    Sketchup is Inacurrate???
    513 Posts 38 Posters 212.0k Views 38 Watching
    • jeff hammondJ
      @wo3dan said:
      You've got the correct model as I can see in later posts.
      I know that there are minor differences, maybe even due to having things separated in groups. But the idea is good. That fact that they do not exactly share the same center if you zoom way in, yes you are right. But maybe this is due to speedy modeling to get the idea across. I stick with accepting this as a good offset solution.
      And come on, segments not being parallel? so what?
      dunno.. my last post right before yours has the lines parallel as well as true arc measurements so it is possible.. that's all i'm saying.. you don't need to compromise in this situation.. you just gotta calculate it properly..
      (re: parallel... i don't mean the segments of the arcs being parallel in john's example.. i'm talking about the straight edges leading into the arcs.. those are simple edge offsets and should be parallel)
      the edges on the bottom version aren't parallel.. they are in the top version
      And you can't be serious when saying that a chord doesn't have anything to do with the accuracy of an arc. Not on its own, but together with the defined radius there's only one arc on either side of the point at center, all vertices on a true circle.
      The chord, together with the radius, defines the angle that is covered by the arc.
      right.. the actual chord length of the entire arc is of course of utmost importance..
      i thought you were talking about chord length between individual segments of an arc.. in which case, they're irrelevant.. i showed a picture a page or two back which had an arc drawn with all sorts of varying chord lengths amongst it's individual segments.. but it's still an arc in the same way as if it were equally divided and segments had the same chord length..
      (i mean... you only need 3 points to define an arc.. the start and endpoints (or chord length if measured that way) then one single point anywhere along it's radius.. that 3rd point doesn't have to be in the middle - it can go anywhere which will created lopsided segmentation but it's still accurate)
      [but i kinda feel like you're just hellbent on trying to prove me wrong or smthng without actually looking at the various situations/models being discussed.. πŸ˜‰ ]
        driven
        that's the only way i can figure out how to do this accurately without leaving sketchup.. but i also feel sketchup could be smarter and do the maths for us πŸ˜‰
        I would call yours accurate, and to check it, I changed the arc segments on mine to 8 and they align perfectly...
        when you've checked that, you can ask what plugin I use;] to draw th arcs.
        • jeff hammondJ
          hey john
          the amount of segments is irrelevant.. i just used 8 because it's easier to see where the vertices are..
          changing yours to 8 does nothing to move the endpoints into their proper position.. (finding the endpoints in this situation is the only thing to be concerned with because sketchup can't do it naturally so you have to workaround.. all the other parts are easy to draw with native tools).. they should be 1000.000000mm perpendicular to the straight edges but they're not.. those straight edges on the left and right side should be parallel..
          re: plugin.. not sure.. me personally though, i always use didier's 3pt Arc.. (centerpoint,end,end) ...as in, i bet i use that plugin more than any other single plugin.. (actually, i know i do)
          [edit] ie- getting those endpoints is not much different than that 20pg mini challenge thread a while ago.. it all boils down to sketchup not having real circles.. (and i don't mean real circles visually on screen, it's fine if they're segmented.. i mean it's brain doesn't have real circles.. so it can't find intersections other than straight lines crossing each other)
            driven
            I just used the given geometry, I didn't redraw the straight edges, [ I wasn't doing it as a pissing contest (@ that point)]
            I know you use 3pt Arc.. and that's exactly why I did as well.
            All I was trying to point out was if we can draw it that 'close to being' accurate, then the engine didn't need changing, it just needs exposing in an easy to use tool, either as an additional option or as a new tool.
            The biggest thing that annoys me [other then you, of cause!], is the 'Offset Tool' doesn't snap on the arc point, so you can't be accurate with it.
            • Wo3DanW
              Wo3Dan
              .....[but i kinda feel like you're just hellbent on trying to prove me wrong or smthng without actually looking at the various situations/models being discussed.. πŸ˜‰ ]
              Sorry if you feel that way, for that is not the case.
              Just a few misunderstandings. At one point (corresponding vertices not being lined up towards the center) I argued in your favor about John's solution. But you set that aside as not being important.
              I don't much care who's right. It's all for a good second option in the 'Offset' tool, hence my little challenge. But Right now I don't think much of repairing the offset at its ends, something I supported at first
              PO?,....... I hope not,........nah.
              p.s. my PC is acting weird. I can hardly keep up with all the examples that are being uploaded. Loading a model (even from HD) can take upto 5 minutes where it should only be seconds.
              • jeff hammondJ
                ha.. i'm not pissing contesting either.. we were just talking about accuracy for the past week or so in the thread so i think it's important (for the sake of this particular discussion at least) to be accurate..
                check out this plugin.. i did this huge workaround 10x faster than it took me to do the sketchup-only work around..
                (no audio)
                (**includes bonus footage of su's spazzed dwg importer)
                that's the same model saved right after i quit ishowU_ing
                that's not a plug in.. it's a plug out..
                why would i want to use sketchup at that point? i wouldn't.. that was kinda my whole point up until page 20smthng when jbacus basically summed up the future regarding circles in sketchup..
                i guess now i'm just talking because i'm a nerd like that πŸ˜‰
                nah.. the engine needs changing.. it needs to be smarter regarding circle.. there is no new tool that's going to solve this because it's the whole app being affected-- not just the offset tool.. teach sketchup some basic circle stuff and a whole slew of problems will start disappearing.. otherwise, all you're going to do with a new tool is pile more crap on top of a weak foundation.. fix the foundation .
                (of course.. that is simply my opinion.. i truly understand that many people couldn't care less about this)
                re: annoying..
                i annoy myself with this stuff too.. like i'm bothered that i'm even bothering any longer.. i wish i could stop but i haven't found the switch yet πŸ˜†
                • DesertRavenD
                  DesertRaven
                  (of course.. that is simply my opinion.. i truly understand that many people couldn't care less about this)....
                  I'm sure there are plenty of folks out there who wouldn't care about these issues, mostly the ones used to how SU works, because they are set in their ways.
                  Many have a problem with changing things to the better and settle for what they can get.
                  I think it would be a shame if SU would not evolve and I do see the great potential.
                  I'm very happy that it did evolve to where they added the solid tools. These are a great asset in today's world of e.g. 3D printing and a step closer to making us build more accurate models. (and requires SU to be even more accurate)
                  So as we progress, the requirements and standards will also become higher. To not improve would be going backwards. I, for my part, would love to keep working with SU in a world that changes fast and be able to deliver great and accurate work for my clients.
                  simplicity is the ultimate sophistication
                    @Jeff
                    You must return make a little visit to the Moi Forum ! πŸ˜‰
                    • jeff hammondJ
                      @Jeff
                      i did.. michael pretty much told me I'm dumb for using sketchup πŸ˜†
                      not in a way that says anything bad about sketchup but more in a way of..
                      "hey, it's not sketchup's fault for not working that way.. it's your fault for trying to use it that way.. "
                      (actually, he didn't say any of that really... it's just the feeling i got after reading.. but if he did say exactly that, i'm thinking i agree πŸ˜‰ )
                        πŸ˜„
                        Despite of all that, what is the best connection between 2 parts of any inclined roads on a flat terrain?
                        (in any progs of course just in theory with same width on the path)
                        Compass+ Protractor + Set Square + Ruler
                        Arc circle + tangency
                        Blend + tangency G1, g2, g3...+ Bulge
                        Fillet G1, g2, g3...+ Bulge
                        Sweep variation
                        Conics
                        Offset of one jointure πŸ˜„
                        From a joined yellow line then propagate a perpendicular width segment
                        (here connection wanted on the top)
                        • gillesG
                          gilles
                          Tangent arcs.
                          Tangent arcs_V6.skp
                            Robust! β˜€
                            And if for any reason I don't want elongate in straight line the piece of road on the right ?
                              Robust! β˜€
                              You then need to shorten the road on the left AND increase the radius !
                              There can only be one circle of a given radius that is tangential to two lines drawn line this, and it will determine its own 'kissing' points on these... Its center is always on the bisector of the edges' angle, and the circle can slide along this, and therefore depending on its radius that will fix the center, because it must be the radius away from both edges when measured perpendicularly from them...
                                driven
                                in Pas-de-Calais it would need to be like this
                                • mitcorbM
                                  mitcorb
                                  I have been following this thread. And I care, if it is do-able.
                                    Robust again β˜€
                                    So if for any reason I don't want elongate or shorter in straight line pieces of road on the left and the right connection with tangency is impossible ?
                                    Said a "plumber" who has not straight tubes but any curvated one πŸ˜„
                                    • jgbJ
                                      jgb
                                      πŸ™‚
                                      This is a standard "OGEE" Curve problem of joining 2 non parallel roads. β˜€
                                      Did it in High School (that's 53 years ago πŸ˜‰ ) with pencil, compass, slide rule, protractor and ruler. No such thing as a pocket calculator then, let alone Sketchup.
                                      But damned if I could remember how I did it!!! πŸ˜’ πŸ˜•
                                      Played in SU for 29 min and got nowhere. πŸ˜†
                                      So the attached drawing is a "Sketch" of what the solution would be.
                                      Not calculated, just by eye.
                                      The "road" rectangles are drawn overlaid on Pilou's ROAD.JPG.
                                      This is a sketch of a solution, not an accurate drawing.
                                      jgb
                                      • jeff hammondJ
                                        πŸ™‚
                                        Sweep variation
                                        Conics
                                        in sketchup, you can use bezierSpline to get a tangent b-spline for one connection.. as far as accurately offsetting that curve, i don't know how to.. the maths go beyond my knowledge at that point and i'd rather just have software do the proper calculations for me πŸ˜‰
                                        (and actually, i don't know the maths to even see if the sketchup drawn b-spline is in fact correct.. and this is an instance where, to me, it's required that i'm using an app that i can fully trust to give the right solutions.. goes back to what i was saying about knowing the numbers.. i don't know the numbers here and neither does the app so i'm screwed..)
                                        β€’ draw an extended line to the one you would like to connect tangentially to..
                                        β€’ using uniform B-spline set to an order of 4 at least, make 4 clicks, (first tangent point, end of it's extended line, end of the other side's extended line, second tangent point)
                                        but assuming that curve is in fact correct, i have no idea how to proceed with offsetting properly (as in, arcs are easy to understand.. these types of curves?.. well, let's just say i was never taught about them in school..
                                        but hey, in sketchup, i could definitely come up with something that looks ok.. πŸ˜‰
                                          Seems very cool too! β˜€
                                          • jeff hammondJ
                                            or, using the ArcBlend command, you'd play with it for 29 seconds and see all possible solutions.. πŸ˜‰
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 25 / 26
