    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 220.9k Views 52 Watching
      ALFRED
      Hello! I am from Russia. Warning! my english is very bad!, Thanks Fredo for a magnificent plug-in πŸ‘ , it some kind of rescue for users of weak computers at work in 3d window, by the way, would be very abruptly if this plug-in could be used as "Vray Proxy" πŸ˜‰ Π‘an Vray use the Ghost components during visualization?
      • fredo6F Offline
        Pavel,
        I don't know VRay, but I doubt the concept of proxy for Vray matches Ghostcomp.
        Actually, Ghostcomp is really conceptual. This is a good example of what Sketchup should do natively, in much better and simple way, including being able to connect the concept to rendering software.
          V-Ray for SketchUp cannot currently use proxies.
          • Y Offline
            yolibs
            to make a render is it necessary to turn components to their real version???
            or they can be in ghost version?
            pls i need help!!
              Yes, unfortunately.
                rv1974
                This tool is essential for those who send files with repetitive components to 3ds max.
                Unfortunatly only after removing this tool I solved the "grey out menus" problem. Is there any chance to update it?
                  Have you updated your FredoLib files? I think most the issues lied within that library, not in the individual plugins. (with an odd exception)
                    rv1974
                    Yes I used latest lib pack (not 100% sure). Today I'll try it once more
                    • TIGT Online
                      I've found a glitch with the code in 'GhostCompAlgo.rb'
                      def onActivePathChanged(*args)
                      	path = Sketchup.active_model.active_path
                      	return unless path
                      	comp = path.last
                          return unless comp.valid? ###<<<
                      	return unless is_ghost?(comp)
                      	ask_confirmation comp
                      If you don't include the extra line I've indicated with ###<<< then you get weird errors in the Ruby Console if you have been editing and then deleting Components... This simple fix ignores recently deleted components etc so no errors...
                        Tig the ghost killer cleaner πŸ’š πŸ‘
                          tfdesign
                          Ghostbusters? πŸ˜‰
                            mandar1983
                            Hello,
                            I have used ghost plug in to make proxy out of original object..
                            I have kept object in proxy format and exported it to kerkythea.
                            When i render it in kerkythea proxy object rendered without material why so?? Do we have convert the back to original form before exporting it into kerkythea every time??
                            Also i have some issues regarding camera in kerkythea. i have placed 3 cameras in the scene and have exported to kerkythea, but whenever i open the scene, i could not find the camera on the same location i have placed it? is it any kind of bug in kerkythea?? or there is some problem in my SU and kerkythea or somthing else?? ple help
                            Regards,
                            MANDAR
                              Yes, I am afraid you do. Ghost Components plugin can only solve performance issues in SU but it would not work as a proxy plugin for exporters. Certainly it could be modified somewhat (and/or the exporter plugin could accommodate) but for that, the two, different authors of the plugins should co-operate on one that works this way.
                              But then all the other renderers could ask the same.
                              • N Offline
                                niks
                                thanks Fredo.. you are a beast on what you do ❗ πŸ‘
                                  scrappy24
                                  Great work! "To God be the victory!" πŸ‘
                                    rachmatrf
                                    Wow! What a great plugin... 😍 😍 😍 😍
                                    I can not thank you enough to make this possible on sketchup... Where have I been so far to miss this wonderful plugin. SU Team surely should incorporate this in SU native version. I believe they will put this in the new Trimble Sketchup... Great work Fredo!!! and thanks once again....
                                      sellberg
                                      Thanks for this! IΒ΄ve only had a short test/peek/session w this RB. It seems super useful!
                                      I had one problem, though: I saved the model when in ghost mode and closed the program. When I opened the same model later I couldnΒ΄t reset the geometry to the complex form. I just saw the ghost. Have anyone else had similar experiences?
                                      //KJS
                                      Running a freeSU8 on a mac.
                                        rv1974
                                        Fredo,I just wondered would this dirty trick http://72.27.230.245/3ds-max/scripts/renderlayers-0 be possible in SU8?
                                          congellous
                                          This is a copy of my plug ins folder, I've upgraded to the new fredo lib and installed the ghost but nothing shows up in the program
                                          Have I got some conflict in here, it's a mess !
                                          __loader.rb
                                          .DS_Store
                                          #extrusionToolbar.rb
                                          AddCtrPnt.rb
                                          animation.rb
                                          artisan
                                          artisan_loader.rb
                                          attributes.rb
                                          Autounfold.rb
                                          bezier.rb
                                          box.rb
                                          clf_shape_bender
                                          clf_shape_bender_loader.rb
                                          contextmenu.rb
                                          ctsMaker
                                          curve_maker.rb
                                          CURVILOFT_Dir_12
                                          deBabelizer.rb
                                          DEFPARAM_Dir
                                          DOCUMENTATION_Dir
                                          drawhelix14.rb
                                          drawmetal_plugins_1_3_4.rb
                                          dropverts.rb
                                          Examples
                                          examples.rb
                                          examplescripts.rb
                                          extrudeEdgesByEdges.rb
                                          extrudeEdgesByFace.rb
                                          extrudeEdgesByFaces.rb
                                          extrudeEdgesByLathe.rb
                                          extrudeEdgesByLoft.rb
                                          extrudeEdgesByOffset.rb
                                          extrudeEdgesByRails.rb
                                          extrudeEdgesByRailsByFace.rb
                                          extrudeEdgesByRailsToLattice.rb
                                          extrudeEdgesByVector.rb
                                          extrudeEdgesByVectorToObject.rb
                                          faceFlattener019.rb
                                          fillet.rb
                                          flattery
                                          flattery.rb
                                          Fredo6Trace.txt
                                          FREDOSCALE
                                          FREDOSCALE_Dir_22
                                          FredoScale_Tool.rb
                                          FredoScale.rb
                                          generateSoapSkinBubble.rbs
                                          Geodesic_SketchUp.rb
                                          GhostComp%201
                                          Help
                                          iges_export.rb
                                          Images
                                          jointpushpull.rb
                                          JPP_Dir_20
                                          LIBFREDO6_Dir_48
                                          LibFredo6.rb
                                          LibTraductor.rb
                                          linetool.rb
                                          maxwell
                                          maxwell.rb
                                          Ocean
                                          ocean_extension.rb
                                          proper_animation
                                          proper_animation_loader.rb
                                          ROUNDCORNER
                                          ROUNDCORNER_Dir_23
                                          RoundCorner.rb
                                          RubyToPython
                                          SCF
                                          selection.rb
                                          shapes.rb
                                          SketchyFFD.rb
                                          skin.rb
                                          skp_to_dxf.rb
                                          skp_to_dxf.rbz
                                          SoapSkinBubble
                                          Help
                                          Images
                                          SoapSkinBubbleMenus.rb
                                          SoapSkinBubbleTools.rb
                                          stock_maker.rb
                                          SU_Podium_Browser.rbs
                                          SU_Podium_V2
                                          SU_Podium_V2.rbs
                                          SuSolid
                                          susolid.rbs
                                          taper_maker.rb
                                          TIGtools
                                          TOS
                                          TOS_Dir_18
                                          tt_cleanup.rb
                                          TT_Lib2
                                          tt_simple_installer.rb
                                          tt_solid_inspector.rb
                                          unfoldtool.rb
                                          Utilities
                                          utilities.rb
                                          utilities.rbs
                                          utilitiestools.rb
                                          vfs.rb
                                          weld.rb
                                          ZLoader__FredoScale.rb
                                          ZLoader__GhostComp.rb
                                          ZLoader__OnSurface.rb
                                          ZLoader__RoundCorner.rb
                                          • TIGT Online
                                            Have you activated its Extension from within Preferences.
                                            You might also then need to activate its Toolbar...
                                            • 3 / 6
