    Completely lost on how to create this orb
    19 Posts 11 Posters 555 Views 11 Watching
      Mra
      Hi there,
      A bit of a challenge, how would one create this in SketchUp?
      As you can see the light is made up of one or two components that is instanced around. My questions is obviously how would one be able to do this and line up all these components?
      I can't label this type of geometry to even begin finding out how to start. Thanks!
        d12dozr
        That looks like it may be a geodesic structure. I'd take a look at Taffgoch's collection in the 3D warehouse for some ideas.
        http://goo.gl/f7ooYh
        • massimoM Offline
          massimo Moderator
          I think that the main problem with those kind of lamp is that the elements are not coplanar, but are kinda twisted each other. See David Trubridge designs for example.
          • olisheaO Offline
            olishea
            Seems to be just two tessellations making up all the components of the lamp. I would use Tool on Surface to a sphere to create the initial curved components then copy as an array around the sphere. At this point you could also add the twisted ends so they overlap) Here you could move the components over each other so they aren't co planar and then add the little rivets. It's quite simple if you break it down but tricky in execution.
            oli
              Make a Geodesic sphere.
              MultipleFaceOffset.
              Erase all faces with <=4 edges...
              JointPushPull.
              Use Artisan to sub-divide/smooth it...
              Choose the 'sphere' type that gives the 'hole pattern' desired...
              • pbacotP Offline
                Nice, TIG. I kept working along those lines myself but it would either crash the computer or look like crap... I will be interested to use exactly the steps you have. I perhaps made the mistake to create my first sphere with Artisan. And I used Lattice maker. I wonder if some creasing will give sharp edged cut-outs?
                  LatticeMaker makes the parts as ovelapping frames which can't be easily made solid - even with SolidSolver.
                  Windowizer4 has similar limitations.
                  Here's my workflow.
                  Make a Geodesic sphere == I used that plugin, octahedron, 2 iterations, 1m radius.
                  Edited the 6 small 'sqaures' into one face...
                  MultipleFaceOffset == I used that plugin, 50mm offset.
                  Erase all faces with <=4 edges... I selected all inside the group and wrote a one-liner in the Ruby Console:
                  Sketchup.active_model.selection.each{|e|e.erase! if e.is_a?(Sketchup::Face)&&e.edges.length<=4}
                  JointPushPull == used that with 50mm offset and keeping original faces, no partitions. Makes result as a 'solid'...
                  Oriented the faces...
                  Used Artisan to sub-divide/smooth it...
                  • N Offline
                    nickchun
                    It's basically this shape(roughly, I haven't rounded all the corners) UV wrapped around around a sphere. The problem is its 5 sided. Any way to do that?
                      That's why it's best to start with some kind of Geodesic sphere...
                      Mapping an image onto a sphere is going to give you brain-ache... πŸ˜•
                        MartinK
                        Here's an attempt. I started with a geodesic sphere from the warehouse. I don't have time to go through the steps, but I remade it with components. The model is attached if you want to explore the parts. It's not perfect and might not even be accurate, but it was a fun experiment. Hope it helps.
                        Test1b.skp
                          Mra
                          Wow, thank you so much for the amazing responses everyone. All these techniques are such good ideas, I'll try and build this myself using the different methods mentioned above as well to learn more complex items in SketchUp!
                          Much appreciated! πŸ‘
                          • gillesG Offline
                            gilles
                            I enjoy geodesic, see this one:
                            orb_V6.skp
                              MartinK
                              Very nice Gilles πŸ‘
                              • cottyC Offline
                                cotty
                                WOW! I can't resist to let it jump πŸ˜‰
                                my SketchUp gallery
                                  Mra
                                  Very clever, just shows how capable SketchUp is in the right hands.
                                  • TaffGochT Offline
                                    TaffGoch
                                    Good examples, above...
                                    I've (thus far) modeled the basic geometry of the pentagonal components.
                                    The pendant lamp geometry is based on a 3v, class-I geodesic sphere.
                                    (Contributors have been quick to jump on this question. I almost missed seeing it, while lurking.) 😳
                                    -Taff
                                    "Information is not knowledge." -- Albert Einstein
                                    • TaffGochT Offline
                                      TaffGoch
                                      I produced the curved-arm portions, simply by radially-copying rectangles along an arc between the geodesic vertices.
                                      Here's a detail, showing "hidden geometry" (lines.)
                                      -Taff
                                      • TaffGochT Offline
                                        TaffGoch
                                        Not quite as "spindly" as the real lamp....
                                        Pendant lamp; 3v.skp
                                        • TaffGochT Offline
                                          TaffGoch
                                          Geodesic-based lamp spheres have, seemingly, been popular, over the past few years.
                                          Here's a sampling for your SketchUp modeling exercises:
