    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 892.4k Views 144 Watching
      rv1974
      Fantastic! thank you Fredo for sharing.
      • P
        publied
        no words. one only: amazing!
        +thank you
        hire me@ http://www.publied.it !
        • T
          torring
          thanks fredo... your the man
          • T
            tspco
            Very cool Fredo!. Since I used to grab terrains from within SU that were supposed to be geolocated and truthful...I grabbed one today, used the contour tool, to generate the iso-lines then deleted the terrain I grabbed. Used TopoShaper to redo the terrain. It worked well after a few attempts thank you very much!. All is not perfect however, I tried to project a gradient material to the terrain, and I ended up with a bunch of different colored triangles, not a smooth texture, I will see if I can figure out what I did wrong...
            SU make 2017, /Twilight Render Hobby
            Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
            • P
              pjkm21
              Really Thank You!! A real Master!
              • W
                Whaat
                Just seeing this now for the first time. Pure brilliance! ๐Ÿ‘ ๐Ÿ‘ Another incredible addition!
                • mitcorbM
                  mitcorb
                  @Whaat:
                  see this example: http://sketchucation.com/forums/viewtopic.php?f=81&t=52237
                  • troyhomeT
                    troyhome
                    Not sure what's going on here
                    Any ideas why I get this when starting SU after installing TopoShaper?
                    IOviz.com
                    SU Pro 2024 PC
                    • massimoM
                      massimo Moderator
                      Have you observed the correct footprint? (See the first post of the thread)
                      • troyhomeT
                        troyhome
                        Ha! Silly mistake. Thanks!! works fine. ๐Ÿ˜ณ
                        IOviz.com
                        SU Pro 2024 PC
                        • massimoM
                          massimo Moderator
                          ๐Ÿ‘
                            **Ewie**
                            Love the idea of this plugin but I'm having no success in getting it to work at all. I've followed the instruction to the letter, checked directories, updated the lib file.. but can't get it to work even with the sample files.
                            The error message window does not appear, is there a log file located somewhere that I could send in hope of finding the problem??
                            Cheers
                              Ewan
                              Open the Ruby Console.
                              Then try running the tool.
                              Report any error messages.
                              Also check your Plugins folder's Properties > Security permissions are set to FULL for everyone in the list [Edit + Apply/OK]
                              If not this might stop some log file etc getting written if you have limited rights...
                              • T
                                tspco
                                Fredo, works like a champ here, installation was a tad tricky (no I don't remember what I did to make it work). After p[laying with this a few days, I ran across a issue. The terrain I have is a lake with several high hills around it, I would like to make the water one material and the hills another material, I tried a few gradients, found one close enough to work, but when rendering I cannot make the water reflective and the hills not. The system recognizes the material as one material. I tried freehanding the water areas, but who would of thought water wasn't level?. I know this is not really about this great plugin, but related. If anyone has any ideas please share them.
                                • Mistro11M
                                  Mistro11
                                  I'm having a problem downloading. I'm using Internet Download Manager. I never had this problem downloading plugins before. Any Ideas?
                                  Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                  • ElibjrE
                                    Elibjr
                                    Thanks. This is simply amazing. Fredo6 you are too kind!
                                    • T
                                      TeKnoel
                                      This is Amazing!!!! There have been tools that let you get to something approaching this result in the past but they have never been this streamlined and powerful. Thank you very much.
                                        rv1974
                                        Hi Fredo, I have a couple questions\requests(?), may be you could kindly help:
                                        How would I:
                                        1.precisely respect given contours (see the red clouds in attachment)
                                        2.predictably set the grid direction (could toposhaper respect the current UCS, including grid origin point would start at current x=0,y=0,z=0?)
                                        3.is there specific reason for minimum number of 20 cells? Setting (alternatively) the grid's physical dimentions would be nice too).
                                        Thank you in advance.
                                        • fredo6F
                                          How would I:
                                          On 1), respecting contours, this is difficult and would not give smooth results. What I can maybe do is 'almost' respect 'some' contours.
                                          On 2), it would be fairly possible to set the origin and orientation of the grid. This is just GUI to add.
                                          on 3), you can already enter the cell dimensions. just type them as float (for current unit) or float + unit. architectural unique are accepted. This works in the VCB and in the dialog boxes. Otherwise, there is a minimum limit to the grid size, because otherwise you would not see anything.
                                            rv1974
                                            Fredo, thank you for clarification ๐Ÿ‘
                                            and hoping for p.2 will come true in some up-coming point update.
                                            • 22
                                            • 23
                                            • 3 / 23
