    Completely lost on how to create this orb
    19 Posts 11 Posters 1.4k Views 11 Watching
    • olisheaO Offline
      olishea
      Seems to be just two tessellations making up all the components of the lamp. I would use Tool on Surface to a sphere to create the initial curved components then copy as an array around the sphere. At this point you could also add the twisted ends so they overlap) Here you could move the components over each other so they aren't co planar and then add the little rivets. It's quite simple if you break it down but tricky in execution.
      oli
        Make a Geodesic sphere.
        MultipleFaceOffset.
        Erase all faces with <=4 edges...
        JointPushPull.
        Use Artisan to sub-divide/smooth it...
        Choose the 'sphere' type that gives the 'hole pattern' desired...
        • pbacotP Offline
          Nice, TIG. I kept working along those lines myself but it would either crash the computer or look like crap... I will be interested to use exactly the steps you have. I perhaps made the mistake to create my first sphere with Artisan. And I used Lattice maker. I wonder if some creasing will give sharp edged cut-outs?
            LatticeMaker makes the parts as ovelapping frames which can't be easily made solid - even with SolidSolver.
            Windowizer4 has similar limitations.
            Here's my workflow.
            Make a Geodesic sphere == I used that plugin, octahedron, 2 iterations, 1m radius.
            Edited the 6 small 'sqaures' into one face...
            MultipleFaceOffset == I used that plugin, 50mm offset.
            Erase all faces with <=4 edges... I selected all inside the group and wrote a one-liner in the Ruby Console:
            Sketchup.active_model.selection.each{|e|e.erase! if e.is_a?(Sketchup::Face)&&e.edges.length<=4}
            JointPushPull == used that with 50mm offset and keeping original faces, no partitions. Makes result as a 'solid'...
            Oriented the faces...
            Used Artisan to sub-divide/smooth it...
            • N Offline
              nickchun
              It's basically this shape(roughly, I haven't rounded all the corners) UV wrapped around around a sphere. The problem is its 5 sided. Any way to do that?
                That's why it's best to start with some kind of Geodesic sphere...
                Mapping an image onto a sphere is going to give you brain-ache... πŸ˜•
                  MartinK
                  Here's an attempt. I started with a geodesic sphere from the warehouse. I don't have time to go through the steps, but I remade it with components. The model is attached if you want to explore the parts. It's not perfect and might not even be accurate, but it was a fun experiment. Hope it helps.
                  Test1b.skp
                    Mra
                    Wow, thank you so much for the amazing responses everyone. All these techniques are such good ideas, I'll try and build this myself using the different methods mentioned above as well to learn more complex items in SketchUp!
                    Much appreciated! πŸ‘
                    • gillesG Offline
                      gilles
                      I enjoy geodesic, see this one:
                      orb_V6.skp
                        MartinK
                        Very nice Gilles πŸ‘
                        • cottyC Offline
                          cotty
                          WOW! I can't resist to let it jump πŸ˜‰
                          my SketchUp gallery
                            Mra
                            Very clever, just shows how capable SketchUp is in the right hands.
                            • TaffGochT Offline
                              TaffGoch
                              Good examples, above...
                              I've (thus far) modeled the basic geometry of the pentagonal components.
                              The pendant lamp geometry is based on a 3v, class-I geodesic sphere.
                              (Contributors have been quick to jump on this question. I almost missed seeing it, while lurking.) 😳
                              -Taff
                              "Information is not knowledge." -- Albert Einstein
                              • TaffGochT Offline
                                TaffGoch
                                I produced the curved-arm portions, simply by radially-copying rectangles along an arc between the geodesic vertices.
                                Here's a detail, showing "hidden geometry" (lines.)
                                -Taff
                                • TaffGochT Offline
                                  TaffGoch
                                  Not quite as "spindly" as the real lamp....
                                  Pendant lamp; 3v.skp
                                  • TaffGochT Offline
                                    TaffGoch
                                    Geodesic-based lamp spheres have, seemingly, been popular, over the past few years.
                                    Here's a sampling for your SketchUp modeling exercises:
