    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 230.5k Views 52 Watching
      rv1974
      @thomthom said:
      @rv1974 said:
      This tool is essential for those who send files with repetitive components to 3ds max.
      Unfortunatly only after removing this tool I solved the "grey out menus" problem. Is there any chance to update it?
      Have you updated your FredoLib files? I think most the issues lied within that library, not in the individual plugins. (with an odd exception)
      Yes I used latest lib pack (not 100% sure). Today I'll try it once more
        I've found a glitch with the code in 'GhostCompAlgo.rb'
        def onActivePathChanged(*args)
        	path = Sketchup.active_model.active_path
        	return unless path
        	comp = path.last
            return unless comp.valid? ###<<<
        	return unless is_ghost?(comp)
        	ask_confirmation comp
        If you don't include the extra line I've indicated with ###<<< then you get weird errors in the Ruby Console if you have been editing and then deleting Components... This simple fix ignores recently deleted components etc so no errors...
          Tig the ghost killer cleaner πŸ’š πŸ‘
          • T
            tfdesign
            Ghostbusters? πŸ˜‰
              mandar1983
              Hello,
              I have used ghost plug in to make proxy out of original object..
              I have kept object in proxy format and exported it to kerkythea.
              When i render it in kerkythea proxy object rendered without material why so?? Do we have convert the back to original form before exporting it into kerkythea every time??
              Also i have some issues regarding camera in kerkythea. i have placed 3 cameras in the scene and have exported to kerkythea, but whenever i open the scene, i could not find the camera on the same location i have placed it? is it any kind of bug in kerkythea?? or there is some problem in my SU and kerkythea or somthing else?? ple help
              Regards,
              MANDAR
              • GaieusG
                Yes, I am afraid you do. Ghost Components plugin can only solve performance issues in SU but it would not work as a proxy plugin for exporters. Certainly it could be modified somewhat (and/or the exporter plugin could accommodate) but for that, the two, different authors of the plugins should co-operate on one that works this way.
                But then all the other renderers could ask the same.
                • N
                  niks
                  thanks Fredo.. you are a beast on what you do ❗ πŸ‘
                    scrappy24
                    Great work! "To God be the victory!" πŸ‘
                      rachmatrf
                      Wow! What a great plugin... 😍 😍 😍 😍
                      I can not thank you enough to make this possible on sketchup... Where have I been so far to miss this wonderful plugin. SU Team surely should incorporate this in SU native version. I believe they will put this in the new Trimble Sketchup... Great work Fredo!!! and thanks once again....
                        sellberg
                        Thanks for this! IΒ΄ve only had a short test/peek/session w this RB. It seems super useful!
                        I had one problem, though: I saved the model when in ghost mode and closed the program. When I opened the same model later I couldnΒ΄t reset the geometry to the complex form. I just saw the ghost. Have anyone else had similar experiences?
                        //KJS
                        Running a freeSU8 on a mac.
                          rv1974
                          Fredo,I just wondered would this dirty trick http://72.27.230.245/3ds-max/scripts/renderlayers-0 be possible in SU8?
                          • C
                            congellous
                            This is a copy of my plug ins folder, I've upgraded to the new fredo lib and installed the ghost but nothing shows up in the program
                            Have I got some conflict in here, it's a mess !
                            __loader.rb
                            .DS_Store
                            #extrusionToolbar.rb
                            AddCtrPnt.rb
                            animation.rb
                            artisan
                            artisan_loader.rb
                            attributes.rb
                            Autounfold.rb
                            bezier.rb
                            box.rb
                            clf_shape_bender
                            clf_shape_bender_loader.rb
                            contextmenu.rb
                            ctsMaker
                            curve_maker.rb
                            CURVILOFT_Dir_12
                            deBabelizer.rb
                            DEFPARAM_Dir
                            DOCUMENTATION_Dir
                            drawhelix14.rb
                            drawmetal_plugins_1_3_4.rb
                            dropverts.rb
                            Examples
                            examples.rb
                            examplescripts.rb
                            extrudeEdgesByEdges.rb
                            extrudeEdgesByFace.rb
                            extrudeEdgesByFaces.rb
                            extrudeEdgesByLathe.rb
                            extrudeEdgesByLoft.rb
                            extrudeEdgesByOffset.rb
                            extrudeEdgesByRails.rb
                            extrudeEdgesByRailsByFace.rb
                            extrudeEdgesByRailsToLattice.rb
                            extrudeEdgesByVector.rb
                            extrudeEdgesByVectorToObject.rb
                            faceFlattener019.rb
                            fillet.rb
                            flattery
                            flattery.rb
                            Fredo6Trace.txt
                            FREDOSCALE
                            FREDOSCALE_Dir_22
                            FredoScale_Tool.rb
                            FredoScale.rb
                            generateSoapSkinBubble.rbs
                            Geodesic_SketchUp.rb
                            GhostComp%201
                            Help
                            iges_export.rb
                            Images
                            jointpushpull.rb
                            JPP_Dir_20
                            LIBFREDO6_Dir_48
                            LibFredo6.rb
                            LibTraductor.rb
                            linetool.rb
                            maxwell
                            maxwell.rb
                            Ocean
                            ocean_extension.rb
                            proper_animation
                            proper_animation_loader.rb
                            ROUNDCORNER
                            ROUNDCORNER_Dir_23
                            RoundCorner.rb
                            RubyToPython
                            SCF
                            selection.rb
                            shapes.rb
                            SketchyFFD.rb
                            skin.rb
                            skp_to_dxf.rb
                            skp_to_dxf.rbz
                            SoapSkinBubble
                            Help
                            Images
                            SoapSkinBubbleMenus.rb
                            SoapSkinBubbleTools.rb
                            stock_maker.rb
                            SU_Podium_Browser.rbs
                            SU_Podium_V2
                            SU_Podium_V2.rbs
                            SuSolid
                            susolid.rbs
                            taper_maker.rb
                            TIGtools
                            TOS
                            TOS_Dir_18
                            tt_cleanup.rb
                            TT_Lib2
                            tt_simple_installer.rb
                            tt_solid_inspector.rb
                            unfoldtool.rb
                            Utilities
                            utilities.rb
                            utilities.rbs
                            utilitiestools.rb
                            vfs.rb
                            weld.rb
                            ZLoader__FredoScale.rb
                            ZLoader__GhostComp.rb
                            ZLoader__OnSurface.rb
                            ZLoader__RoundCorner.rb
                              Have you activated its Extension from within Preferences.
                              You might also then need to activate its Toolbar...
                              • C
                                congellous
                                There doesn't seem to be an extension in there ?
                                It has instal extension which one is the extension ?
                                  • C
                                    congellous
                                    Yeah it's not there
                                      In your list there's 'GhostComp%201' what's that ?
                                      Looks like an html based name ?
                                      There ought to be a folder called 'GHOSTCOMP_Dir_10'
                                      containing these files Capture.PNG This suggests you has mis-installed it...
                                      • C
                                        congellous
                                        Dunno what that was but removing it sorted it, didn't even need to turn the extension on. Thanks TIG
                                        • P
                                          parsleybrain
                                          Hello Fredo, thanks for another great plugin. So I startet to use it and it worked just fine. I've lots of railings in my model, some are just copies of components but I also had to make a bunch of them unique and to tweak them. Finally making even one copy of an component took so long I decided to use your ghostcomp. And it worked - but now Sketchup always chrashes when I try to create a ghost component. Do you have any advice or idea what to do about that? Thanks in advance.
                                          • fredo6F
                                            Please make sure you have the most recent versions. For the crash, it may be some conflicting plugins (some versions of Vray and Podium for instance)
                                            • 3 / 6
