    [Plugin] CleanUp
    974 Posts 217 Posters 1.2m Views 217 Watching
      I'll repackage the plugin as an RBZ and better message for missing TT_Lib2.
        Piratestef
        with what settings should I clean up this file?
        https://www.dropbox.com/s/vpqng31chal8v4l/brad%20kussens.skp
        It keeps losing surfaces, could you work your magic and tell me what settings to use?
        I really hope this works!
          I'm out traveling so I cannot open the file right now. But I'll guess that the missing faces are very small. When edges are less near and less than 1mm things like that start happening. You'd then have to scale up the model.
          Note that scaling the instance won't work. You'd have to open up the group or component.
          Sent from my LT25i using Tapatalk 2
            Piratestef
            Ok so I scaled it with 200%, with what setting should I start the cleanup?
              I don't know what settings to recommend because I do not know what result you expect. All the settings are for different proposes.
              Btw, 2 times might not be enough scaling. You might have to scale up by 10, 100 or 1000 times.
                rs3sekar
                Thanks a lot - very useful tool
                • E Offline
                  ephraimlord65
                  Really cool ! Nice job and thanks a lot for this plugin ! 😉
                    Mybis
                    Please disregard my question below. The std RBZ installer in my SU8 doesn't seem to work so having read some of your related info I simply changed the RBZ's to ZIP, unpacked them, and moved them to the plug in folder. PU's seem to work fine. Looking fwd to using your cleanup PI ... sounds awesome.
                    Tks.
                    Hi, I'm new to the plug in concept in SU so my apologies in advance.
                    Im on Mac OS10.8.3 / SUpro V8.
                    I am keen to install your cleanup PI and I keep getting the following error
                    "SketchUp was unable to install the Extension you have chosen for some unknown reason.
                    Consult your Extension's documentation for additional help"
                    It seems to come up regardless of the rbz file that I am trying to install.
                    Any advise will be greatly appreciated!
                    scott
                      That sounds like a issue that appear from time to time - where OSX users for some reason didn't have full access to the Plugins folder. Once they gave them selves full access they where able to use the RBZ installation feature.
                      • ashscottA Offline
                        ashscott
                        Its a fantastic plugin thomthom, thanks very much
                        Just some stuff I do with Sketchup.
                          detcharles
                          HELP!
                          Hello,
                          I have never posted before and I'm sorry to interrupt a conversation but I am having trouble installing the cleanup plugin. I keep getting an error message saying that google was not able to install the plugin for an unknown reason. I use V.8. and I am currently using a pro trial.
                            The most likely problem is that you haven't set up full read and write permissions for the Plugins folder. Do that and try to install again.
                            • plot-parisP Offline
                              plot-paris
                              Hey Thomthom,
                              I am using Cleanup every day (or every other minute pretty much). Even got a shortcut assigned that I use as naturally as a wet dog shakes itself dry - its become a reflex!
                              However, sometimes this reflex rips apart my models, especially when having used plugins like Curviloft prior to it or pretty much every time I import a .3ds file...
                              One such model is this shiny new Bialetti Espresso Maker (just finished modelling it 😄 ).
                              Bialetti_EspressoMaker.skp
                              When I run Cleanup over it, it gets destroyed. Even when I scale it up 100x...
                              Is there any way to change the cleanup settings to avoid this?
                              • massimoM Offline
                                massimo Moderator
                                Well it works fine for me, without scaling anything, with these settings:
                                • E Offline
                                  edfishbone
                                  Thanks in advance. Just installed cleanup. Looks great!
                                  I have the TT Lib2 2.7.1 but the installer is calling for 2.8 which i cannot seem to find. The download link does not work.
                                  best
                                  screenshot
                                    plot-paris
                                    Hey Massimo,
                                    it was the "Ignore Normals" setting. I had this one ticked. Now its working for me too.
                                    Thanks for the help!
                                    • massimoM Offline
                                      massimo Moderator
                                      • W Offline
                                        watkins
                                        When using Fredo6's plugin checker it suggests that I do not have the most recent version of cleanup, even though I have installed it. The checker appears to be calling for an earlier version. What's up doc!
                                          HELP!
                                          As Dave mentions - this is some bug with SketchUp where some users doesn't have proper access to their plugins folder. I'm not a Mac guy, so I don't know the exact steps to correct the folder permissions. :s
                                            @plot-paris said:
                                            Hey Thomthom,
                                            When you scale up groups/components you scale only the instance - the definitions are still small. You'd have to "Scale Definitions" for the scaling trick to work.
                                            @plot-paris said:
                                            Hey Massimo,
                                            That's odd though, the normals of your model appeared to be correctly oriented and in any case it shouldn't break. But that's probably due to the very small size of the faces.
                                            You have a very old version of CleanUp. I'd recommend you update.
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 48
                                            • 49
                                            • 38 / 49
