    Sketchup 2013 issues
    208 Posts 53 Posters 54.8k Views 53 Watching
      Did you try right clicking the SU2013 icon and choosing Run as Admin?
      • plesiosaurP
        plesiosaur
        Rich, you're the man! Thanks!
        • KrisidiousK
          Krisidious
          I also have to re-select toolbars after restarting the system.
          By: Kristoff Rand
          • BoxB
            I can't for the life of me find how to turn off the "Welcome to sketchup" screen. It opens every time even if I already have SU open and will only go away by clicking, Start using.....
            Is this nagware that only goes away with Pro, or am I even more stupid than usual?
            • KrisidiousK
              Krisidious
              should be a check box to turn it off right in the window itself... at the bottom.
              By: Kristoff Rand
              • BoxB
                That was the first place I looked, but no.
                If you are telling me it does exist then I need to adjust my resolution again to find it.
                • BoxB
                  So are you saying Kristoff, that in the pro version it doesn't nag you each time.
                  • KrisidiousK
                    Krisidious
                    No, I'm saying it does. maybe it's because I'm still in evaluation?CaptureSUintro.JPG
                    By: Kristoff Rand
                    • KrisidiousK
                      Krisidious
                      You're right, mine is not there either...
                      By: Kristoff Rand
                      • BoxB
                        Ah Ok, so either it's annoying everyone that is using 13 or you and I are equally "Challenged"
                        • KrisidiousK
                          Krisidious
                          I've looked through preferences and found nothing.
                          By: Kristoff Rand
                            @penguin2 said:
                            Loaded the following from EW:-
                            'Selection Toys'
                            'Edge Tools2'
                            404 Not Found
                            (sketchucation.com)
                            • Dan RathbunD
                              Dan Rathbun
                              No you are not any dumber than usual. 😛
                              Yes the check box has been removed for the 2013 Make edition, and only appears in the Pro edition.
                              An omission from the "What's New" list... 😒
                              I'm not here much anymore.
                              • G
                                Garry K
                                Does anyone know of a registry entry that would disable the Nag screen?
                                I have a ruby script that I run at startup that draws a complete kitchen.
                                Version 7 - 17 seconds
                                Version 8 - 19 seconds
                                Version 2013 - 52 seconds
                                For what ever reason Version 8's graphics have less jaggies than Version 7 or Version 2013.
                                So - I'm not impressed.
                                  The nag [aka 'welcome'] screen 'show' setting is hard-coded into 'Make', it simply ignores the existing registry entry that is set 0/1 for 'Pro' by the check-box...
                                  So don't waste your time trying to circumvent it 😒
                                    Interesting. Is the operation wrapped in model.start_operation? And is the disable_ui argument set to true?
                                    • G
                                      Garry K
                                      I am not using model.start_operation.
                                        See if it makes a difference if you wrap it up into one operation - and use the disable_ui argument.
                                        • G
                                          Garry K
                                          I added in the code as you suggested.
                                          model.start_operation( "gkware", true )
                                          did all the work
                                          model.commit_operation
                                          Version 8 increased its time from 19 seconds to 90 seconds
                                          Version 2013 increased its time from 52 seconds to 64 seconds
                                          So - for those who are using start / commit then 2013 is faster. But for me - it's quite a bit slower.
                                            That is bizzare. I've never seen disable_ui make things slower. It's always been faster as it prevented the UI from updating while the operation ran.
                                            • 11
                                            • 5 / 11
