    How to create a Mask in Layout
    layout
    42 Posts 9 Posters 7.9k Views 9 Watching
      That just sounds like a lot of work to me. If it works for you, great. If I had to work that way I think I'd quit and do something else. πŸ˜‰
      • porch_unpluggedP
        porch_unplugged
        It's not too bad, drawing out a clipping mask in layout sounds like a lot more work to me. Doesn't look like I'll be getting Pro and layout any time soon, so it'll have to do. πŸ˜„
        • bmikeB
          bmike
          have a look at my layout overview.
          even if you don't go pro - there are lots of ways to setup your sketchup to streamline your workflow.
          • porch_unpluggedP
            porch_unplugged
            @pbacot said:
            Brian: Have you tried a dwg export or vector pdf to CAD? I think there a plugins for the dwg or dxf if you don't have pro.
            thought never crossed my mind, i'll look into it, thanks Peter.
            I'm sure I've watched it already, but just waiting for it load again now (rubbish internet connection) Thanks Mike πŸ‘
            • pbacotP
              Brian: Have you tried a dwg export or vector pdf to CAD? I think there's a plugins for the dwg or dxf if you don't have pro.
              • P
                penumbra
                How about this? What do you do when you have elements on an elevation that are not orthogonal with the view plane as in walls that are at an angle and receding away from the viewer?
                  What do you mean, "what do you do?" What would you do? Could you post an example?
                    You could us Fog in SKP scene-tab or a Style with depth-cues - to show them feinter.
                    You could use a SectionPlane in the SKP scene-tab to hide everything towards the back of the model.
                    You could make a large white grouped vertical face on a special layer that's only on in that scene-tab, locate it to obscure the back of the model.
                    Or a shaped mask face overlaid in LayOut to hide them, or even made edgeless and translucent to show what's behind feinter.
                    There are many ways to achieve different effects - you choose or invent one that does what you want... πŸ˜•
                    • P
                      penumbra
                      Thanks tig. Very helpful.
                      • pbacotP
                        Penumbra,
                        In common elevations, one should be able to see background elements of the building. Here is a masterful use of fog by Sonder, in SU and LO:
                        http://sketchucation.com/forums/download/file.php?id=80022&t=1
                        404 Not Found
                        (sketchucation.com)
                        Peter
                        • P
                          penumbra
                          Thanks Peter, i find fog difficult to control but once is setup right, looks great.
                          • bmikeB
                            bmike
                            I find it difficult to use as well, likely operator error on my part.
                              Use [and update] scene-tabs, styles etc to 'remember' your settings for fog, layers etc
                                sonder
                                Fog is really easy to use. I set it up always in SU saved to the scene. Once you understand how the two arrows work, it is really intuitive. I like to think of the two as - right arrow = overall fog thickness - thicker as you slide to the left. Left arrow = fog depth from view point to your model - gets thinner as you slide it towards the right arrow.
                                I wish the fog in my brain were so easily controlled.
                                • bmikeB
                                  bmike
                                  Do you need a separate style anytime you change the arrows? Or is it remembered per scene like the shadows?
                                  • pbacotP
                                    Per Scene.
                                      sonder
                                      Yes, it saves with the scene when updated after adjustment.
                                      • 2 / 3
