    Sketchup 2013 issues
    208 Posts 53 Posters 45.7k Views 53 Watching
    • plesiosaurP Offline
      plesiosaur
      FYI for those who use 3Dconnexion products:
      I am, or have been, using a 3Dconnecxion SpacePilot Pro with SU8; it appears that 3Dconnexion does not play well with SU2013, at least not for me.
      • Alan FraserA Offline
        Alan Fraser
        Unless that's a typo on your part, the fault may lie in the syntax. SketchUp shouldn't have a capital P.
        I can't say I've had any problem with any of Fredo's plugins...Round Corners included, after I upgraded the LibFredo6 Library files.
        3D Figures
        • BoxB Offline
          For those with missing toolbars, check that they aren't hiding under the others.
          There are a few that get stuck at the top left.
          Close all the others or drag them off the top. If there is one stuck there under "File" you can usually release it by double clicking on it.
            plesiosaur
            Alan, the syntax is per the SU2013 installation, just for kicks I renamed the folder with a lower case "p" - same error messages; I deleted all of the Fredo6 plugins and folders from my SU2013 plugins folder then re-re-installed all of them; again, same error messages. I may have to re-install SU2013 to see if that fixes it.
              Did you try right clicking the SU2013 icon and choosing Run as Admin?
                plesiosaur
                Rich, you're the man! Thanks!
                • KrisidiousK Offline
                  Krisidious
                  I also have to re-select toolbars after restarting the system.
                  By: Kristoff Rand
                  • BoxB Offline
                    I can't for the life of me find how to turn off the "Welcome to sketchup" screen. It opens every time even if I already have SU open and will only go away by clicking, Start using.....
                    Is this nagware that only goes away with Pro, or am I even more stupid than usual?
                      Krisidious
                      should be a check box to turn it off right in the window itself... at the bottom.
                      By: Kristoff Rand
                      • BoxB Offline
                        That was the first place I looked, but no.
                        If you are telling me it does exist then I need to adjust my resolution again to find it.
                        • BoxB Offline
                          So are you saying Kristoff, that in the pro version it doesn't nag you each time.
                            Krisidious
                            No, I'm saying it does. maybe it's because I'm still in evaluation?CaptureSUintro.JPG
                            By: Kristoff Rand
                              Krisidious
                              You're right, mine is not there either...
                              By: Kristoff Rand
                              • BoxB Offline
                                Ah Ok, so either it's annoying everyone that is using 13 or you and I are equally "Challenged"
                                  Krisidious
                                  I've looked through preferences and found nothing.
                                  By: Kristoff Rand
                                    @penguin2 said:
                                    Loaded the following from EW:-
                                    'Selection Toys'
                                    'Edge Tools2'
                                    404 Not Found
                                    (sketchucation.com)
                                    • Dan RathbunD Offline
                                      Dan Rathbun
                                      No you are not any dumber than usual. ๐Ÿ˜›
                                      Yes the check box has been removed for the 2013 Make edition, and only appears in the Pro edition.
                                      An omission from the "What's New" list... ๐Ÿ˜’
                                      I'm not here much anymore.
                                        Garry K
                                        Does anyone know of a registry entry that would disable the Nag screen?
                                        I have a ruby script that I run at startup that draws a complete kitchen.
                                        Version 7 - 17 seconds
                                        Version 8 - 19 seconds
                                        Version 2013 - 52 seconds
                                        For what ever reason Version 8's graphics have less jaggies than Version 7 or Version 2013.
                                        So - I'm not impressed.
                                          The nag [aka 'welcome'] screen 'show' setting is hard-coded into 'Make', it simply ignores the existing registry entry that is set 0/1 for 'Pro' by the check-box...
                                          So don't waste your time trying to circumvent it ๐Ÿ˜’
                                            Interesting. Is the operation wrapped in model.start_operation? And is the disable_ui argument set to true?
                                            • 11
                                            • 5 / 11
