    Batch rendering?
    renderpluginsextensions
    37 Posts 15 Posters 34.5k Views 15 Watching
    • panixiaP
      panixia
      did you check "enable scene transition" in sketchup animation settings???
      • FlatchoumF
        Flatchoum
        Yes I did, the scenes render, but just don't get saved anywhere...
        • FlatchoumF
          Flatchoum
          HI, still haven't found a solution, except for wacking up every hour last night, change scenes manually, pray and go back to bed...for one hour. I tryed several ways, calculating pictures of 5x5...They always calculate but don't get saved anywhere. I wish I could find a solution before the end of this world, please help!
          • ATLAStudioA
            ATLAStudio
            This tutorial has fairly comprehensive options setup, not sure if it'll solve the issues though as haven't tried animation myself.
            http://sketchupvrayresources.blogspot.co.uk/2011/08/tutorial-vray-sketchup-animation.html
            http://www.atlas-studio.co.uk
            • andybotA
              andybot
              Just a simple thing to check - have you specified a file name for your saved images? You have to have autosave enabled so vray can save your images.
              • P
                pierreaudouin
                I also had this problem recording.
                I did a search in windows and the files were stored in TEMP / vfstextureCache.
                I hope you find it!
                • P
                  pierreaudouin
                  @lvl1201 said:
                  In some older version of vray the scene 1 will be rendered 2 times in version 1.49.01 this no longer happens.
                  I have the last version of Vray (1.49.01), but the first scene is rendered two times!!!
                  I don't know why.
                  Is it the same for you?
                  • FlatchoumF
                    Flatchoum
                    Thanks for your answers, I still have the same problem; to Andybot, yes I specified a name, and to PierreAudouin, I'm very surprised, it looks like I don't have such a file named vfstextureCache? I looked for it, I don't think I have Hidden files, on Windows 7... Still trying to do a Batch rendering now, I hope 2013 gives me the answer. I'm on Sketchup 8 and bought my Vrayfor SU version in August. To Pierre, you must have an option like "reboot on first scene"?
                    • FlatchoumF
                      Flatchoum
                      Wow! I just looked again, and I finally found the pictures! They were hidden in the OS(C:)/User/(Me)/AppData/Local/Temp/VfsTextureCache!!!
                      Thank god I can now work and sleep 8 hours in a row!! And Special thanks to PierreAudouin too, you were right! I just wonder why the pics are saved ther and not where I told Vray to save it? an other bug? And the search tool on windows 7 is just useless, perhaps should I stay on a mac next time I buy a Computer...This little gag almost cost me a project
                      • P
                        pierreaudouin
                        Yes, good, this is 2013!!!
                        Happy new year!
                        it's weird, it is thanks to the windows search tool I have found my files.
                        Good for you.
                        I search "reboot on first scene".I don't have option like this.
                        it doesn't matter,but if you have a solution...
                        • FlatchoumF
                          Flatchoum
                          Happy new year too! I can't find this option any more, but I'm pretty sure it was part of the previous sketchup versions. By the way I also have the first scene doubled in my file this morning...And they look strictly the same? Now I have a little bug with the "face me components": some of them are grouped at the origin of the axes...Weird, but I may find an explanation on this forum...
                          • peter_shawP
                            peter_shaw
                            is it possible to change layer states during a batch render? i'm trying to render an animation made with SU animate, but vray only seems to accept the layer state of the first scene.
                            check the attachement to see what i mean
                            Untitled.skp
                            • andybotA
                              andybot
                              unfortunately, no. That's just the way vray works currently. It only loads the model once at the beginning for batch rendering.
                              • P
                                pierreaudouin
                                and i ask the same question with camera setting (focal, aspect ratio...)?
                                • peter_shawP
                                  peter_shaw
                                  only position if i remember correctly
                                  • andybotA
                                    andybot
                                    correct, all the vray variables are set per model. Have to adjust it for each scene 😞
                                    • FlatchoumF
                                      Flatchoum
                                      Since I know how to do a batch rendering, I also get twice the same picture, with twice the render time, for the first scene of my Skp file. I bought my Vray version in july, but I'm not sure which version it is, where do I find it, and is there a way to solve this problem, please?
                                      • FlatchoumF
                                        Flatchoum
                                        At the moment the only solution I found not to lose hours of useless calculation time, is to create a first scene which focuses on a white wall without reflection in a part of my file...Then Vray renders it twice and can start calculation of the other scenes...But it's a bit tricky, isn't it?
                                        • panixiaP
                                          panixia
                                          i used the same once.. the only difference creating a scene inside a black cube wich is also faster than a white wall.. 💭
                                          however i generally tend to (rarely to be honest) use batch for test of multiple scenes and to avoid at all batch render for the advanced/final renders, because it does not support layer changes, camera changes, visopt changes, emissive material changes, additional channels etc.. 😞
                                            AMELIEBOB
                                            I followed your steps and it saved with the name and the location i adressed! I saw all the scenes change one by one, the VR frame buffer appeared, i went to sleep. The next morning : I found like 4 exact scenes and another one (the same scene!) rendering in VRFB!!
                                            vray kept rendering the same scene over and over!
                                            ❗ ❗ Is there any solution to this problem??
                                            • 2 / 2
