rgb' for #<SketchupExtension::M3darcstudiotree::Cf3das_Colorset:0xf8a1cf0>> (eval):1774:in hsltorgb'
        (eval):1648:in initialize' (eval):1628:in each'
        (eval):1628:in initialize' (eval):2559:in new'
        (eval):2559:in drawstems' (eval):2394:in draw'
        (eval):667:in f3das_loadconfiguration' (eval):4443:in require'
        (eval):4443:in `call'
        Agir comme un homme de pensée, et penser comme un homme d'action...
        • ppoublanP
          ppoublan
          @archigrafix said:
          Thanx to help TIG
          I need to debug with SU7. Seems SU7 interprets differently the ruby code. hue2rgb is a local definition within another one (hsltorgb). Should not be a method of the class. (is not with SU8).
          Here is the code that is working for SU8 and not SU7 if someone has an idea
          def hsltorgb(h, s, l)
          		if h<0.0
          			h=h+1.0
          		if h>1.0
          			h=h-1.0
          		if s<0.01
          			s=0.01
          		if s>0.99
          			s=0.99
          		if l<0.01
          			l=0.01
          		if l>0.99
          			l=0.99
          		if(s == 0)
          			r = g = b = l
          		else
          			def hue2rgb(p, q, t)
          				if(t < 0)
          					t = t + 1.0
          				if(t > 1)
          					t = t - 1.0
          				if(t < 1.0/6.0)
          					return p + (q - p) * 6.0 * t
          				if(t < 1.0/2.0)
          					return q
          				if(t < 2.0/3.0)
          					return p + (q - p) * (2.0/3.0 - t) * 6.0
          				return p
          			q = l < 0.5 ? l * (1.0 + s) ; l + s - l * s
          			p = 2.0 * l - q
          			r = hue2rgb(p, q, h + 1.0/3.0)
          			g = hue2rgb(p, q, h)
          			b = hue2rgb(p, q, h - 1.0/3.0)
          		return [r * 255, g * 255, b * 255]
          • ppoublanP
            ppoublan
            ok I got it.
            Need to publish new version.
            Really strange that ruby code (without SU calls) not interpreted the same way.
            Will fix this today.
            Yours
            Pascal
              archigrafix
              @ppoublan said:
              ok I got it.
              Yours
              Pascal
              Thanx to help Pascal
              I will wait for it 😉
              • K
                kaas
                @alan fraser said:
                Brilliant plugin, Pascal...and very configurable.... 👍 👍 👍
                Brilliant indeed!
                The plugin is also very good at making 'low' polygon count trees. The picture is a tree made of nearly 3k faces and 6k edges (mostly the trunk and 3d branches), the leaf size is maximum with a branch texture applied to it.
                • KrisidiousK
                  Krisidious
                  You guys are killin me... I want mine to work.
                  By: Kristoff Rand
                  • davids90gtD
                    davids90gt
                    @krisidious said:
                    On SU 2013 Win, I'm getting this error on startup.
                    no such file to load -- 3darcstudio/3darcstudiotree.rbs
                    Error Loading File 3darcstudiotreeloader.rb
                    The file is in the location specified.
                    I'm getting this exact same thing. I have full permissions.
                    • KrisidiousK
                      Krisidious
                      I'm not crazy... WooHoo...
                      By: Kristoff Rand
                      • ppoublanP
                        ppoublan
                        @archigrafix said:
                        @ppoublan said:
                        ok I got it.
                        Yours
                        Pascal
                        Beta v0.93 published : (should work with SU7, but still to be tested)
                        • Fixed call to hue2rgb code incorrectly interpreted by SU7 (inline def usage)
                        • Converted skp leaves components to SU7 file format (hope it will work also with SU8)
                        • Fix of “up” flowers parameter bug
                        • Removed the dot at the end of comments between =begin and =end commands that generates errors loading script in some cases
                        Can be found here : http://3darcstudio.com/en/downloads-files/sketchup-plugins/206-3d-tree-maker-sketchup-plugin
                        Yours
                        Pascal
                        • ppoublanP
                          ppoublan
                          I made tests with SU 2013 (free version). Seems to work, so I Will need more info to find the error cause.
                          • any other info within message box other than error loading file ?
                          • the loader is not scrambled and only few lines (less than 10), if someone else got similar issue when migrating to SU2013 ? Here is the code (I only removed the dots at the end of lines between =begin and =end.
                          =begin
                          Copyright 2012-2013 3DArcStudio
                          All Rights Reserved
                          THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
                          WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF
                          MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
                          =end
                          require 'sketchup.rb'
                          require 'extensions.rb'
                          extension = SketchupExtension.new '3DArcStudio Tree Maker', '3darcstudio/3darcstudiotree.rbs'
                          extension.creator = 'Pascal Poublan'
                          extension.version = '093'
                          extension.copyright = '2013, 3D Arc Studio. All rights reserved.'
                          extension.description = 'Sketchup Generic Trees Maker'
                          Sketchup.register_extension extension, true
                          • ppoublanP
                            ppoublan
                            Dear all,
                            Here is a new tree template I like.
                            Extract the zip file to the plugins/3darcstudio directory and choose Vine Tree template when creating a tree.
                            Yours
                            tree maker template to copy to plugin 3darcstudio directory
                            • KrisidiousK
                              Krisidious
                              I get the same error in both SU8 and SU2013.
                              Could this be a Pro Problem?
                              By: Kristoff Rand
                              • Alan FraserA
                                Alan Fraser
                                Kris, are you running SU in Administrator mode? You can set the program exe file to do this every time in Properties. I had to do this some time ago when a few of Fredo's scripts were acting up (before he updated the library file)
                                I'm not saying it'll solve the problem, but it's worth a try. I've had that error in the past with other Rubies...infuriating when the 'missing' file is staring you in the face.
                                3D Figures
                                  Check that everyone has FULL permissions to your Plugins folder [and that it trickles down to all subfolders/files etc...]
                                  If you have a 'CREATOR OWNER' listed under Security try to remove it...
                                  Use the 'Advanced...' options to Edit that...
                                  Add yourself [or your 'group'] as the Owner.
                                  The only three entries you need are SYSTEM, users-group and admins-group - and perhaps yourself - BUT you should be in the other two groups anyway!
                                  You don't really need CREATOR OWNER or Trusted Installer...
                                  Have the inherit properties check-box unchecked!
                                  That combined with running it as administrator might alleviate these issues... 😕
                                  • KrisidiousK
                                    Krisidious
                                    Ok, I deleted Creator Owner and hit all of the permissions again.
                                    ran as administrator... same thing.
                                    By: Kristoff Rand
                                    • massimoM
                                      massimo Moderator
                                      Do you have the same settings also for "Users"? If not, do the same for that.
                                      • KrisidiousK
                                        Krisidious
                                        path='C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs'
                                        File.exist?(path)
                                        true
                                        Load Path
                                        Error: #<NameError: (eval):155: uninitialized constant Path>
                                        (eval):155
                                        load path
                                        Error: #<SyntaxError: (eval):155:in load': C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: no .<digit> floating literal anymore; put 0 before dot RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: syntax error, unexpected tINTEGER RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: Invalid char \010' in expression>
                                        (eval):155
                                        (eval):155
                                        By: Kristoff Rand
                                        • KrisidiousK
                                          Krisidious
                                          yes... have it at the same.
                                          By: Kristoff Rand
                                          • Alan FraserA
                                            Alan Fraser
                                            That looks similar to my Plugins properties...except I have "CREATOR OWNER" on top of SYSTEM; and "Administrators(Alan-PC/Administrators)" underneath it.
                                            3D Figures
                                            • 16
                                            • 17
                                            • 5 / 17
