    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
    • mitcorbM
      mitcorb
      @Whaat:
      see this example: http://sketchucation.com/forums/viewtopic.php?f=81&t=52237
      • troyhomeT
        troyhome
        Not sure what's going on here
        Any ideas why I get this when starting SU after installing TopoShaper?
        IOviz.com
        SU Pro 2024 PC
        • massimoM
          massimo Moderator
          Have you observed the correct footprint? (See the first post of the thread)
          • troyhomeT
            troyhome
            Ha! Silly mistake. Thanks!! works fine. 😳
            IOviz.com
            SU Pro 2024 PC
            • massimoM
              massimo Moderator
                **Ewie**
                Love the idea of this plugin but I'm having no success in getting it to work at all. I've followed the instruction to the letter, checked directories, updated the lib file.. but can't get it to work even with the sample files.
                The error message window does not appear, is there a log file located somewhere that I could send in hope of finding the problem??
                Cheers
                  Ewan
                  Open the Ruby Console.
                  Then try running the tool.
                  Report any error messages.
                  Also check your Plugins folder's Properties > Security permissions are set to FULL for everyone in the list [Edit + Apply/OK]
                  If not this might stop some log file etc getting written if you have limited rights...
                  • T
                    tspco
                    Fredo, works like a champ here, installation was a tad tricky (no I don't remember what I did to make it work). After p[laying with this a few days, I ran across a issue. The terrain I have is a lake with several high hills around it, I would like to make the water one material and the hills another material, I tried a few gradients, found one close enough to work, but when rendering I cannot make the water reflective and the hills not. The system recognizes the material as one material. I tried freehanding the water areas, but who would of thought water wasn't level?. I know this is not really about this great plugin, but related. If anyone has any ideas please share them.
                    SU make 2017, /Twilight Render Hobby
                    Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                    • Mistro11M
                      Mistro11
                      I'm having a problem downloading. I'm using Internet Download Manager. I never had this problem downloading plugins before. Any Ideas?
                      Structural Integrity is Not Just Physical...It's in the Design and Purpose
                      • ElibjrE
                        Elibjr
                        Thanks. This is simply amazing. Fredo6 you are too kind!
                        • T
                          TeKnoel
                          This is Amazing!!!! There have been tools that let you get to something approaching this result in the past but they have never been this streamlined and powerful. Thank you very much.
                            rv1974
                            Hi Fredo, I have a couple questions\requests(?), may be you could kindly help:
                            How would I:
                            1.precisely respect given contours (see the red clouds in attachment)
                            2.predictably set the grid direction (could toposhaper respect the current UCS, including grid origin point would start at current x=0,y=0,z=0?)
                            3.is there specific reason for minimum number of 20 cells? Setting (alternatively) the grid's physical dimentions would be nice too).
                            Thank you in advance.
                            • fredo6F
                              How would I:
                              On 1), respecting contours, this is difficult and would not give smooth results. What I can maybe do is 'almost' respect 'some' contours.
                              On 2), it would be fairly possible to set the origin and orientation of the grid. This is just GUI to add.
                              on 3), you can already enter the cell dimensions. just type them as float (for current unit) or float + unit. architectural unique are accepted. This works in the VCB and in the dialog boxes. Otherwise, there is a minimum limit to the grid size, because otherwise you would not see anything.
                                rv1974
                                Fredo, thank you for clarification 👍
                                and hoping for p.2 will come true in some up-coming point update.
                                  sridhar
                                  Hi Fredo,
                                  Tried using the plugin, it allows me to select and then quickly flashes the cleansing screen and generates a flat rectangular surface and contours as guidelines.
                                  I have installed as instructed.
                                  Am i missing something
                                  Regards
                                  Sridhar
                                  • fredo6F
                                    @sridhar said:
                                    Hi Fredo,
                                    Regards
                                    Sridhar
                                    The default view for the Cleansing is the map view. Are your original contours given an elevation?
                                    The best would be to post your model
                                      sridhar
                                      @sridhar said:
                                      Hi Fredo,
                                      Regards
                                      Sridhar
                                      Hi sending the screenshot
                                      thanks
                                      • fredo6F
                                        @Sridhar
                                        It seems you miss the button palette
                                          sridhar
                                          @Sridhar
                                          The button comes briefly and then exits out of the plugin with an output shown above,
                                          Regards
                                          Sridhar
                                          • fredo6F
                                            @sridhar said:
                                            Regards
                                            Sridhar
                                            Could you open the Ruby console and report of the error message you see.
                                            Your model seems complex and there may be some issues
                                            Thanks very much
                                            • 22
                                            • 23
                                            • 4 / 23
