    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 247.6k Views 79 Watching
      @archgrafix
      Are you sure that the specified component SKP exists in the tool's subfolder?
      If so can you open it in SketchUp?
      If it is getting found, then the 'empty component' error suggest that is either 'empty' [i.e. it contains no entities] or most likely it's been saved as a SketchUp version newer that the version that your current Model is opened in ??
      So for example, if the SKPs are v2013 and you try to use them in v8 it'll fail, or
      if the SKPs are v8 and you try to use them in v7 it'll fail and so on... Older version SKPs can be used with newer versions of SketchUp, but not vice versa...
      The tool's SKPs seem to ship as v8.
      Have you edited them in v2013, or trying to use them in SketchUp v7 ?
      So, if you open/edit any component SKP - like those in the tool's subfolder - then be sure to use 'Save_as' on it to put it back as being for an earlier version of SketchUp: so that it is then compatible when inserted as a component in earlier versions that it has just been edited in...
      PS: Please update your User-Profile to show your OS, Version etc...
      It helps us to help you...
      • Alan FraserA Offline
        Alan Fraser
        Brilliant plugin, Pascal...and very configurable...both during and post production. 👍 👍 👍
        The tree on the left is a default Olive...but with simplified leaf geometry (down to 3 faces per leaf). It is now down to only 21,000 faces.
        The tree on the right is another default Olive, but with even simpler leaves (1 face) but double the number of leaves; and minus all the small twigs. This is down to only 12,000 faces. It was only 7000 before I doubled the leaf count (by simply selecting the foliage group, duplicating and rotating it.)
        3D Figures
        • KrisidiousK Offline
          Krisidious
          You might want to just add that to you signature and save some time.
          By: Kristoff Rand
          • ppoublanP Offline
            ppoublan
            @archigrafix said:
            @ppoublan said:
            @archigrafix said:
            Yes Kris nothing happens at all...just frustration 😲
            Hi Kris,
            Sorry for that but I only tested it on SU8 as dev started after SU8 was available. Do not know what functions are not correctly supported by previous versions.
            Do you get at least the menu in plugins ?
            I you activate the Ruby console, do you get some messages in the console ?
            Yours
            Pascal
            Yes the menu is there...When I choice "Make tree" it returns:
            Error: #<RuntimeError: Can't insert empty component.>
            (eval):1050:in load' (eval):1050:in initialize'
            (eval):1042:in each' (eval):1042:in initialize'
            (eval):1217:in new' (eval):1217:in initialize'
            (eval):653:in new' (eval):653:in f3das_loadconfiguration'
            (eval):651:in each' (eval):651:in f3das_loadconfiguration'
            (eval):4443:in require' (eval):4443:in call'
            Hope you can help
            This part of code is loading skp files as components. It seems that these files are not read by SU7. The solution may be to load them wiht SU8 and save them as SU7 skp format.
              archigrafix
              Thanx to help TIG
              I have saved all leaves components in version 7 and now I get it to start...
              Anyway it creates the trunk but no leaves and I get this error message from ruby console:
              Error: #<NoMethodError: undefined method hue2rgb' for #<SketchupExtension::M3darcstudiotree::Cf3das_Colorset:0xf8a1cf0>> (eval):1774:in hsltorgb'
              (eval):1648:in initialize' (eval):1628:in each'
              (eval):1628:in initialize' (eval):2559:in new'
              (eval):2559:in drawstems' (eval):2394:in draw'
              (eval):667:in f3das_loadconfiguration' (eval):4443:in require'
              (eval):4443:in `call'
              Agir comme un homme de pensée, et penser comme un homme d'action...
              • ppoublanP Offline
                ppoublan
                @archigrafix said:
                Thanx to help TIG
                I need to debug with SU7. Seems SU7 interprets differently the ruby code. hue2rgb is a local definition within another one (hsltorgb). Should not be a method of the class. (is not with SU8).
                Here is the code that is working for SU8 and not SU7 if someone has an idea
                def hsltorgb(h, s, l)
                		if h<0.0
                			h=h+1.0
                		if h>1.0
                			h=h-1.0
                		if s<0.01
                			s=0.01
                		if s>0.99
                			s=0.99
                		if l<0.01
                			l=0.01
                		if l>0.99
                			l=0.99
                		if(s == 0)
                			r = g = b = l
                		else
                			def hue2rgb(p, q, t)
                				if(t < 0)
                					t = t + 1.0
                				if(t > 1)
                					t = t - 1.0
                				if(t < 1.0/6.0)
                					return p + (q - p) * 6.0 * t
                				if(t < 1.0/2.0)
                					return q
                				if(t < 2.0/3.0)
                					return p + (q - p) * (2.0/3.0 - t) * 6.0
                				return p
                			q = l < 0.5 ? l * (1.0 + s) ; l + s - l * s
                			p = 2.0 * l - q
                			r = hue2rgb(p, q, h + 1.0/3.0)
                			g = hue2rgb(p, q, h)
                			b = hue2rgb(p, q, h - 1.0/3.0)
                		return [r * 255, g * 255, b * 255]
                • ppoublanP Offline
                  ppoublan
                  ok I got it.
                  Need to publish new version.
                  Really strange that ruby code (without SU calls) not interpreted the same way.
                  Will fix this today.
                  Yours
                  Pascal
                    archigrafix
                    @ppoublan said:
                    ok I got it.
                    Yours
                    Pascal
                    Thanx to help Pascal
                    I will wait for it 😉
                      kaas
                      @alan fraser said:
                      Brilliant plugin, Pascal...and very configurable.... 👍 👍 👍
                      Brilliant indeed!
                      The plugin is also very good at making 'low' polygon count trees. The picture is a tree made of nearly 3k faces and 6k edges (mostly the trunk and 3d branches), the leaf size is maximum with a branch texture applied to it.
                        Krisidious
                        You guys are killin me... I want mine to work.
                        By: Kristoff Rand
                        • davids90gtD Offline
                          davids90gt
                          @krisidious said:
                          On SU 2013 Win, I'm getting this error on startup.
                          no such file to load -- 3darcstudio/3darcstudiotree.rbs
                          Error Loading File 3darcstudiotreeloader.rb
                          The file is in the location specified.
                          I'm getting this exact same thing. I have full permissions.
                            Krisidious
                            I'm not crazy... WooHoo...
                            By: Kristoff Rand
                            • ppoublanP Offline
                              ppoublan
                              @archigrafix said:
                              @ppoublan said:
                              ok I got it.
                              Yours
                              Pascal
                              Beta v0.93 published : (should work with SU7, but still to be tested)
                              • Fixed call to hue2rgb code incorrectly interpreted by SU7 (inline def usage)
                              • Converted skp leaves components to SU7 file format (hope it will work also with SU8)
                              • Fix of “up” flowers parameter bug
                              • Removed the dot at the end of comments between =begin and =end commands that generates errors loading script in some cases
                              Can be found here : http://3darcstudio.com/en/downloads-files/sketchup-plugins/206-3d-tree-maker-sketchup-plugin
                              Yours
                              Pascal
                              • ppoublanP Offline
                                ppoublan
                                I made tests with SU 2013 (free version). Seems to work, so I Will need more info to find the error cause.
                                • any other info within message box other than error loading file ?
                                • the loader is not scrambled and only few lines (less than 10), if someone else got similar issue when migrating to SU2013 ? Here is the code (I only removed the dots at the end of lines between =begin and =end.
                                =begin
                                Copyright 2012-2013 3DArcStudio
                                All Rights Reserved
                                THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
                                WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF
                                MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
                                =end
                                require 'sketchup.rb'
                                require 'extensions.rb'
                                extension = SketchupExtension.new '3DArcStudio Tree Maker', '3darcstudio/3darcstudiotree.rbs'
                                extension.creator = 'Pascal Poublan'
                                extension.version = '093'
                                extension.copyright = '2013, 3D Arc Studio. All rights reserved.'
                                extension.description = 'Sketchup Generic Trees Maker'
                                Sketchup.register_extension extension, true
                                • ppoublanP Offline
                                  ppoublan
                                  Dear all,
                                  Here is a new tree template I like.
                                  Extract the zip file to the plugins/3darcstudio directory and choose Vine Tree template when creating a tree.
                                  Yours
                                  tree maker template to copy to plugin 3darcstudio directory
                                    Krisidious
                                    I get the same error in both SU8 and SU2013.
                                    Could this be a Pro Problem?
                                    By: Kristoff Rand
                                      Alan Fraser
                                      Kris, are you running SU in Administrator mode? You can set the program exe file to do this every time in Properties. I had to do this some time ago when a few of Fredo's scripts were acting up (before he updated the library file)
                                      I'm not saying it'll solve the problem, but it's worth a try. I've had that error in the past with other Rubies...infuriating when the 'missing' file is staring you in the face.
                                      3D Figures
                                        Check that everyone has FULL permissions to your Plugins folder [and that it trickles down to all subfolders/files etc...]
                                        If you have a 'CREATOR OWNER' listed under Security try to remove it...
                                        Use the 'Advanced...' options to Edit that...
                                        Add yourself [or your 'group'] as the Owner.
                                        The only three entries you need are SYSTEM, users-group and admins-group - and perhaps yourself - BUT you should be in the other two groups anyway!
                                        You don't really need CREATOR OWNER or Trusted Installer...
                                        Have the inherit properties check-box unchecked!
                                        That combined with running it as administrator might alleviate these issues... 😕
                                          Krisidious
                                          Ok, I deleted Creator Owner and hit all of the permissions again.
                                          ran as administrator... same thing.
                                          By: Kristoff Rand
                                          • massimoM Offline
                                            massimo Moderator
                                            Do you have the same settings also for "Users"? If not, do the same for that.
                                            • 16
                                            • 17
                                            • 4 / 17
