    Sketchup 2013 issues
    208 Posts 53 Posters 59.1k Views 53 Watching
    • KrisidiousK
      Krisidious
      @box said:
      I can't for the life of me find how to turn off the "Welcome to sketchup" screen. It opens every time even if I already have SU open and will only go away by clicking, Start using.....
      Is this nagware that only goes away with Pro, or am I even more stupid than usual?
      should be a check box to turn it off right in the window itself... at the bottom.
      By: Kristoff Rand
      • BoxB
        That was the first place I looked, but no.
        If you are telling me it does exist then I need to adjust my resolution again to find it.
        • BoxB
          So are you saying Kristoff, that in the pro version it doesn't nag you each time.
          • KrisidiousK
            Krisidious
            No, I'm saying it does. maybe it's because I'm still in evaluation?CaptureSUintro.JPG
            By: Kristoff Rand
            • KrisidiousK
              Krisidious
              You're right, mine is not there either...
              By: Kristoff Rand
              • BoxB
                Ah Ok, so either it's annoying everyone that is using 13 or you and I are equally "Challenged"
                • KrisidiousK
                  Krisidious
                  I've looked through preferences and found nothing.
                  By: Kristoff Rand
                    @penguin2 said:
                    Loaded the following from EW:-
                    'Selection Toys'
                    'Edge Tools2'
                    404 Not Found
                    (sketchucation.com)
                    • Dan RathbunD
                      Dan Rathbun
                      No you are not any dumber than usual. 😛
                      Yes the check box has been removed for the 2013 Make edition, and only appears in the Pro edition.
                      An omission from the "What's New" list... 😒
                      I'm not here much anymore.
                      • G
                        Garry K
                        Does anyone know of a registry entry that would disable the Nag screen?
                        I have a ruby script that I run at startup that draws a complete kitchen.
                        Version 7 - 17 seconds
                        Version 8 - 19 seconds
                        Version 2013 - 52 seconds
                        For what ever reason Version 8's graphics have less jaggies than Version 7 or Version 2013.
                        So - I'm not impressed.
                          The nag [aka 'welcome'] screen 'show' setting is hard-coded into 'Make', it simply ignores the existing registry entry that is set 0/1 for 'Pro' by the check-box...
                          So don't waste your time trying to circumvent it 😒
                            Interesting. Is the operation wrapped in model.start_operation? And is the disable_ui argument set to true?
                            • G
                              Garry K
                              I am not using model.start_operation.
                                See if it makes a difference if you wrap it up into one operation - and use the disable_ui argument.
                                • G
                                  Garry K
                                  I added in the code as you suggested.
                                  model.start_operation( "gkware", true )
                                  did all the work
                                  model.commit_operation
                                  Version 8 increased its time from 19 seconds to 90 seconds
                                  Version 2013 increased its time from 52 seconds to 64 seconds
                                  So - for those who are using start / commit then 2013 is faster. But for me - it's quite a bit slower.
                                    That is bizzare. I've never seen disable_ui make things slower. It's always been faster as it prevented the UI from updating while the operation ran.
                                    • G
                                      Garry K
                                      When running code without the disable_ui I have to make certain that the Outliner is not visible - otherwise it is really slow.
                                      Here are 2 images of a kitchen. One in Sketchup 8 and the other in Sketchup 2013
                                      Sketchup 8
                                      Sketchup 2013
                                        For the images - the edge appear more jagged because you haven't exported with anti-aliasing.
                                        • G
                                          Garry K
                                          These aren't exported - I used a snipping tool to grab exactly what I see on screen.
                                          If you click on the images and compare them - Sketchup 8 is giving me better graphics.
                                          • G
                                            Garry K
                                            I figured it out - I had to play around with the OpenGL settings. Sketchup 2013 defaulted to 15 0x antialias whereas Sketchup 8 was using 40 4x.
                                            Now they are both rendering the same.
                                            • 11
                                            • 5 / 11
