    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 225.7k Views 52 Watching
      I've found a glitch with the code in 'GhostCompAlgo.rb'
      def onActivePathChanged(*args)
      	path = Sketchup.active_model.active_path
      	return unless path
      	comp = path.last
          return unless comp.valid? ###<<<
      	return unless is_ghost?(comp)
      	ask_confirmation comp
      If you don't include the extra line I've indicated with ###<<< then you get weird errors in the Ruby Console if you have been editing and then deleting Components... This simple fix ignores recently deleted components etc so no errors...
        Tig the ghost killer cleaner πŸ’š πŸ‘
          tfdesign
          Ghostbusters? πŸ˜‰
            mandar1983
            Hello,
            I have used ghost plug in to make proxy out of original object..
            I have kept object in proxy format and exported it to kerkythea.
            When i render it in kerkythea proxy object rendered without material why so?? Do we have convert the back to original form before exporting it into kerkythea every time??
            Also i have some issues regarding camera in kerkythea. i have placed 3 cameras in the scene and have exported to kerkythea, but whenever i open the scene, i could not find the camera on the same location i have placed it? is it any kind of bug in kerkythea?? or there is some problem in my SU and kerkythea or somthing else?? ple help
            Regards,
            MANDAR
              Yes, I am afraid you do. Ghost Components plugin can only solve performance issues in SU but it would not work as a proxy plugin for exporters. Certainly it could be modified somewhat (and/or the exporter plugin could accommodate) but for that, the two, different authors of the plugins should co-operate on one that works this way.
              But then all the other renderers could ask the same.
              • N Offline
                niks
                thanks Fredo.. you are a beast on what you do ❗ πŸ‘
                  scrappy24
                  Great work! "To God be the victory!" πŸ‘
                    rachmatrf
                    Wow! What a great plugin... 😍 😍 😍 😍
                    I can not thank you enough to make this possible on sketchup... Where have I been so far to miss this wonderful plugin. SU Team surely should incorporate this in SU native version. I believe they will put this in the new Trimble Sketchup... Great work Fredo!!! and thanks once again....
                      sellberg
                      Thanks for this! IΒ΄ve only had a short test/peek/session w this RB. It seems super useful!
                      I had one problem, though: I saved the model when in ghost mode and closed the program. When I opened the same model later I couldnΒ΄t reset the geometry to the complex form. I just saw the ghost. Have anyone else had similar experiences?
                      //KJS
                      Running a freeSU8 on a mac.
                        rv1974
                        Fredo,I just wondered would this dirty trick http://72.27.230.245/3ds-max/scripts/renderlayers-0 be possible in SU8?
                          congellous
                          This is a copy of my plug ins folder, I've upgraded to the new fredo lib and installed the ghost but nothing shows up in the program
                          Have I got some conflict in here, it's a mess !
                          __loader.rb
                          .DS_Store
                          #extrusionToolbar.rb
                          AddCtrPnt.rb
                          animation.rb
                          artisan
                          artisan_loader.rb
                          attributes.rb
                          Autounfold.rb
                          bezier.rb
                          box.rb
                          clf_shape_bender
                          clf_shape_bender_loader.rb
                          contextmenu.rb
                          ctsMaker
                          curve_maker.rb
                          CURVILOFT_Dir_12
                          deBabelizer.rb
                          DEFPARAM_Dir
                          DOCUMENTATION_Dir
                          drawhelix14.rb
                          drawmetal_plugins_1_3_4.rb
                          dropverts.rb
                          Examples
                          examples.rb
                          examplescripts.rb
                          extrudeEdgesByEdges.rb
                          extrudeEdgesByFace.rb
                          extrudeEdgesByFaces.rb
                          extrudeEdgesByLathe.rb
                          extrudeEdgesByLoft.rb
                          extrudeEdgesByOffset.rb
                          extrudeEdgesByRails.rb
                          extrudeEdgesByRailsByFace.rb
                          extrudeEdgesByRailsToLattice.rb
                          extrudeEdgesByVector.rb
                          extrudeEdgesByVectorToObject.rb
                          faceFlattener019.rb
                          fillet.rb
                          flattery
                          flattery.rb
                          Fredo6Trace.txt
                          FREDOSCALE
                          FREDOSCALE_Dir_22
                          FredoScale_Tool.rb
                          FredoScale.rb
                          generateSoapSkinBubble.rbs
                          Geodesic_SketchUp.rb
                          GhostComp%201
                          Help
                          iges_export.rb
                          Images
                          jointpushpull.rb
                          JPP_Dir_20
                          LIBFREDO6_Dir_48
                          LibFredo6.rb
                          LibTraductor.rb
                          linetool.rb
                          maxwell
                          maxwell.rb
                          Ocean
                          ocean_extension.rb
                          proper_animation
                          proper_animation_loader.rb
                          ROUNDCORNER
                          ROUNDCORNER_Dir_23
                          RoundCorner.rb
                          RubyToPython
                          SCF
                          selection.rb
                          shapes.rb
                          SketchyFFD.rb
                          skin.rb
                          skp_to_dxf.rb
                          skp_to_dxf.rbz
                          SoapSkinBubble
                          Help
                          Images
                          SoapSkinBubbleMenus.rb
                          SoapSkinBubbleTools.rb
                          stock_maker.rb
                          SU_Podium_Browser.rbs
                          SU_Podium_V2
                          SU_Podium_V2.rbs
                          SuSolid
                          susolid.rbs
                          taper_maker.rb
                          TIGtools
                          TOS
                          TOS_Dir_18
                          tt_cleanup.rb
                          TT_Lib2
                          tt_simple_installer.rb
                          tt_solid_inspector.rb
                          unfoldtool.rb
                          Utilities
                          utilities.rb
                          utilities.rbs
                          utilitiestools.rb
                          vfs.rb
                          weld.rb
                          ZLoader__FredoScale.rb
                          ZLoader__GhostComp.rb
                          ZLoader__OnSurface.rb
                          ZLoader__RoundCorner.rb
                            Have you activated its Extension from within Preferences.
                            You might also then need to activate its Toolbar...
                              congellous
                              There doesn't seem to be an extension in there ?
                              It has instal extension which one is the extension ?
                                  congellous
                                  Yeah it's not there
                                    In your list there's 'GhostComp%201' what's that ?
                                    Looks like an html based name ?
                                    There ought to be a folder called 'GHOSTCOMP_Dir_10'
                                    containing these files Capture.PNG This suggests you has mis-installed it...
                                      congellous
                                      Dunno what that was but removing it sorted it, didn't even need to turn the extension on. Thanks TIG
                                        parsleybrain
                                        Hello Fredo, thanks for another great plugin. So I startet to use it and it worked just fine. I've lots of railings in my model, some are just copies of components but I also had to make a bunch of them unique and to tweak them. Finally making even one copy of an component took so long I decided to use your ghostcomp. And it worked - but now Sketchup always chrashes when I try to create a ghost component. Do you have any advice or idea what to do about that? Thanks in advance.
                                        • fredo6F Offline
                                          Please make sure you have the most recent versions. For the crash, it may be some conflicting plugins (some versions of Vray and Podium for instance)
                                          • fredo6F Offline
                                            NEW RELEASE: GhostComp v1.1a - 27 Nov 13
                                            GhostComp 1.1a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                                            • 3 / 6
