    [Plugin] CleanUp
    974 Posts 217 Posters 985.7k Views 217 Watching
      rs3sekar
      Thanks a lot - very useful tool
      • E Offline
        ephraimlord65
        Really cool ! Nice job and thanks a lot for this plugin ! πŸ˜‰
          Mybis
          Please disregard my question below. The std RBZ installer in my SU8 doesn't seem to work so having read some of your related info I simply changed the RBZ's to ZIP, unpacked them, and moved them to the plug in folder. PU's seem to work fine. Looking fwd to using your cleanup PI ... sounds awesome.
          Tks.
          Hi, I'm new to the plug in concept in SU so my apologies in advance.
          Im on Mac OS10.8.3 / SUpro V8.
          I am keen to install your cleanup PI and I keep getting the following error
          "SketchUp was unable to install the Extension you have chosen for some unknown reason.
          Consult your Extension's documentation for additional help"
          It seems to come up regardless of the rbz file that I am trying to install.
          Any advise will be greatly appreciated!
          scott
            That sounds like a issue that appear from time to time - where OSX users for some reason didn't have full access to the Plugins folder. Once they gave them selves full access they where able to use the RBZ installation feature.
            • ashscottA Offline
              ashscott
              Its a fantastic plugin thomthom, thanks very much
              Just some stuff I do with Sketchup.
                detcharles
                HELP!
                Hello,
                I have never posted before and I'm sorry to interrupt a conversation but I am having trouble installing the cleanup plugin. I keep getting an error message saying that google was not able to install the plugin for an unknown reason. I use V.8. and I am currently using a pro trial.
                  The most likely problem is that you haven't set up full read and write permissions for the Plugins folder. Do that and try to install again.
                  • plot-parisP Offline
                    plot-paris
                    Hey Thomthom,
                    I am using Cleanup every day (or every other minute pretty much). Even got a shortcut assigned that I use as naturally as a wet dog shakes itself dry - its become a reflex!
                    However, sometimes this reflex rips apart my models, especially when having used plugins like Curviloft prior to it or pretty much every time I import a .3ds file...
                    One such model is this shiny new Bialetti Espresso Maker (just finished modelling it πŸ˜„ ).
                    Bialetti_EspressoMaker.skp
                    When I run Cleanup over it, it gets destroyed. Even when I scale it up 100x...
                    Is there any way to change the cleanup settings to avoid this?
                    • massimoM Offline
                      massimo Moderator
                      Well it works fine for me, without scaling anything, with these settings:
                      • E Offline
                        edfishbone
                        Thanks in advance. Just installed cleanup. Looks great!
                        I have the TT Lib2 2.7.1 but the installer is calling for 2.8 which i cannot seem to find. The download link does not work.
                        best
                        screenshot
                          plot-paris
                          Hey Massimo,
                          it was the "Ignore Normals" setting. I had this one ticked. Now its working for me too.
                          Thanks for the help!
                          • massimoM Offline
                            massimo Moderator
                            πŸ‘
                            • W Offline
                              watkins
                              When using Fredo6's plugin checker it suggests that I do not have the most recent version of cleanup, even though I have installed it. The checker appears to be calling for an earlier version. What's up doc!
                                HELP!
                                As Dave mentions - this is some bug with SketchUp where some users doesn't have proper access to their plugins folder. I'm not a Mac guy, so I don't know the exact steps to correct the folder permissions. :s
                                  @plot-paris said:
                                  Hey Thomthom,
                                  When you scale up groups/components you scale only the instance - the definitions are still small. You'd have to "Scale Definitions" for the scaling trick to work.
                                  @plot-paris said:
                                  Hey Massimo,
                                  That's odd though, the normals of your model appeared to be correctly oriented and in any case it shouldn't break. But that's probably due to the very small size of the faces.
                                  You have a very old version of CleanUp. I'd recommend you update.
                                    Are you sure you installed TT_Lib2 correctly?
                                    What is returned if you open the Ruby Console (under Window menu) and type in TT::Lib::VERSION ?
                                    Also - when you say the link doesn't work - exactly what happens? Error m
                                    Also - when you say the link doesn't work - exactly what happens? Error messages?
                                      I don't know. Maybe fredo's checker only uses the first digit of the version number? Extracting the digit 1 from 10? I don't really know.
                                        Yes, since it says "Not Installed" it means you do not have TT_Lib2 installed. Had it been out of date it would have said "Outdated".
                                        I'm going to make a guess that you have placed the RBZ in the plugins folder directly. Note that RBZ files are not the same as RB files. RBZ files must be installed via the "Install Extension" function in SketchUp. (Window > Preferences > Extensions > Install Extension)
                                        For more info on how to install plugins or extensions: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                                        To make it even easier, have a look at SketchUcations plugin manager that will download and install plugins hosted on this site for you: http://sketchucation.com/resources/plugin-store-download
                                        • massimoM Offline
                                          massimo Moderator
                                          Yes I know, thanks. πŸ˜„
                                          I'll do.
                                          • E Offline
                                            edfishbone
                                            Thanks for the reply. I started again and used your simple installer, then the clean.rbz, and finally the TT_Lib2 file and it worked! I had originally used the plugin manager/store but somehow messed it up.
                                            Cheers!
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 48
                                            • 49
                                            • 38 / 49
