    [Plugin][$] TopoShaper - v2.7a - 01 Apr 24
    451 Posts 143 Posters 669.3k Views 142 Watching
    • massimoM Offline
      massimo Moderator
      Have you observed the correct footprint? (See the first post of the thread)
        troyhome
        Ha! Silly mistake. Thanks!! works fine. 😳
        IOviz.com
        SU Pro 2024 PC
        • massimoM Offline
          massimo Moderator
          πŸ‘
          • * Offline
            **Ewie**
            Love the idea of this plugin but I'm having no success in getting it to work at all. I've followed the instruction to the letter, checked directories, updated the lib file.. but can't get it to work even with the sample files.
            The error message window does not appear, is there a log file located somewhere that I could send in hope of finding the problem??
            Cheers
              Ewan
              Open the Ruby Console.
              Then try running the tool.
              Report any error messages.
              Also check your Plugins folder's Properties > Security permissions are set to FULL for everyone in the list [Edit + Apply/OK]
              If not this might stop some log file etc getting written if you have limited rights...
                tspco
                Fredo, works like a champ here, installation was a tad tricky (no I don't remember what I did to make it work). After p[laying with this a few days, I ran across a issue. The terrain I have is a lake with several high hills around it, I would like to make the water one material and the hills another material, I tried a few gradients, found one close enough to work, but when rendering I cannot make the water reflective and the hills not. The system recognizes the material as one material. I tried freehanding the water areas, but who would of thought water wasn't level?. I know this is not really about this great plugin, but related. If anyone has any ideas please share them.
                SU make 2017, /Twilight Render Hobby
                Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                • Mistro11M Offline
                  Mistro11
                  I'm having a problem downloading. I'm using Internet Download Manager. I never had this problem downloading plugins before. Any Ideas?
                  i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                  Structural Integrity is Not Just Physical...It's in the Design and Purpose
                  • ElibjrE Offline
                    Elibjr
                    Thanks. This is simply amazing. Fredo6 you are too kind!
                      TeKnoel
                      This is Amazing!!!! There have been tools that let you get to something approaching this result in the past but they have never been this streamlined and powerful. Thank you very much.
                        rv1974
                        Hi Fredo, I have a couple questions\requests(?), may be you could kindly help:
                        How would I:
                        1.precisely respect given contours (see the red clouds in attachment)
                        2.predictably set the grid direction (could toposhaper respect the current UCS, including grid origin point would start at current x=0,y=0,z=0?)
                        3.is there specific reason for minimum number of 20 cells? Setting (alternatively) the grid's physical dimentions would be nice too).
                        Thank you in advance.
                        • fredo6F Offline
                          How would I:
                          On 1), respecting contours, this is difficult and would not give smooth results. What I can maybe do is 'almost' respect 'some' contours.
                          On 2), it would be fairly possible to set the origin and orientation of the grid. This is just GUI to add.
                          on 3), you can already enter the cell dimensions. just type them as float (for current unit) or float + unit. architectural unique are accepted. This works in the VCB and in the dialog boxes. Otherwise, there is a minimum limit to the grid size, because otherwise you would not see anything.
                            rv1974
                            Fredo, thank you for clarification πŸ‘
                            and hoping for p.2 will come true in some up-coming point update.
                              sridhar
                              Hi Fredo,
                              Tried using the plugin, it allows me to select and then quickly flashes the cleansing screen and generates a flat rectangular surface and contours as guidelines.
                              I have installed as instructed.
                              Am i missing something
                              Regards
                              Sridhar
                              • fredo6F Offline
                                @sridhar said:
                                Hi Fredo,
                                Regards
                                Sridhar
                                The default view for the Cleansing is the map view. Are your original contours given an elevation?
                                The best would be to post your model
                                  sridhar
                                  @sridhar said:
                                  Hi Fredo,
                                  Regards
                                  Sridhar
                                  Hi sending the screenshot
                                  thanks
                                  • fredo6F Offline
                                    @Sridhar
                                    It seems you miss the button palette
                                      sridhar
                                      @Sridhar
                                      The button comes briefly and then exits out of the plugin with an output shown above,
                                      Regards
                                      Sridhar
                                      • fredo6F Offline
                                        @sridhar said:
                                        Regards
                                        Sridhar
                                        Could you open the Ruby console and report of the error message you see.
                                        Your model seems complex and there may be some issues
                                        Thanks very much
                                          chris87
                                          @sridhar said:
                                          Regards
                                          Sridhar
                                          Thanks very much
                                          I have the same problem.
                                          The rod of Topshaper tools also disappears to this level.
                                          No message of mistake in the Ruby console.
                                          This problem even occurs with the well stocked examples.
                                          • fredo6F Offline
                                            @chris87, @sridhar
                                            Could check that if you type Return, you go to the next step (preview). You can also check the contextual menu.
                                            By the way, which OS are you on?
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
