    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 892.4k Views 144 Watching
    • fredo6F
      @rv1974 said:
      Hi Fredo, I have a couple questions\requests(?), may be you could kindly help:
      How would I:
      1.precisely respect given contours (see the red clouds in attachment)
      2.predictably set the grid direction (could toposhaper respect the current UCS, including grid origin point would start at current x=0,y=0,z=0?)
      3.is there specific reason for minimum number of 20 cells? Setting (alternatively) the grid's physical dimentions would be nice too).
      Thank you in advance.
      On 1), respecting contours, this is difficult and would not give smooth results. What I can maybe do is 'almost' respect 'some' contours.
      On 2), it would be fairly possible to set the origin and orientation of the grid. This is just GUI to add.
      on 3), you can already enter the cell dimensions. just type them as float (for current unit) or float + unit. architectural unique are accepted. This works in the VCB and in the dialog boxes. Otherwise, there is a minimum limit to the grid size, because otherwise you would not see anything.
        rv1974
        Fredo, thank you for clarification 👍
        and hoping for p.2 will come true in some up-coming point update.
          sridhar
          Hi Fredo,
          Tried using the plugin, it allows me to select and then quickly flashes the cleansing screen and generates a flat rectangular surface and contours as guidelines.
          I have installed as instructed.
          Am i missing something
          Regards
          Sridhar
          • fredo6F
            @sridhar said:
            Hi Fredo,
            Regards
            Sridhar
            The default view for the Cleansing is the map view. Are your original contours given an elevation?
            The best would be to post your model
              sridhar
              @sridhar said:
              Hi Fredo,
              Regards
              Sridhar
              Hi sending the screenshot
              thanks
              • fredo6F
                @Sridhar
                It seems you miss the button palette
                  sridhar
                  @Sridhar
                  The button comes briefly and then exits out of the plugin with an output shown above,
                  Regards
                  Sridhar
                  • fredo6F
                    @sridhar said:
                    Regards
                    Sridhar
                    Could you open the Ruby console and report of the error message you see.
                    Your model seems complex and there may be some issues
                    Thanks very much
                    • C
                      chris87
                      @sridhar said:
                      Regards
                      Sridhar
                      Thanks very much
                      I have the same problem.
                      The rod of Topshaper tools also disappears to this level.
                      No message of mistake in the Ruby console.
                      This problem even occurs with the well stocked examples.
                      • fredo6F
                        @chris87, @sridhar
                        Could check that if you type Return, you go to the next step (preview). You can also check the contextual menu.
                        By the way, which OS are you on?
                        • C
                          chris87
                          @fredo6 said:
                          @chris87, @sridhar
                          OS :
                          PC windows 7 - sketchup 8 pro last version-
                          No action occurs with the key return
                          the contextual menu "toposhaper --- > generate land (square maillage)" makes the previous operation throw back only.
                          the toposhaper toolbar doesn't reappear.
                          excuse me for the bad english language (french user....)
                          best regards and thank you for your superb plugins...
                          • B
                            bhbarchitects
                            Great plugin love it!
                              **Ewie**
                              @tig said:
                              Ewan
                              Open the Ruby Console.
                              Then try running the tool.
                              Report any error messages.
                              Also check your Plugins folder's Properties > Security permissions are set to FULL for everyone in the list [Edit + Apply/OK]
                              If not this might stop some log file etc getting written if you have limited rights...
                              Hi TIG, sorry for the tardy reply, I didn't get a notification of the replies on this thread..
                              I checked permissions on the plugin folder; all full control so no issues there.
                              Re-ran the plugin with the ruby script window open.. Same issue as before, this time using one of the sample files
                              Screen shot attached to explain.
                                @Ewan
                                Have you tried reinstalling the whole Topo'toolset AND the latest LibFredo again.
                                That might jolt it into submission...
                                First, if you did a manual install check for misplaced files in the Plugins folder.
                                Then reinstall the Lib, then Topo'toolset - I recommend you get/use the "SketchUcation Plugin Store" and use its 'AutoInstall' feature, this will ensure that everything is always put into the right places...
                                • C
                                  chris87
                                  @tig said:
                                  @Ewan
                                  I have exactly the same problem.
                                  All is installed correctly with the good rights and with the last libraries.
                                  No error in the ruby console !!!!
                                    Can you post screenshots for Fredo to check...
                                    Of the Plugins folder showing the installed files/subfolder and the contents of the subfolder itself...
                                    • fredo6F
                                      @chris87, @ewan
                                      It may simply be a bug.
                                      I'll come back with some instructions in order to figure out what it could be.
                                      What would help me is that you tell me what you see in the contextual menu when you are in this screen (a screenshot is OK).
                                      • C
                                        chris87
                                        @fredo6 said:
                                        @chris87, @ewan
                                        screenshot
                                        • fredo6F
                                          Chris,
                                          I mean when you are within TopoShaper and have the display of your screenshot, right click and tell me what is the contextual menu.
                                          • C
                                            chris87
                                            @fredo6 said:
                                            Chris,
                                            Visible on my screenshot :
                                            right click
                                            toposhaper ---- > générer terrain (maillage carré)
                                            best regards
                                            • 22
                                            • 23
                                            • 4 / 23
